Some people you just shouldn't listen to, go to ram forum and talk with h395 using redline towing his family and trailer up the ikeman and using temp guns to monitor temps, as he reported over time live on the forum, using redline c+. He did have to pull over, but only to let his engine oil cool, his diffs and transmsions were outstanding. I forget, he might even of had Amsoil in the diffs. There are plenty of reason someone should consider redline in transmsion, too many to list, and all legitimate, and everytime it will be met with a joke of a rebutal here. I mean to question ester content in an application that is heat sensitive is utterly laughable. Only thing funnyier then that is my spelling. No reason to debate reasons here when you have people that act similar to CNN and their fake news. Just a bunch of fake rebuttals by people who don't even care about the science of pao/esters. Research that stuff elsewhere like machinelbe, you just wont get good info here, sad to say. Maybe in 2006 you would have, but no longer do these "oil guys" talk about high quality oils, they prefer spec hunting as a sport.
Anyhow, what you need to tell us is the transmsion, then we can say more Most Chrysler transmisions really need clean fluid, maybe even more the a redline type product, depending on it's use and what it's towing. The sump filter is synthetic and can easily last 100k miles plus, but the spin on is paper. The good news is the spin on leads into sump filter, so skipping the spin on is less dangerous then otherwise. If you have a moderate duty 545te transmsion, you should get a drain bolt pan or use a 20 dollar pump from amazon and do quick flushes of a gallon or ore everytime you change your engine oil. If you have an application that gets hot, consider redline c+, if not, consider doing a series of flushes because you are on borrowed time. The transmsion is a weak spot, any atf 4 would do, just do it often.
