I have a 97 F150 4x4 with 83000 miles on it and just changed the front diff oil for the first time. It was a light gray in color, does this mean anything? I put in Castrol 75w90, GL5. This is a nice amber color. Any thoughts? TIA.
Axles are always neglected...bulletin out now at the big three if you don't do regular diff drain and fills NO warranty work will be coveredquote:
Originally posted by Steve S:
If there is a big worry about a problem with the component send the the oil to an oil analysis company if you have it. Then share the results with us. Now I will get on my soap box and preach . Changing all the fluids in your vehicles on a regular schedule ,See the factory manual, will be one of the best things that can be done to get the longest life out of your vehicle. The oil is old and there is condensation and front differentials in 4 by 4's have lots of thrust bering loads on them when steering.
I doubt that the grey color comes from normal wear. I think it is an additive.quote:
Originally posted by metroplex:
The metal particles that come from normal wear are mixed in with the oil giving it that blackish/greyish color.
When the ring and pinion break-in and establish their contact pattern the metal that was removed from them goes somewhere...changing the fluid with-in the first few thousand miles makes a big difference down the road in axle life...I've changed some pretty nasty looking gear oil in my 30 or so years doing itquote:
I changed the rear fluid on a 12 bolt chevy ss camaro that had gone 10 years and 180k miles and it came out about the same as the black tar that is used to patch the roads with. Actually came out like cold tar.quote:
i'll have to agree. i've probably changed 100 gear sets, 90% of them in fords. the earlier ones had clear gear lube, even with 100k miles. around '96, they started getting a thick, charcoal, murky looking lube.quote:
Doesn't your wife like the smell of sulfer?Boy she wouldn't like the aroma of our moose campquote:
Originally posted by Ron:
I just changed the diff factory fill on my 99 E-150 at 25K with no towing/abuse. Put in Sta-Lube Syn-Go 75w-140 plus Trans-X FM. The soup I pumped out was metalic charcoal grey, and a sludge was on the magnet fill plug.The odd thing was the odor of the Sta-Lube oil made my wife sick to her stomach!I had to air seal the rest in another container! She was not happy and thought the stuff would smell up the van!The stuff does sorta stink.Beware guys, the wife may take offense.
Ron
