For the Tremec T56 6-speeds found in the Camaro's, Firebird's and Corvettes, the manuals say use Dexron3 atf, even though it's a manual transmission. I don't know about you all, but mine shifts like crap and it doesn't shift at all when it's cold. I'm considering using one of the following: amsoil synthetic atf, redline hi-temp atf or redline MTL.
I've used Redline D4atf in my 99 camaro 6-speed. It shifted great when it was cold, but during the summer when the car was hot it felt like the d4atf was too thin. When shifting when it was hot the transmission would sort of bang when you shifted into the next gear, like the syncros weren't getting the gears to the same rpm before engaging. Don't get me wrong, the thing shifted good and all and I never had any problems, but I honestly think the d4atf was, too thin for a lack of a better word. I was reading the redline website and either their hi-temp atf or MTL look ideal. I'm a little hesitant about amsoil because it has the same viscosity of the d4atf at 100C, about 7.5. The redline hi-temp atf and MTL are 10.0 at 100C, and even though their viscosities at lower temps are higher than the d4atf, I would hope they would give at least some better shiftability during cold weather than the factory fill dexron3 atf.
The only thing I'm worried about is the Dexron3 requirement stated in the manual. Do I abolutely need to use dexron IIE or dexronIII atf? The redline hitemp atf meets dexron3, but the MTL according to the redline literature seems better suited but it doesn't meet dexron3. After all the T56 = manual syncromesh tranny = MTL = manual trans. lube. So why use an atf in a manual tranny. Would there be any compatibility issues using the MTL even though it's not dexron3 compliant? And what is the definition behind dexron3 does anybody know? And has anybody used either amsoil or redline mtl in both cold and hot weather with success?
