1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
Hazet 600LG/8 Wrench set - $160
by drtyler - 02/25/20 01:34 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
26 registered members (Best F100, 53' Stude, Amenhotep, Aichiguy, Bjornviken, 5 invisible), 1,225 guests, and 18 spiders.
Topics301,933
Posts5,205,762
Members70,801
Glysantin G64 PSi-OAT #4997731 02/01/19 12:03 AM
F
FordCapriDriver Offline OP
F
I've been reading up a lot on coolants since about September, but i hadn't even come across this stuff before.
https://www.glysantin.de/en/glysantinr-g64r-concentrate
Glysantin call it a PSi-OAT , a.k.a, Phosphates + Silicates + OAT
Ph seems average for a typical OAT, between 7.5 - 8.5, but with a high reserve alkalinity ( 8-10 ) , apparently it's dyed dark green.
It seems like it's mostly meant for heavy duty diesels.
What do you think?
1975 Ford Capri II Ghia 3000 V6 - Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - Repsol Elite Super 20W-50
Re: Glysantin G64 PSi-OAT [Re: FordCapriDriver] #4998278 02/01/19 11:41 AM
N
nthach Offline
N
It's sold in the US as Zerex Original Green, but it also claims a 10/100K service life due to the OAT addition. I've used it before in a Nissan and I would use it in an application that uses old school green.
Re: Glysantin G64 PSi-OAT [Re: nthach] #4998478 02/01/19 01:49 PM
F
F
Really?? wow, it seems like a great coolant.
I use G40 which is very similar but pink and without phosphates in the place of conventional green in my two old Fords.
Re: Glysantin G64 PSi-OAT [Re: FordCapriDriver] #4998514 02/01/19 02:09 PM
N
nthach Offline
N
I stand corrected - it's a 5yr/100k coolant like Dex-Cool/G-05, but it's still an upgrade over conventional green while being compatible with it.
https://www.valvoline.com/our-products/antifreeze-products/zerex-original-green-antifreeze
Re: Glysantin G64 PSi-OAT [Re: FordCapriDriver] #4998525 02/01/19 02:15 PM
F
F
It sure is an upgrade.
Re: Glysantin G64 PSi-OAT [Re: FordCapriDriver] #4999329 02/02/19 10:25 AM
M
mightymousetech Offline
M
Interesting. Guess you can mix phosphated and silicated OAT?
Mighty Mouse Tech
BMW Diagnostic and Alignment Tech
2013 BMW 135i M Sport Edition Motul 0W40, MTL/MT-LV
2010 BMW 328i X-Drive, BMW 0W30, MT-LV
Re: Glysantin G64 PSi-OAT [Re: FordCapriDriver] #4999446 02/02/19 12:07 PM
P
pbm Offline
P
I always wondered how Zerex could claim 5yr/100K ability on a 'conventional' coolant....now I know...thanks nthach...
'Journalism is Dead'
Re: Glysantin G64 PSi-OAT [Re: mightymousetech] #4999542 02/02/19 02:18 PM
F
F
Phosphate and Silicate both being conventional inhibitors should not have any problems i guess mixing with eachother.
I'm going to research if i could possibly get some of this G64 here in Spain, the Phosphates should add some cavitation protection and improve cast iron corrosion.
Re: Glysantin G64 PSi-OAT [Re: FordCapriDriver] #4999553 02/02/19 02:31 PM
N
nthach Offline
N
Phosphates are there to quickly protect aluminum from what I understand - which is why the Japanese favor them and traditional green uses them. Silicates were more for ferrous metals. OATs do take a while to passivate and setup.
Re: Glysantin G64 PSi-OAT [Re: FordCapriDriver] #4999703 02/02/19 05:08 PM
M
M
Just mix Honda and BMW coolants. wink
Mighty Mouse Tech
Re: Glysantin G64 PSi-OAT [Re: nthach] #4999983 02/03/19 02:58 AM
F
F
Quite the opposite! , Silicates are by far the best corrosion inhibitor for Aluminium components.... everybody but the Japanese agrees on that, Phosphates are primarily used to inhibit Cast Iron corrosion, and also reduce cavitation.
Silicates started to be used in the 80s, when engines began using Alu cylinder heads, they found the traditional Phosphate, Borate, Azole etc formulations did not protect them well.
OAT coolants do take longer to activate, but they do not Passivate anything like Silicates or Azoles and Phosphates do, they only act wherever there is corrosion happening, if there is no corrosion occurring, they stay sort of "inactive"
Re: Glysantin G64 PSi-OAT [Re: FordCapriDriver] #4999985 02/03/19 03:04 AM
F
F
I don't have pictures right now to show you, but Years of using a Phsophate / Borate conventional coolant ( No silicate ) did quite some damage to my Ford Capri's water pump, thermostat housing and intake manifold ( all the aluminium components )
All were badly pitted and the coolant had literally eaten chunks out of them.
Now it has a new water pump, thermostat housing and i am using G40 Silicate OAT coolant in it.
Re: Glysantin G64 PSi-OAT [Re: FordCapriDriver] #5001243 02/04/19 12:42 PM
N
nthach Offline
N
Weird - the cooling system passages look pristine with Toyota phosphated coolant. I've seen pitting with everything else though.
Re: Glysantin G64 PSi-OAT [Re: FordCapriDriver] #5001690 02/04/19 11:49 PM
F
F
Coupled with an OAT inhibitor it probably does a perfectly good job, however a plain jane Phosphate / Borate conventional coolant doesn't do to well from personal experience with alu engine parts
Re: Glysantin G64 PSi-OAT [Re: FordCapriDriver] #5002013 02/05/19 12:43 PM
N
nthach Offline
N
Honda and Toyota are against the use of borates as they believe it causes pitting of Al components. An old Lexus I had used nothing but Toyota red coolant and when I pulled the water pump everything looked great.
Toyota had a sell sheet about why their coolant should always be used, I found one for Hino, same spiel: http://www.hino.com/assets/lt-0003-hino-coolant-2010.pdf
