A friend of mine has a theory that, if two cars has the same gearbox, and one has as relatively more powerful engine , there would be less need to downshift under load or during acceleration. So This could theoritically save automatic gearbox.
From the experience i know that, if engine doesn"t produce enough power, i have to shift so frequently in order to avoid high RPM and lugging engine.
Since manual transmissions are very reliable, it shouldn"t be a problem.
But how about automatic transmissions ? How frequent shifting affect their life ?
