AME 37330 Hub Cleaner for Impact Wrench
by The Critic - 11/18/19 01:54 AM
Plastic bag vs Car
by The Critic - 11/18/19 01:50 AM
Fram XG7317 20k miles cut open
by dbeau - 11/17/19 09:46 PM
2021 Ford Mach-E Electric SUV
by KeithS_NW_Ohio - 11/17/19 09:05 PM
Walker mower Oil
by Joey737 - 11/17/19 09:03 PM
Rough service tough light bulb 1¢ at Home Depot
by JLawrence08648 - 11/17/19 08:40 PM
2015 F150 5.0 8592 miles
by Buzzinhalfdozen - 11/17/19 08:36 PM
MOPAR MO-285 FACTORY OIL FILTER CUT OPEN
by 53' Stude - 11/17/19 07:43 PM
Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
Grumpy Kid
by wings&wheels - 11/17/19 01:57 PM
h9/95R FLA Batteries
by TXCarGeek - 11/17/19 01:40 PM
Preventative parking brake service
by Donald - 11/17/19 01:26 PM
JimBobSeeker, Joey737, bdavis218, XTR74, 2009Caraman
69899 Registered Users
31 registered members (ctechbob, CharlieBauer, 53' Stude, dervdave, carlprop, 2 invisible), 577 guests, and 16 spiders.
Topics297,569
Posts5,118,204
Members69,899
Most Online3,589
Nov 2nd, 2019
Page 1 of 3 1 2 3
New Bridgestone Blizzak WS90 #4987556 01/22/19 12:59 PM
SubLGT Offline OP
https://www.tirereview.com/bridgestone-introduces-new-winter-passenger-tire/
https://www.moderntiredealer.com/news/732751/bridgestone-introduces-the-blizzak-ws90-winter-tire
Quote
Based on dealer feedback, the Blizzak WS90 has also been engineered to be more durable. With a 30% more block stiffness in its tread pattern, the company says drivers can expect to get an extra winter season out of the new design when compared to its predecessor, the WS80.
Re: New Bridgestone Blizzak WS90 [Re: SubLGT] #4987604 01/22/19 01:36 PM
E
edyvw Offline
E
Considering WS80 lateral ice performance, not surprising they replaced it so fast.
Edit: Design looks like DM-V2.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
Re: New Bridgestone Blizzak WS90 [Re: SubLGT] #4987694 01/22/19 02:56 PM
U
UG_Passat Offline
U
[Linked Image]
Looks like there is less siping density in the new one.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: New Bridgestone Blizzak WS90 [Re: SubLGT] #4987717 01/22/19 03:17 PM
K
KGMtech Offline
K
I have the WS80's on my Maxima, these new versions should be well established when I need to re-tire.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: New Bridgestone Blizzak WS90 [Re: SubLGT] #4987748 01/22/19 04:09 PM
SubLGT Offline OP
Re: New Bridgestone Blizzak WS90 [Re: SubLGT] #4987769 01/22/19 04:28 PM
SubLGT Offline OP
Hey Michelin, wake up hornets
Will you ever come out with a successor to the "aged" Xi3?
You have this "advanced rubber compound" in your new studded tire that has a glass transition temperature of -85f ! Sounds perfect for a XIce Xi4.
Re: New Bridgestone Blizzak WS90 [Re: SubLGT] #4987913 01/22/19 06:58 PM
U
UG_Passat Offline
U
Not to mention, Michelin has a dual layer technology also, from the Alpin 6.
Re: New Bridgestone Blizzak WS90 [Re: SubLGT] #4987939 01/22/19 07:37 PM
SOHCman Offline
Would this compound still last 40k like the xi3?
I urge people not to wait 100K to change out the fluid in their transfer case units. -Kestas
Re: New Bridgestone Blizzak WS90 [Re: SubLGT] #4987964 01/22/19 08:10 PM
Snagglefoot Offline
Has anyone tried the new Blizzak LT ?
If you want the job done right......do it yourself.
Re: New Bridgestone Blizzak WS90 [Re: SubLGT] #4988154 01/23/19 05:24 AM
E
edyvw Offline
E
Question is whether they need to?
Xi3 has full winter compound unlike Blizzak and proved to be better rounded tire. I think WS90 is an attempt to bite into market of Xi3.
I had DM-V2 on X5 which is same generation as WS80, and than Xi2, and although Xi2 is generation older than DM-V2, it proved better than DM-V2, especially in ice, dry and wet. Longevity is actually not comparable.
I am afraid that Bridgestone is hardening tread block for longevity while still keeping dual compound. That harder tread, what effect will it have in ice and snow?
Re: New Bridgestone Blizzak WS90 [Re: SubLGT] #4988155 01/23/19 05:25 AM
E
edyvw Offline
E
OK< it does not look like DM-V2, I thought by looking at it on that car it did.
Re: New Bridgestone Blizzak WS90 [Re: edyvw] #4988305 01/23/19 09:07 AM
SubLGT Offline OP
Question is whether they need to?....
The Xi3 is lagging behind its competitors in ice traction and slush planing resistance, at the very least. In the 2015 "NAF Test" (performed at the professional tire testing facility Test World in Finland) the Xi3 ranked in 2nd place overall. Fast forward to 2018, and it ranked only 7th place overall.
The 2018 NAF summary comments from NAF for the Xi3 (translated from Norwegian by Google):
Quote
Very poor results on snow and ice.
Especially the side grip is poor, it steers inexperienced and is understaffed.
The impression changes sharply on asphalt, and especially in the wet, where the tire - both objectively and subjectively - is second best.
Quiet and stable under these conditions.
Here are the 2018 NAF comments about the WS80:
Quote
Best result of everyone in the important moment braking on dry asphalt.
Also very good driving feel on the dry road.
Among the better stud-free tires during braking on snow and ice. Quiet and stable behavior with predictable understeer.
Decent on noise.
Here are the 2018 NAF comments about the Nokian R3
Quote
Close behind the very best on snow and ice. Stable and good steering feeling.
Among the best in wet conditions, but below average for the studless on dry surfaces.
The driving feeling is safe and predictable regardless of the surface.
Pleasant low noise level.
https://www.naf.no/forbrukertester/dekktester/vinterdekktest-2018/
http://www.testworld.fi
Re: New Bridgestone Blizzak WS90 [Re: SubLGT] #4989142 01/24/19 06:04 AM
E
edyvw Offline
E
Quote
Quote
Decent on noise.
Quote
Sure, but I am talking from buyers perspective. Also, I know Michelin will have very similar performance next winter, not so sure about Nokian based on these R2's I have.
Slushing is an issue for Xi3, due to packed design. But we are talking here about lower 48 states. How much time one spends constantly driving on snow, ice and in slush? That is the issue, the compromise between dry, wet roads that drivers drive on most of the time, and occasional snow storms. Even I who spends a lot of time on the slopes, like good balanced tire that has good behavior in all conditions. I went yesterday over Loveland Pass at 11,500ft during snow storm with my Xi2 on Toyota and cannot say they are any less confident in it than R2, WS70, LM60, DM-V2 I used over that same pass on different vehicles.
What is clear is that wearing of Xi2 (which I was very skeptical about as Overkill knows) is not noticeable after some 5000 miles this winter and that they behave like good A/S tire in dry and wet, which cannot be said for R2, and something that WS70 and DM-V2 struggled with.
In the end, WS90 is introduced even per Bridgestone testimony to increase life, but question is whether there will be drop in performance.
Re: New Bridgestone Blizzak WS90 [Re: SubLGT] #4991443 01/26/19 12:40 PM
SubLGT Offline OP
https://www.caranddriver.com/features/a26038430/bridgestone-blizzak-ws90-tire-drive/
Quote
Both on its own and against the Michelin X-Ice Xi3 and Continental WinterContact SI, both of which outscored the WS80 in our last winter-tire test, the WS90 proved to be a serious snowshoe. All of the tires on our drive were fitted to similar front-wheel-drive Toyota Camry sedans. Through a handful of choreographed exercises, the new WS90 backed up Bridgestone's claim of superior ice grip, both in acceleration and braking, by besting the Michelin over a zero-to-10-mph-to-zero sprint on an inactive ice-skating rink. And on the groomed-snow tracks of Bridgestone's Winter Driving School—now in its 35th year in Steamboat Springs—the latest Blizzak exhibited a reassuringly strong turn-in bite into corners on packed snow, as well as a confidence-inspiring level of stability and feedback as we gently drifted around the school's higher-speed handling course.
Unusually poor weather conditions limited our track time and prevented us from experiencing the new tire on the street, but the WS90 showed none of the sudden-breakaway behavior at the limit that we've noted of its WS80 predecessor—which still remains an excellent winter-weather ally. Bridgestone's directional WS90 is a fitting evolution, and we're anxious to expose it to a more thorough barrage of real-world conditions on at least one of our long-term vehicles next winter.
Re: New Bridgestone Blizzak WS90 [Re: SubLGT] #4991680 01/26/19 05:15 PM
E
edyvw Offline
E
Quote
This is main reason for such quick update to WS80. WS90 will still lack longevity of Xi3, but this was seriously apparent on my DM-V2 which is same generation as WS80. Also, in talk to my skier friends that use(d) WS80, they were seriously disappointed with them compared to previous generation of WS models.
Page 1 of 3 1 2 3
