Vehicle Insurance Goes Down Again
by BlueOvalFitter. 07/22/19 05:20 PM
2003 Dodge Caravan front brakes
by Oldtom. 07/22/19 04:52 PM
TPMS Sensors for a 2012 Highlander
by Tundragod. 07/22/19 04:43 PM
No one has posted the C8 interior yet?
by wensteph. 07/22/19 04:42 PM
Discard veggies from homemade veggie broth? Really?
by Ed_Flecko. 07/22/19 04:37 PM
Water spot remover
by Redright9. 07/22/19 03:40 PM
Optimal oil temp?
by gfh77665. 07/22/19 03:08 PM
Westlake Tires
by bunnspecial. 07/22/19 03:04 PM
Quick struts
by t1snwrbrdr12. 07/22/19 02:55 PM
Mechanic in Green Bay, WI?
by Y_K. 07/22/19 02:48 PM
Tub Advice
by coopns. 07/22/19 02:08 PM
9688 the one size fits all for asian cars?
by jayjr1105. 07/22/19 01:20 PM
Does Edge 0w20 contain moly? Any recent voa’s?
by Stickygreen. 07/22/19 01:15 PM
QSUD 0W20 vs. 5W20 ?
by ChrisD46. 07/22/19 01:14 PM
fat tire bikes, benefit?
by 1978elcamino. 07/22/19 12:37 PM
Whole House A/C stopped cooling Trane XE1000
by Vikas. 07/22/19 12:06 PM
Pongo23, brantdw, dgwilkes, Barb, Cromwell
68735 Registered Users
121 registered members (97tbird, 53' Stude, 4WD, 2015_PSD, 01rangerxl, AandPDan, 12 invisible), 2,343 guests, and 23 spiders.
Topics292,247
Posts5,019,642
Members68,735
Most Online2,967
Mar 10th, 2019
Craftsman/Kohler Riding Mower Runs & Blows Fuse #4991778
01/26/19 08:03 PM
01/26/19 08:03 PM
northern Alabama
benjamming Offline OP
northern Alabama
2000 Craftsman mower model 917.271131 with a Kohler Command PRO 16.5HP OHV model CV16S-43527 spec #43527 Family YKHXS.4262GB 426cc engine.
Will start right up & runs but then dies <1 minute with a blown 15A fuse. Thoughts on what's going wrong? Schematic is on page 16 of this PDF.
Re: Craftsman/Kohler Riding Mower Runs & Blows Fuse [Re: benjamming] #4991804
01/26/19 08:24 PM
01/26/19 08:24 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
short somewhere? its 19 years old probably a wire frayed or bad switch?
Is that with the deck running or not.. had a JD with a bad electronic PTO that was melting wiring/fuses.
Re: Craftsman/Kohler Riding Mower Runs & Blows Fuse [Re: benjamming] #4991806
01/26/19 08:26 PM
01/26/19 08:26 PM
Georgia
MParr Offline
MParr  Offline
Georgia
Just guessing, look for a chafed wire, check for a loose ground wire or bad electrical connection. There is some short somewhere.
2019 VW Tiguan SE Now: Factory fill & OEM filter
2017 Ford Escape SE 2.0T Now: NAPA Synthetic 5W30 & NAPA Gold 1348
Re: Craftsman/Kohler Riding Mower Runs & Blows Fuse [Re: benjamming] #4991825
01/26/19 08:39 PM
01/26/19 08:39 PM
OH
Woodster Offline
Woodster  Offline
OH
Yessir--as said, run down each wire that you can find. Gotta be a ground out/short somewhere.
Look especially at the items grounded to the chassis, or look at "screw on" type metal bezels connecting ignitiion switch, solenoids, etc--they may be making bad or intermittent grounds blowing the fuse.
Page 32 schematic doesn't look to complicated--trace each wire.
Re: Craftsman/Kohler Riding Mower Runs & Blows Fuse [Re: benjamming] #4991871
01/26/19 09:35 PM
01/26/19 09:35 PM
northern Alabama
northern Alabama
That is without the deck running.
I don't know why I said page 16; was thinking page 31 - getting old!
The weird thing is that this issue didn't happen one week and now it is.
I was hoping for a bad solenoid or switch but that doesn't seem to make sense; after all it starts and runs!
Re: Craftsman/Kohler Riding Mower Runs & Blows Fuse [Re: benjamming] #4992134
01/27/19 07:52 AM
01/27/19 07:52 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Since it happens after it runs for a short time, I do not suspect a dead short to ground from a chaffed wire which would blow the fuse immediately. Myself, after tracing the circuit, I would be looking at the components in the charging system, especially the regulator.
The "thinking" man's friend.
Re: Craftsman/Kohler Riding Mower Runs & Blows Fuse [Re: benjamming] #4993274
01/28/19 08:18 AM
01/28/19 08:18 AM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
Try unplugging the kill wire from the coil. There also is a kill switch in the carburetor (anti-backfire switch). I believe, although I'm not a small engine guy, that the engine should run indefinitely with these bypassed. I have seen some engines that are ground to run, though.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Craftsman/Kohler Riding Mower Runs & Blows Fuse [Re: benjamming] #4995212
01/29/19 11:28 PM
01/29/19 11:28 PM
Texas, United states
Jmoney7269 Offline
Jmoney7269  Offline
As a small engine mechanic I have seen this several times....
Most of the time it was due to a faulty regulator or a shorted stator under the engine flywheel.
Also as mentioned earlier hold your hand on the carburetor anti backfire solenoid and if it gets hot, replace it..... because it shouldn't. I have seen this several times to be the culprit also
Good bbq ain't cheap and cheap bbq ain't good!
Re: Craftsman/Kohler Riding Mower Runs & Blows Fuse [Re: Jmoney7269] #4995603
01/30/19 12:12 PM
01/30/19 12:12 PM
Buffalo, NY
JTK Online content
JTK  Online Content
Buffalo, NY
For sure on this.
I had one that somehow was working, but was shorting to the point that it electrified the whole carburetor and was making the thin wire throttle return spring glow red hot. This was on a cheap Chinese replacement carb on my Craftsman rider 18hp Briggs engine.
2017 Ram 1500 4x4, 3.6L.
2016 Nissan Quest SV (Babe magnet IV)
2015 Nissan Versa 1.6 S
Re: Craftsman/Kohler Riding Mower Runs & Blows Fuse [Re: benjamming] #5004298
02/07/19 07:53 PM
02/07/19 07:53 PM
Florida
gotnogunk Offline
gotnogunk  Offline
Florida
I had the same thing on a craftsman B&S. I just dried it with electric cleaner and used steel wool. I thought it was from when I sprayed it off.
2018 Cadillac XTS 3.6
2014 Ford F150 3.7 supercrew
Re: Craftsman/Kohler Riding Mower Runs & Blows Fuse [Re: benjamming] #5015064
02/18/19 11:41 AM
02/18/19 11:41 AM
northern Alabama
northern Alabama
Found the original root cause - battery was connected backwards & tried to start not knowing the problem. I guess that would mean it's the regulator???
Re: Craftsman/Kohler Riding Mower Runs & Blows Fuse [Re: benjamming] #5019292
02/21/19 05:32 PM
02/21/19 05:32 PM
Cape Cod, MA
RF Overlord Offline
RF Overlord  Offline
Cape Cod, MA
I'm confused...how would the engine even start if the battery was connected backwards?
Supercharged '03 Mercury Marauder - Trilogy Motorsports #61
PP 5W-30 / MC FL820S
'04 Grand Marquis LS Limited Edition - MC 5W-20 / FL820S
'00 Grand Marquis GS - being resurrected. Slowly.
Re: Craftsman/Kohler Riding Mower Runs & Blows Fuse [Re: benjamming] #5019303
02/21/19 05:39 PM
02/21/19 05:39 PM
northern Alabama
northern Alabama
It wouldn't. The issue was found & rectified. Then I came in & tried to start with the above issue.
