Carquest oil and filter deal.
by JTK - 01/23/20 07:35 PM
Anti seize vs silicone paste
by buck91 - 01/23/20 06:57 PM
UOA - 11 VW GTI 2.0T TSI - Purol 10w40 - 5k
by dubman - 01/23/20 06:33 PM
Old SG/CD Mopar Vintage oil useless?
by BBDartCA - 01/23/20 06:32 PM
Great Slave Lake
by 53' Stude - 01/23/20 04:57 PM
Went used car shopping today. So interesting
by WhyMe - 01/23/20 04:33 PM
Wix 51269 I think cut open
by Mightymouse - 01/23/20 04:08 PM
What oil for a new VW Beetle?
by widetrax - 01/23/20 03:52 PM
Lossless audio music
by Cujet - 01/23/20 03:38 PM
Castrol Edge on Rollback at Walmart
by Matt1980 - 01/23/20 03:35 PM
Regretted Selling a Car?
by RDY4WAR - 01/23/20 02:14 PM
3 American Volunteers lost in Oz fires....
by Shannow - 01/23/20 02:13 PM
Need a tire pressure gauge
by nomas - 01/23/20 02:11 PM
Why Waffle Sipes - but very little depth
by Cressida - 01/23/20 02:05 PM
Personal finance book in Spanish
by czbrian - 01/23/20 01:03 PM
SQL Basics?
by tom slick - 01/23/20 11:08 AM
Unused PRO-TEC 101 oil filter cut open / Wix 51515
by rollinpete - 01/23/20 10:32 AM
1997 Civic Ignition Module & Coil Replacement?
by njohnson - 01/23/20 09:38 AM
Sirius radio Issues
by Boomer - 01/23/20 09:09 AM
Mailman1995, DougCFL, Sayafi, SeanSkiVT, 02COBRA
70512 Registered Users
122 registered members (53' Stude, 2002 Maxima SE, 2003f7, 4WD, 2010Civic, 55hambone, 12 invisible), 1,920 guests, and 19 spiders.
Topics300,474
Posts5,176,716
Members70,512
Page 2 of 2 1 2
Re: 4R70W transmission overheating / failed cooler bypass valve? [Re: VeryNoisyPoet] #4992334 01/27/19 10:44 AM
V
VeryNoisyPoet Offline OP
V
Repair successful!
Removed old thermostat and used two stubs of flex hose to bypass it, then drained and filled pan with fresh fluid. Unhooked return line at cooler and started engine to flush out cooler circuit. Plenty of flow through coolers and pushed a few more quarts of fresh ATF into system in the process. Next I installed a Derale 13011 fluid control thermostat up front and rerouted the lines. Had to cut one of the hard lines, so used a flare tool to make a lip to prevent the hose from slipping off and double clamped it to be sure. Transmission cooling system works properly, and the truck shifts like new, so I can drive it with confidence again.
Considering adding an external transmission filter, especially with all the crud I saw coming out of the coolers when I flushed them. Probably will do one more fluid drain and fill, but maybe in a few weeks time.
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: 4R70W transmission overheating / failed cooler bypass valve? [Re: VeryNoisyPoet] #4992358 01/27/19 11:03 AM
T
Trav Offline
T
Nice! Good fix.
Page 2 of 2 1 2
