Originally Posted by dblshock
Check the cost of a 4.6 starter replacement and they do go.
Not sure why that matters--same engine family, so the starter should be in the same place for both of them.
Originally Posted by Zee09
Seems the 4.6 runs 3.91 cogs and the 5.7 runs 4.30
Yes, but... The 4.6 with the tow package came with 4.10's in the pumpkins. Which I strongly recommend. I took my truck out for a spin today, and with cruise set to 70mph it was kicking out of 6th on many hills on the relatively flat 101 highway in NH. I wasn't that impressed (nor when it was hunting!).
I would very much not recommend the crewmax with 4.6 and no tow package! Might as well leave the trans in 5th gear. Which is what I do if I know I'm not going past 55mph or so--it just can't handle any hills at that speed.
Been a while but IIRC the 4.6 is a lower deck height, and as such, bolt-ons like headers don't work. Just pointing that out, in case anyone wants to hot-rod one.
Oh, and something else. The transmissions in at least the Tundra are slightly different. 1st, 2nd and I think 3rd are different--4 and up are the same gear ratios. Takeoff ratio winds up about the same between them, but technically the 4.6 gets a deeper 3.52:1 1st (as opposed to 3.33). I recall seeing the 2014 brochure and it looked like the 4.6 was getting the 5.7 trans--which means it would be more of a dog off the line. I don't know if that was a typo or not. But in 2014 my model truck went from like 7,900lb towing to 6,500lb. Makes me wonder if I really have 7,900 or not now--not that it matters, I wound up never towing with mine, but it's yet another consideration.
Just do the 5.7.
