Best Nubuck protector/waterproof
er
by PW01 - 09/20/19 04:14 AM
Aircraft Tempest Spin-EZ AA-48108-2
by Capt - 09/19/19 11:22 PM
Emission Readiness monitors
by bowlofturtle - 09/19/19 10:12 PM
Thoughts on the GM strike?
by Vern_in_IL - 09/19/19 09:37 PM
tropical storm imelda blows up everynight?
by motor_oil_madman - 09/19/19 09:12 PM
2017 Corvette / Mobil 1 ESP 0w40 / 5.2k mi
by dparm - 09/19/19 08:57 PM
2019 Lexus UX 250h
by Direct_Rejection - 09/19/19 08:56 PM
Gas theft
by tahoe_hybrid - 09/19/19 08:04 PM
Aisin 09G transmission fluid?
by sloinker - 09/19/19 07:44 PM
Oil for 2005 BMW X3
by Nyquist - 09/19/19 07:34 PM
Golden Eagles Take Down Deer and Wolves
by buster - 09/19/19 07:31 PM
P21S Windshield Washer Booster
by mclasser - 09/19/19 06:30 PM
Why warm up oil before a UOA sample is taken?
by paulri - 09/19/19 06:21 PM
Selling the 97 Camry V6 again
by PandaBear - 09/19/19 05:15 PM
FRAM Orange Cans
by KevGuy - 09/19/19 05:13 PM
Colt Ceases Civilian AR-15 Production
by billt460 - 09/19/19 04:50 PM
Amsoil “synthetic technology”
by spiderbypass - 09/19/19 03:15 PM
Srfridd, V1313, Ecan89, ProBest, Zolton
69333 Registered Users
41 registered members (billt460, bbhero, ATex7239, CB900F2, crosspug, Char Baby, 5 invisible), 638 guests, and 22 spiders.
Topics294,802
Posts5,066,914
Members69,333
Most Online3,532
Jul 30th, 2019
Page 1 of 7 1 2 7
The inner workings of a 6R140 transmission #4995976 01/30/19 06:07 PM
M
mattd Offline OP
M
Thought I’d share my most recent work project . I have done several of these transmissions with the same issue. 3-4 upshift slip or flare between shifts. Here are some disassembly pics. Enjoy.
2E91F680-A4C0-4D9D-BD38-DAEF59C7E1CA.jpeg8D9BB816-80D5-4C0B-90E2-B72A8AB34100.jpeg63CB7863-BC37-4674-BCA2-CFE4A964E1BD.jpegF90CEF48-0A16-44FD-809C-FF323C265193.jpegAA030A30-9A67-43B4-AC36-945CB628096B.jpeg5F7DCA1E-3E46-43B8-AEB7-9132ADA07BC1.jpegC707A9F8-62C7-468B-8365-0712861412B2.jpeg
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1
Re: The inner workings of a 6R140 transmission [Re: mattd] #4995979 01/30/19 06:09 PM
M
mattd Offline OP
M
A few more. Assembly pictures will follow once parts come in
75F90BDA-8889-44CA-B0B6-4552BAC4AA19.jpeg9D7E9469-FB89-4C06-859F-2570DCB84923.jpegC39E5DAD-8E66-45C4-ABA0-CEE9D6FE122A.jpeg7811BBC4-0819-4C1B-98B7-48BF48680F69.jpegE4B3F09B-7FCD-4D16-9D95-0CBC0D7B48B1.jpeg
ASE Master, L1
Re: The inner workings of a 6R140 transmission [Re: mattd] #4995990 01/30/19 06:18 PM
SubieRubyRoo Offline
That transmission was way to clean to have failed. I think you're pulling our legs. LOL
Dang, those clutch disks are shot! What's the root cause and fix?
Re: The inner workings of a 6R140 transmission [Re: mattd] #4996002 01/30/19 06:26 PM
N
nthach Offline
N
It doesn't look as complicated as I thought but those clutches are thin!
Re: The inner workings of a 6R140 transmission [Re: mattd] #4996003 01/30/19 06:28 PM
P
PandaBear Offline
P
Clutch worn out? or glazed?
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: The inner workings of a 6R140 transmission [Re: PandaBear] #4996036 01/30/19 06:55 PM
M
mattd Offline OP
M
Worn down to the metal zero friction material left on half of the friction plates in that set. Forward, direct, and low/reverse were worn beyond maximum limits and the overdrive was worn 5 times max limit. I am very impressed how well the TCM adapted to the wear. This particular clutch (overdrive) has too little surface area compared the others in the transmission. There is an aftemarket clutch drum that has 50% more holding power from increased clutch count but requires a billet intermediate shaft and billet input shaft (which also acts as overdrive drum) to a tune of 1500$. Not a reasonable cost for a municipality. This truck is a F450 rescue with a 6.7 powerstroke. Just over 100k miles. It’s gstting a full overhaul. There are several updated hard parts too ford has made over the years.
This transmission is not bad to rebuild. Some special tools are required specific to this unit. They are also heavy 325lbs dry. The input assembly alone all together weighs 80 lbs . Its 4 pic up from bottom on the left.
ASE Master, L1
Re: The inner workings of a 6R140 transmission [Re: mattd] #4996051 01/30/19 07:08 PM
MolaKule Offline
Global Moderator
Global Moderator
What are you finding as the main problems?
I am working with an AT shop near here developing a rebuild ATF. The MERCON® LV fluid doesn't seem to have the FM longevity needed for 150,000 mile OCI's.
In addition, while the dual filter system removes particulates, the quick lockup feature of the TCC on upshifts shears the fluid pretty fast.
The value of a scientific theory is its ability to prompt further study, not that it has any relation to the established facts of scientific reality.
Re: The inner workings of a 6R140 transmission [Re: mattd] #4996074 01/30/19 07:20 PM
CT8 Offline
Thanks for the pics were those trannies in a gas or diesel engine? the trans in huge !
2015 F150 2.7
2018 F350 6.2
Re: The inner workings of a 6R140 transmission [Re: CT8] #4996120 01/30/19 07:45 PM
M
mattd Offline OP
M
This is a diesel application. However the physical size between gas and diesel are the same but internally some differences. It has 6 forward ratios and a torque input capacity of 1400 lb ft.
Molakule, you are correct. In this application 150k miles is far too much for the fluid. The trans made it barely 2/3 of the way there. Ford now sells a friction modifier called XL16 and recommends using it after an overhaul. The torque converter clutch is used far more than the previous generations of the torqshift and can definitely contribute to shear. These transmissions are also designed to operate at around 200*F fluid temperature. The main issue I feel with this transmission is the overdrive clutch surface area. It was also designed with a molded rubber piston and all the other clutch sets use a solid aluminum piston with lip seals.
I’ll try to have some more detailed pics of the individual components when I reassemble it.
ASE Master, L1
Re: The inner workings of a 6R140 transmission [Re: CT8] #4996134 01/30/19 07:49 PM
bdcardinal Offline
Both gas and diesel.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: The inner workings of a 6R140 transmission [Re: mattd] #4996159 01/30/19 08:04 PM
MolaKule Offline
Global Moderator
Global Moderator
...Molakule, you are correct. In this application 150k miles is far too much for the fluid. The trans made it barely 2/3 of the way there. Ford now sells a friction modifier called XL16 and recommends using it after an overhaul. The torque converter clutch is used far more than the previous generations of the torqshift and can definitely contribute to shear. These transmissions are also designed to operate at around 200*F fluid temperature. The main issue I feel with this transmission is the overdrive clutch surface area. It was also designed with a molded rubber piston and all the other clutch sets use a solid aluminum piston with lip seals...
Thanks for the info. The shop is very hesitant to use an MoDTC amide additive since this is an organo-metallic FM and we don't feel this is going to fix any problems.
Re: The inner workings of a 6R140 transmission [Re: bdcardinal] #4996160 01/30/19 08:04 PM
CT8 Offline
Is your shop seeing many of the 60R140 trans with problems? I am a fluid and filter changer when the unit is new then sooner than later after the break in oil change
2015 F150 2.7
2018 F350 6.2
Re: The inner workings of a 6R140 transmission [Re: CT8] #4996169 01/30/19 08:10 PM
M
mattd Offline OP
M
Right around 100k miles they start to develop issues. The 450s tend to show up faster than the 350s. My only guess is due to weight. Keep in mind a majority of the trucks I see have very hard miles. Constant run time with lots of city driving with hills. This particular truck has 17000 engine hours with just over 100k road miles. By the hours it’s approximately 560,000 engine miles.
ASE Master, L1
Re: The inner workings of a 6R140 transmission [Re: mattd] #4996186 01/30/19 08:24 PM
X
xxch4osxx Offline
X
Has this transmission ever been serviced through out the time it was in service? I would have thought that they would have at least one fluid and filter change in that amount of miles due to the severe operating environment they are used in.
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
Re: The inner workings of a 6R140 transmission [Re: xxch4osxx] #4996307 01/30/19 09:50 PM
M
mattd Offline OP
M
No it has not. It makes too much sense to do that. The person that is in charge of the department does not believe in routine fluid changes (other than engine oil). I have convinced him otherwise as this is the 7th transmission failure in 2 years in rescue fleet alone.
ASE Master, L1
Page 1 of 7 1 2 7
