Nylon spacers
by VeeDubb - 07/06/20 02:37 PM
Extra Long Valve Caps
by Mr_Luke - 07/06/20 02:28 PM
using vinegar to flush cooling system
by old1 - 07/06/20 02:11 PM
Best lube for refrigerator door hinges?
by paulri - 07/06/20 01:11 PM
RIP Ennio Morricone
by 2015_PSD - 07/06/20 12:49 PM
What oil do you recommend?
by BretBouer - 07/06/20 12:36 PM
NAPA Synthetic / Filter Sale
by WyrTwister - 07/06/20 12:16 PM
Squished Stihl MS 181
by Gebo - 07/06/20 12:14 PM
Used Review- '17 Nissan Armada Platinum
by panthermike - 07/06/20 11:53 AM
RIP Charlie Daniels.
by PimTac - 07/06/20 11:34 AM
Transmission fluid change
by dan765 - 07/06/20 10:53 AM
Toyota LL or SLL in a Ford?????
by TacoFergie - 07/06/20 10:52 AM
Pulling a vacuum to remove water
by Donald - 07/06/20 10:42 AM
03 4.7 Durango - AC System
by joshuawesl - 07/06/20 10:40 AM
19 4Runner M1 0w40 11k oci
by Doublehaul - 07/06/20 10:11 AM
Fiberglass Garage Door
by Al - 07/06/20 09:57 AM
EcoGard x4615 can l "use it with confidence"?
by Joe1 - 07/06/20 09:43 AM
Bearing issues on rebuilt engine
by Mullady76 - 07/06/20 08:57 AM
Portable tire inflator
by RoyClark - 07/06/20 08:52 AM
AnotherPerson, biomatrix, CDN, KeyzzDzz, carms
71858 Registered Users
110 registered members (53' Stude, 911Don, 77GrandPrix, A310, 2015_PSD, 379KITTY, 12 invisible), 2,369 guests, and 23 spiders.
Topics307,493
Posts5,312,141
Members71,858
Page 6 of 9 1 5 6 7 9
Re: Has anyone had oil-related issues during the polar vortex? [Re: Triple_Se7en] #4998501 02/01/19 03:03 PM
P
Patman Offline
Global Moderator
Global Moderator
P
Originally Posted by Triple_Se7en
Facing the vehicle to the wind in an open area, gives those cold starts a real-feel temperature to deal with.
Wind chill has zero effect on an engine, it's all about the ambient temperature.
2018 Corvette, 22k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 156k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,130k, GC 0w40 & Fram Ultra
Re: Has anyone had oil-related issues during the polar vortex? [Re: Patman] #4998516 02/01/19 03:10 PM
Z
ZeeOSix Offline
Z
Wind chill has zero affect on an engine, it's all about the ambient temperature.
Wind only effects the rate of heat loss, but yeah, it can't get any colder than the still air temperature.
Re: Has anyone had oil-related issues during the polar vortex? [Re: Gokhan] #4998615 02/01/19 04:28 PM
2
2003GPW Offline
2
Here in northern Illinois, my IS300 sat outside from last Saturday, the 26th, until Wednesday morning. It was about -30F. Wind chill was around -53F. The cat had a vet appointment at 9am. I went out to start it up at 8. It cranked as slowly as I've ever heard a car crank. The battery is 3 years old. It fired up after what seemed like 20 seconds of turning over. I let it run for 25 minutes before leaving and I left it running at the vet's while I was inside for an hour. Other than the very hard start, the only other thing that struck me was that the power steering fluid never thinned out. After two and a half hours running, the steering was still very heavy. This car is a champ! Fifteen years old with almost 150,000 on it and it's as solid and reliable as most new cars out there. My neighbor's 2016 Chevy small-suv-thingy didn't start that same morning.
Also, the forecast for Monday is 41F and rain. What a difference 5 days makes.
2004 Lexus IS300 5 Qts M1 5W-30, .5 Qt M1 15W-50
2003 S2000 4 Qts M1 5W-30, 1 Qt M1 15W-50
2009 Corolla 1.8 M1 5W-20
2015 Freightliner DD13 Cenex Maxxtron 5W40
Re: Has anyone had oil-related issues during the polar vortex? [Re: 2003GPW] #4998626 02/01/19 04:37 PM
O
OVERKILL Online Content
Online Content
O
You were definitely past the cold cranking
You were definitely past the Cold Cranking rating for your "blend" and were probably right into the pumping limit. The CCS limit for the 5w-xx designation is -30C (-22F), you were roughly 5C below that at -35C, which is where the cold temp pumping limit for the designation is tested. Considering you have it mixed with 1/2 a quart of 15w-50, you are lucky it pumped.
2020 Jeep Grand Cherokee SRT Ravenol SSL 0w-40, FRAM Ultra
Re: Has anyone had oil-related issues during the polar vortex? [Re: Gokhan] #4998628 02/01/19 04:40 PM
SatinSilver Offline
2005 Matrix with 5w30 VWB in it. Car has 150k and started up just fine at -3 the other morning. Just put a new battery in since the old one was over 6 years old. Glad I replaced it. I only let it idle for 30 seconds since the cold idle is pretty high, around 1600 or so. I just go very easy on it and the rpms are around 1800 or so when driving. Car seemed to do fine. Also have 4500 miles/3 months on the VWB so time for an oil change soon. Fourth consecutive interval of that oil and doesn't burn a drop of it unlike with some other oils like MC syn-blend 5w20 and 5w30.
Have 5 qts of PUP 5w20 on hand along with 20 qts of Idemitsu 0w20 full syn that I can use.
Re: Has anyone had oil-related issues during the polar vortex? [Re: SatinSilver] #4998635 02/01/19 04:44 PM
53' Stude Online Content
Online Content
Good to hear sir. The PP 5w30 did great Wednesday and Thursday morning smile
2009 Toyota Camry LE
Re: Has anyone had oil-related issues during the polar vortex? [Re: Gokhan] #4998636 02/01/19 04:45 PM
H
Huie83 Offline
H
I'm in MN. I parked my VW Golf TDI outside on the coldest night, -50'ish. Cycled the glow plugs a few times and it fired right up in the AM, no drama, no weird noises. It has Castrol SLX professional 5w-30 in it.
Our 2010 Impala and 2006 Sienna also fired right up that afternoon, started them just to run them a bit. They were a little slow to crank but sounded fine on start.The Power steering on both wined a little but only for a few seconds. Both have Pennzoil Platinum 5w-30 in them.
Re: Has anyone had oil-related issues during the polar vortex? [Re: Gokhan] #4998638 02/01/19 04:45 PM
J
JC1 Offline
J
There will be more battery issues than oil issues unless you're running 20w-50 in these temps.
No oil issues for me.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Has anyone had oil-related issues during the polar vortex? [Re: Gokhan] #4998639 02/01/19 04:45 PM
SatinSilver Offline
Glad it's warming up to the 50's this weekend. What a difference a few days makes! No more bone chilling temps for a while I hope.
Re: Has anyone had oil-related issues during the polar vortex? [Re: PimTac] #4998650 02/01/19 05:02 PM
A
addyguy Offline
A
Originally Posted by PimTac
Originally Posted by addyguy
January 21st, overnight temp hit -28C, my Soul failed to start. It had started a couple of times at that temp before the 21st, but couldn't do it that day.
Now, mea culpa, it has M1EP 10W-30 in it, a nine-year old battery (original!), and was not plugged in.
Since then, have been plugging it in, but even with that, it struggles to start as we are still in -28C overnight temps.
Battery is obviously on its last legs, but can't change it now or change the oil, so we will see what happens.
Why can’t you change the battery?
Serious cash flow problem at the moment. Also reason oil wasn't changed for the winter...a move happened a lot sooner than I thought and $$ have been tied up in that.
I don't blame the car for not starting, it deserves better for that!
2010 Kia Soul 2U - 2.0L I-4, auto; 153k miles.
Castrol GTX 5W-20; Motomaster MPH 9688
2009 Pontiac G5 - 2.2 I-4, auto, 121k miles.
Oil/filter TBD
Re: Has anyone had oil-related issues during the polar vortex? [Re: Gokhan] #4998940 02/01/19 10:37 PM
T
TiredTrucker Offline
T
Well, my 2015 Chevy 2500 gasser pickup did just fine with the 10w30 syn blend that it gets. And my heavy commercial truck did just fine with the 10w30 HDEO syn blend that it gets. Both vehicles starting and running just fine at -20F and below. My commercial truck was in Minnesota, Wisconsin, Illinois, Iowa, and Indiana for all of this cold snap. Pickup was in Iowa the whole time. Wife used in several times to go to town during this cold snap. Did have to finally change out a fuel filter in the commercial truck this morning, but that was the extent of anything related to the cold.
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
Re: Has anyone had oil-related issues during the polar vortex? [Re: TiredTrucker] #4998982 02/01/19 11:22 PM
O
Online Content
O
You have them plugged in?
Re: Has anyone had oil-related issues during the polar vortex? [Re: Gokhan] #4998986 02/01/19 11:28 PM
U
Uphill_Both_Ways Offline
U
No problem each morning after temps of near ~ –40 overnight and dead block heater. This is the first time I'm running Mobil1 0W-30. For going on nine years it had been on a steady diet of Mobil 1 5W-30.
I didn't notice any difference. The engine sounded the same starting and running as it did in earlier years when I couldn't plug it in and with 5W-30 in it.
2008 Impala 3.5
Vanilla Mobil 1 0W-30
Napa Gold 1522 or Wix 51522
Re: Has anyone had oil-related issues during the polar vortex? [Re: Gokhan] #4998993 02/01/19 11:38 PM
A
Aero540T Offline
A
My 04 Grand Cherokee started very slowly even with a new battery but it was -22. It went into reverse fine but hesitated going into drive for a few seconds. Is that normal considering the conditions?
Once I was going it was fine and warmed up quickly
2004 Jeep Grand Cherokee Limited 4.7L (wife’s) PUP & FU
2002 Ford Taurus 24V M1HM & M1EP
2001 Dodge Ram 1500 5.9L 4x4 10w-30 RP & FU
1993 Yamaha FZR 600
Re: Has anyone had oil-related issues during the polar vortex? [Re: Gokhan] #4999011 02/01/19 11:56 PM
N
nyquil_junkie Offline
N
When I was a kid we always had a heated dipstick in the car or truck we had in the winter. I can remember the things would barely crank without them.
Somewhere along the line, we/I stopped using them and I don't remember why.... but starting was never a problem after that.
Now yesterday, at a balmy -25 windchill, I got in the ranger to start it and it was slow but started. The oil pressure took about 30 sec to move the needle. I let it run for a while to defrost the windows and off it went.
If this cold is going to be a new normal, I'll have to dig out one of those old heated dipsticks.
One of my sisters old ford vans way back when had a 1500w heater on the water hose... it was toasty warm heat and an easy start every morning and no waiting.
Winters musta been much colder back then.
