Originally Posted by zorobabel
Thanks for stopping by grampi.
Does your VC gasket not leak?
I've always imagined you fixed/replaced your odometer.
My car hasn't leaked a drop of anything the whole time I've had it. Never replaced odometer, I now keep track of my mileage with the trip meter...
I see you stayed frugal.
This Corolla (my wife's car) never leaked a drop on the ground either, in fact most of the oil pan is dry. But oil was seeping from the tensioner O-ring and VC gasket, starting to make a mess (I didn't want my bitog card voided).
Is the VC gasket area dry on yours? I would be surprised, since the gasket I took out was brittle. My original plan was to open the valve cover, take pics, run Rislone for 5k, open valve cover again, observe results and replace the gasket; but the old gasket was too brittle, so I abandoned the plan.
Yes, mine is completely dry...
