95 registered members (Al, alienyouth33, 2004tdigls, 1foxracing, Alfred_B, 13 invisible),
1,521
guests, and 51
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics284,600
Posts4,873,164
Members67,298
Most Online2,548 Feb 16th, 2019
Re: The inner workings of a 6R140 transmission
[Re: CT8]
#4996957
01/31/19 12:21 PM
01/31/19 12:21 PM
Posts: 11,803 Santa Barbara, CA
bdcardinal
Santa Barbara, CA
Thanks for the pics were those trannies in a gas or diesel engine? the trans in huge ! Both gas and diesel. Is your shop seeing many of the 60R140 trans with problems? I am a fluid and filter changer when the unit is new then sooner than later after the break in oil change None that I have seen. But we generally don't repair something like OP does, they just have us put in a new/reman assembly.
2014 Ford Mustang GT Track Pack 1995 Ford Mustang GT
Ford/Mazda Parts Counter NRA Benefactor Member Opinions expressed are my own.
[Re: mattd]
#4997105
01/31/19 01:57 PM
01/31/19 01:57 PM
Posts: 2,747 Cedarbrae, Ontario
xxch4osxx
Cedarbrae, Ontario
No it has not. It makes too much sense to do that. The person that is in charge of the department does not believe in routine fluid changes (other than engine oil). I have convinced him otherwise as this is the 7th transmission failure in 2 years in rescue fleet alone. Not really surprising. They think they are saving money buy not doing proper preventitive maintenance till something grenades and ends up costing them big bucks. I can imagine these transmissions are not cheap to rebuild and the downtime of not having the vehicle in service can be detrimental for an emergency services outfit. It is good to know you have convinced them otherwise!
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
[Re: SubieRubyRoo]
#4998708
02/01/19 05:19 PM
02/01/19 05:19 PM
Posts: 768 RI
mattd
OP
OP
RI
Most of the parts came in still waiting on a half dozen things or so
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1
[Re: CT8]
#5002470
02/05/19 08:53 PM
02/05/19 08:53 PM
Posts: 768 RI
mattd
OP
OP
RI
A few parts still on back order and waiting for some selective snap rings to adjust clutch clearance but here is a few more for now
ASE Master, L1
[Re: mattd]
#5002478
02/05/19 08:57 PM
02/05/19 08:57 PM
Posts: 768 RI
mattd
OP
OP
RI
And last round till I get some more parts
ASE Master, L1
[Re: mattd]
#5002488
02/05/19 09:08 PM
02/05/19 09:08 PM
Posts: 387 MD
claluja
MD
Great info - thanks for posting. Will be ordering another filter and Mercon LV tomorrow for my 6R140W, based on the comments above. Has 155K, but haven't replaced filter or drained since 75K.
2014 F250 6.7L PSD 2006 Sequoia 4.7L 2005 E500 5.0L 2018 Jeep Rubicon, Pentastar 3.6L
[Re: claluja]
#5002603
02/06/19 05:13 AM
02/06/19 05:13 AM
Posts: 768 RI
mattd
OP
OP
RI
Definitely do so. These are not the cheapest units to rebuild. Due to the service the trucks I work on see I convinced the boss that to do a drain and fill once a year on all the trucks.
What year is your truck?
ASE Master, L1
[Re: mattd]
#5002610
02/06/19 05:27 AM
02/06/19 05:27 AM
Posts: 387 MD
claluja
MD
What year is your truck? 2014 F250 6.7 (20-30% of the miles towing 14K). Thanks for the advice!
[Re: claluja]
#5002640
02/06/19 06:20 AM
02/06/19 06:20 AM
Posts: 768 RI
mattd
OP
OP
RI
The 14s have most but not all the updated hard parts so if you ever have to have it rebuilt not too many updates other than replacing worn parts
When it starts to show issues it will usually start flaring shifting from 3-4 so just watch for that.
Is the truck tuned/deleted?
ASE Master, L1
[Re: mattd]
#5002658
02/06/19 06:49 AM
02/06/19 06:49 AM
Posts: 387 MD
claluja
MD
Is the truck tuned/deleted? Yes, deleted about 11K ago. Tow tune slight HP increase. Thanks again!
