"Snake Oil" brand, snake oil!
by daves66nova - 12/05/19 11:58 PM
m1 TDT vs Rotella t6?
by Stickygreen - 12/05/19 11:09 PM
Not to beat a dead horse but...
by MoPowa - 12/05/19 10:22 PM
Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid
by FloridaTime - 12/05/19 09:55 PM
3 HP on a 15 Amp 120 v circuit
by Snagglefoot - 12/05/19 09:53 PM
SRT part 3 - 2020 Grand Cherokee SRT
by OVERKILL - 12/05/19 09:14 PM
My first new vehicle - first oil change
by Kurtatron - 12/05/19 09:02 PM
My wife made peanut butter fudge today(PIC)
by tig1 - 12/05/19 08:34 PM
07 Saturn Ion 2.0 L clutch replacement
by Nitronoise - 12/05/19 07:23 PM
Do You Prefer A 2 Cycle Or 4 Cycle Engine
by Warstud - 12/05/19 06:45 PM
Help with gift idea - Vacuum Sealer
by 92saturnsl2 - 12/05/19 05:49 PM
More news on the Ford Transmission Issues
by domer10 - 12/05/19 05:48 PM
Drain plug with nut welder to it. PIC
by tig1 - 12/05/19 05:29 PM
5 in 1 Rental Review
by panthermike - 12/05/19 05:25 PM
Engagement Ring Photos
by The Critic - 12/05/19 04:55 PM
Black Friday Oculus Go review
by PandaBear - 12/05/19 04:41 PM
Goodyear Wrangler buy-and a chuckle
by Lapham3 - 12/05/19 04:02 PM
2015 Mazda 3 2.0 - Intake Valve Pics
by buster - 12/05/19 03:54 PM
Timemaster had to get fixed...
by dareo - 12/05/19 03:44 PM
msf1344, Tank99, Ronparise, DrPcFix, benny88
70043 Registered Users
52 registered members (adams355, 14Accent, alcyon, 4WD, 928, 2 invisible), 1,466 guests, and 62 spiders.
Topics298,352
Posts5,133,576
Members70,043
Most Online3,589
Nov 2nd, 2019
Power steering fluid for 1994 E150? #4998772 02/01/19 06:08 PM
cadjak Offline OP
, Talk about conflicting information...The dealer, based on my vin number, said my power steering originally called for Mercon fluid. There is a lot of online info, supposedly from Ford, saying NOT to use Mercon V in applications previously requiring Mercon and not to mix them.
Then there was a 2007 Motorcraft announcement saying, "Effective July 1, the production and licensing for MERCON will cease. Automatic transmissions, power steering systems and manual transmissions previously requiring MERCON must, as of July 1, be serviced with MERCON V."
All I want to do is keep my great running van in the best shape possible, for as long as possible. I typically always stick with the manufacturers recommendations. Can anyone point me to a trustworthy source to help me come up with the best fluid to flush and replace my power steering fluid? I have no idea what I have in it now.
Thanks
Re: Power steering fluid for 1994 E150? [Re: cadjak] #4998786 02/01/19 06:18 PM
KJSmith Offline
My Father was born in Pecan Gap. (1929 IIRC)
What's the population there now?
Can't be double digits.
Try Mobil 1 tranny fluid.
https://mobiloil.com/en/automatic-transmission-fluid/synthetic-atf
I put it in my '02 F250.
Big difference.
Nice thing is that it mixes with most other fluids, no issues.
Re: Power steering fluid for 1994 E150? [Re: cadjak] #4998793 02/01/19 06:22 PM
B
bullwinkle Offline
B
I actually swapped out the Mercon in my MGM's PS system to Dexron VI, it helped with my cold, noisy PS pump action. The '93 E-350 box truck we used to have lost it's PS gearbox, we actually put Type F in it & it worked fine!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Power steering fluid for 1994 E150? [Re: cadjak] #4998795 02/01/19 06:23 PM
Q
qdeezie Offline
Q
For what it's worth, in my '06 F-150, I am using cheap Supertech Dexron/Mercon fluid. It works just fine and my truck calls for Mercon. Smooth and quiet and better than the gook that was in it when I bought the truck. Eventually I'll upgrade to a full synthetic, but for now I am happy.
'90 F150 XLT Lariat
'13 Hyundai Elantra Coupe SE
'03 Ford Focus ZX3
'06 F150 King Ranch
Re: Power steering fluid for 1994 E150? [Re: cadjak] #4998807 02/01/19 06:32 PM
CT8 Offline
Dexron III
Re: Power steering fluid for 1994 E150? [Re: cadjak] #4998850 02/01/19 07:14 PM
L
Linctex Offline
L
It REALLY doesn't matter.
Pretty much ANY hydraulic fluid or ATF will work just fine in your ol' Ford.
Some Asian cars are "fussy"...... your truck isn't.
Re: Power steering fluid for 1994 E150? [Re: cadjak] #4998857 02/01/19 08:10 PM
Chris142 Offline
When that van was made there was only dex3 / mercon or type f. Either will work fine.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Power steering fluid for 1994 E150? [Re: cadjak] #4998925 02/01/19 09:19 PM
slacktide_bitog Offline
Ford did revise the Mercon V some time to make it backwards-compatible with regular Mercon
In a power steering system, it probably matters much, much less, than it would for a transmission.
Also, Ford was still using Type F in some of their PS systems at the time
Re: Power steering fluid for 1994 E150? [Re: slacktide_bitog] #4998927 02/01/19 09:23 PM
Chris142 Offline
They used type F up into the 2000's! They must have had a bazillion barrels of type F they had to get rid of.
Re: Power steering fluid for 1994 E150? [Re: cadjak] #4999265 02/02/19 09:43 AM
T
tig1 Offline
T
I have used M1 ATF in all of my Ford PS pumps since about 1990. No failures to date.
2007 Ford Fusion 250,000 miles
M1 5-20HM
2017 Ford Fusion 83K
M1 0-20EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Power steering fluid for 1994 E150? [Re: Chris142] #4999277 02/02/19 09:56 AM
W
Whimsey Offline
W
My 1996 Contour specs type F for the power steering and that's what I still use.
Whimsey
Re: Power steering fluid for 1994 E150? [Re: cadjak] #4999318 02/02/19 10:18 AM
K
Kira Offline
K
The banishment of old Mercon and its replacement with MerconV was universal, no?
Re my friend's '97 F-150 we serviced the transmission and topped off the power steering fluid with MerconV. This was 5.5 years ago without any problems.
RELATED QUESTION: In cases such as this (vehicle close to 25 years old), does it make any sense to flush out the old fluid with new?
No biggie, just disconnect the return line to the PS reservoir and add fresh fluid while turning lock-to-lock.
Also, are there arguments for and against using a synthetic fluid?
Re: Power steering fluid for 1994 E150? [Re: cadjak] #4999366 02/02/19 10:56 AM
A
abycat Offline
A
ive always used type f in my older fords and never had a problem.
2017 dodge caravan gt
2011 nissan versa hb
Re: Power steering fluid for 1994 E150? [Re: cadjak] #4999691 02/02/19 04:57 PM
2
240_Ed Offline
2
I had the same difficulty finding good information on the correct fluid for my 240's power steering. The owner's manual just says to use 'ATF', and some online claim that certain cars had Dex III and others had Type F and using the wrong one will kill the seals, blah blah blah...in the end I gave up and went for fully synthetic Motul Multi ATF that meets a myriad of specs and it works like a dream.
However, in your application, it seems like you'd be best off finding a brand-name Mercon equivalent fluid and just using that. A reputable oil company will likely be producing it to specification even if Ford no longer officially licenses it, and since it's what your vehicle asks for, you won't be having any sleepless nights.
1992 Volvo 240 (B200F) - Castrol Edge 5w30, Mann W917 filter
2001 Volvo V70 (B5244S) - Shell Helix Ultra AF 5w30, Mann HU819X filter
Re: Power steering fluid for 1994 E150? [Re: cadjak] #5000943 02/04/19 06:35 AM
K
ka9mnx Offline
K
My 93 F150 calls for Type F in the OM. I used Mercon and the pump locked up (after a couple of years).
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
