Exactly, it will not decrease, But it does not go up with time as fast if you increase filtration media surface area. A known factor is that with use filters become more efficient, this gain is reduced with a larger filter, inversely a larger filter can be run longer without becoming restrictive.
Originally Posted by Gokhan
Originally Posted by Bryanccfshr
Primarily the purpose of doing this is Additional oil capacity. Filtration efficiency goes down, flow goes up all things being equal. In the past (2002-4 timeframe)for example I have run an oversized filter on that 3.4 Toyota engine you have. The Motorcraft FLS400. No damage occurred, but today having a better grasp, I would just run the recommended filter size.
Originally Posted by ka9mnx
Originally Posted by ZeeOSix
What's your main goal for running an over sized filter?
Add me to that question. I thought the filter on my 4Runner was a bit small but after seeing the engineering that went into this vehicle, I'll trust the engineers.
Hmm, ZeeOSix says the filtration efficiency does not go down when the filter size increases.
