New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Breaking in the new clutch. Backwards.
by Chris142 - 02/22/20 02:18 PM
Toyota 0W20 $2.95 + shipping YMMV
by Q451990 - 02/22/20 01:34 PM
Toyota Catalytic Converter (B2)
by MaximaGuy - 02/22/20 01:31 PM
The Camry lives!
by 53' Stude - 02/22/20 01:01 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
103 registered members (alchargo, 2009Caraman, ammolab, AC1DD, ArrestMeRedZ, 55hambone, 8 invisible), 2,102 guests, and 18 spiders.
Topics301,806
Posts5,203,080
Members70,784
Page 3 of 9 1 2 3 4 9
Re: Has anyone had oil-related issues during the polar vortex? [Re: Gokhan] #4997708 01/31/19 11:42 PM
G
Gasbuggy Offline
G
My Yukon did not want to idle smoothly when I started it at 5 degrees, real feel -3. PP10w30
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 Euro L
76 Mercedes 300D Rotella T4
Series III Land Rover VWB
02 Yukon 10w30 PP
01 P71 M1 EP-HM 0W20
95 Accord - 386k. Mobil 2 RIP
Re: Has anyone had oil-related issues during the polar vortex? [Re: Gokhan] #4997710 01/31/19 11:43 PM
Shannow Online Content
Online Content
I was a little concerned at the 5W40 in my Colorado at 40C after work (105F).
But I think I got away with it.
If it's the truth....it can handle the pressure !!!
Re: Has anyone had oil-related issues during the polar vortex? [Re: Shannow] #4997716 01/31/19 11:47 PM
B
bbhero Online Content
Online Content
B
Well that because you should have had a straight 40 grade in your Colorado LOL
Nissan Altima 3.5 Coupe
Cam2 SuperproMax 5w30 Carquest r84356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Has anyone had oil-related issues during the polar vortex? [Re: Gokhan] #4997736 02/01/19 12:08 AM
M
Michael_P Offline
M
Started my 97 F150 4.6 with 301,000 miles, original engine and transmission in -9F. The engine (M1 0W30), trans (Amsoil ATF) and diff (Amsoil Severe Gear 75W140) were fine but the power steering sounded like a mashed cat for the first 20 seconds. Later that day, I vac'd out the reservoir and the lines leading to the power steering pump. I replaced it with Super Tech low viscosity ATF. The next morning it was -5F, but no power steering noises.
Re: Has anyone had oil-related issues during the polar vortex? [Re: Gokhan] #4997747 02/01/19 12:57 AM
csandste Online Content
Online Content
Remember running straight 10 weight in a 53 Mercury flat head in the mid sixties. South Dakota cold! Then I'd stick in STP when it got warm.
2017 Kia Soul Plus-- Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Re: Has anyone had oil-related issues during the polar vortex? [Re: Michael_P] #4997752 02/01/19 01:09 AM
Online Content
That's seriously an issue of undermaintenance in so many vehicles on the road.
Re: Has anyone had oil-related issues during the polar vortex? [Re: Gokhan] #4997758 02/01/19 01:27 AM
G
Gokhan Offline OP
G
That's probably a PS fluid leak. When it gets cold, the PS fluid level drops even more, causing screeching sounds. Unfortunately, I have the same problem. Perhaps, you can find out where the leak is and fix it. Or keep checking the level of the PS fluid.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 4,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: Has anyone had oil-related issues during the polar vortex? [Re: Gokhan] #4997763 02/01/19 01:35 AM
Online Content
No, I've had it here in Oz, on cold mornings no lower than -7C...with a perfectly fine oil level, on multiple cars as the fluid ages.
Two of the three pumps failed not very long (a year) after it started...but the problem went away after a reservoir change and a short drive.
I'm pretty sire that the poster would have known if he was running of oil.
Re: Has anyone had oil-related issues during the polar vortex? [Re: Gokhan] #4997767 02/01/19 01:57 AM
G
Gokhan Offline OP
G
Well, it could be (1) a PS fluid that is in a really bad shape, (2) leaks in the system, or (3) a low PS fluid level. It was (3) in may case and it happened in cold days and cold starts. Interestingly, the PS fluid was never changed in my car in 34 years -- it would definitely be good to change it though but it's a messy job with the hoses in all the unreachable places and I don't want to do it.
Re: Has anyone had oil-related issues during the polar vortex? [Re: Gokhan] #4997768 02/01/19 02:10 AM
F
FT92 Offline
F
minus 6 this morning and the 99 accord started like it was a 80 degree day running 5-30 napa oil which I believe is vavoline the ford focus the same no problems at all
Re: Has anyone had oil-related issues during the polar vortex? [Re: Gokhan] #4997771 02/01/19 02:35 AM
Online Content
Don't you think the poster, having a leak and running out of fluid would have attributed the noise to THAT not the ambient and old fluid ?
Re: Has anyone had oil-related issues during the polar vortex? [Re: Shannow] #4997776 02/01/19 03:06 AM
G
Gokhan Offline OP
G
You had already made that point.
Re: Has anyone had oil-related issues during the polar vortex? [Re: Gokhan] #4997782 02/01/19 03:45 AM
Online Content
And having initially (incorrectly) asserted it you re stated it in points 2), and 3) of your potentials for what he experienced.
Re: Has anyone had oil-related issues during the polar vortex? [Re: Gokhan] #4997804 02/01/19 05:04 AM
G
Garak Offline
G
Has anyone had any oil-related issues during the polar vortex, like difficulty cranking? A 5W-30 probably can take -30 °F but don't you wish you were running 0W-xx?
I've been fine, although our winter has oddly enough been better than most who got hit with this lately. In any case, I've had no problems with a 5w-XX for as long as I've been driving, and only did a 0w-XX a few times. I might have noted before that anecdotally, the 5w-30 HDEO seems to crank a little more readily than the 5w-40 HDEO, but that's not a huge difference nor unexpected.
Plain, simple Garak.
Re: Has anyone had oil-related issues during the polar vortex? [Re: Snagglefoot] #4997806 02/01/19 05:06 AM
G
Garak Offline
G
Snagglefoot, that's the Pennzoil 0w-30 Caterham was recommending I try in the G37 when that oil first came out. It certainly was and is worthy of consideration, and would meet my specifications, but back then, one litre bottles only were available, and that, particularly from CT, does not a cheap oil change make. wink
