I have a 2017 Civic Coupe base 2.0L. I did the first oil change with PP at 7K, and I'm coming right up on 10K now (there's a service bulletin that advises to leave the factory fill in as long as possible so I drew it out to when my maintenance minder hit 5%. The bulletin is from the '90s though).
I'm going to change the oil and send a sample to BlackStone. Would it make any sense to change the transmission fluid now just for kicks? Like to empty out metal shavings from the machining process or whatnot? I could send them a sample of transmission fluid too.
It's not a big inconvenience for me to do this but I'd like to know if I'm just being neurotic? It's just a basic drain and fill on the transmission. I've always used Honda OEM fluid in the transmission.
