What would you like to do in the future?
by Red91. 07/20/19 12:45 PM
Pulling timing for high IAT
by LAGA. 07/20/19 11:55 AM
I think I messed up. How badly?
by JohnG. 07/20/19 11:19 AM
[Cut Open] Volkswagen 04E 115 561 H (Virgin)
by DuckRyder. 07/20/19 10:51 AM
PARTS PLUS PH 500 CUT OPEN
by 53' Stude. 07/20/19 10:32 AM
MOBIL 1 M1-108A CUT OPEN
by 53' Stude. 07/20/19 10:25 AM
Mac Pro -- Keep Killing Keyboards
by ET16. 07/20/19 10:23 AM
Air filters with foam facing?
by Dave1027. 07/20/19 09:31 AM
Run em or replace
by faltic. 07/20/19 08:49 AM
Low NOACK oils
by 53' Stude. 07/20/19 08:35 AM
Weird brakes on 1996 Buick
by 007. 07/20/19 08:18 AM
What oil does a Chevy dealer use
by tblt44. 07/20/19 08:09 AM
Cool info on the Corvette
by mcrn. 07/20/19 05:55 AM
Your preferred syn or conv oil
by NavyVet88. 07/20/19 05:03 AM
Bruce Crower Passes
by 02SE. 07/20/19 12:30 AM
Toyota YZZA1 Filter, 9,958mls
by edyvw. 07/20/19 12:06 AM
Chevron Supreme 5w30 Noack?
by Whammo. 07/19/19 11:56 PM
Injector sleeves in 7.3 Powerstroke w/ 6 sp MT
by Earls1st. 07/19/19 11:32 PM
Bonebender, Stonehunter, ctwhitechin, gwandless, Philippe1988
68713 Registered Users
82 registered members (379KITTY, aquariuscsm, 2003f7, atikovi, Audios, 8 invisible), 2,447 guests, and 27 spiders.
Topics292,139
Posts5,017,553
Members68,713
Most Online2,967
Mar 10th, 2019
Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary #4990773
01/25/19 07:38 PM
01/25/19 07:38 PM
Florida
Artem Offline OP
Artem  Offline OP
Florida
Slowly racking up the miles on the oil while monitoring wear and oil condition to determine the best interval for this freakin Rotary engine.
Only 4 quarts drain out during an oil change. Total sump capacity is 7 quarts, so 3 quarts of old oil remain and instantly contaminate the new oil... it sucks, but what can you do?
Thinking of just calling it quits @ 1,500 mile OCIs. My cost per 4 quart drain n fill = under $10 and takes 5 minutes. Seems like a no brainer since my goal is to try to keep this thing spinning happily for as long as possible. Thoughts?
Code
OIL             Pennzoil yellow bottle 10w40
MILES IN USE    1,621 miles
MILES on unit   140,970
SAMPLE TAKEN    12/12/2018
Make up Oil     1qt
ALUMINUM        2
CHROMIUM        9
IRON            14
COPPER          1
LEAD            3
TIN             0
MOLYBDENUM      127
NICKEL          0
MANGANESE       0
SILVER          0
TITANIUM        0
POTASSIUM       2
BORON           68
SILICON         3
SODIUM          25
CALCIUM         1677
MAGNESIUM       21
PHOSPHORUS      575
ZINC            683
BARIUM          0
SUS VIS 210�F   63.5
cSt @ 212�F     11.20
FLASHPOINT �F   395
Fuel %          <0.5
Antifreeze       0.0
WATER            0.0
INSOLUBLES       0.1
TBN
TAN
OilReports.aspx-4.jpgfull-38453-22470-fullsizerender_7.jpgfull-38453-22468-img_8945.png
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: Artem] #4990800
01/25/19 08:08 PM
01/25/19 08:08 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Maybe try switching oils? Since you’re using a 40-grade conventional (because wankel), what about trying a 15W-40 conventional HDEO? Something like Delo. Still cheap, comes in gallon jugs (handy for your 4 quart drain), and has far more antiwear additives.
2019 Tesla Model 3 SR+
2016 Countryman S: Castrol 0W-40
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: Artem] #4990811
01/25/19 08:20 PM
01/25/19 08:20 PM
PA
Gasbuggy Offline
Gasbuggy  Offline
PA
Man, don't see many of those on the road anymore, fun to drive. I'm guessing it's had a rebuild by now. What did Mazda call for a change interval? What killed alot of these cars were owners not staying on top of the typical rotary oil consumption.
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 Euro L
76 Mercedes 300D Rotella T4
Series III Land Rover VWB
02 Yukon 10w30 PP
01 P71 M1 EP-HM 0W20
95 Accord - 386k. Mobil 2 RIP
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: 1JZ_E46] #4990904
01/25/19 09:58 PM
01/25/19 09:58 PM
Florida
Artem Offline OP
Artem  Offline OP
Florida
I plan on trying something else during the summer. I'm already stressing with the 10w40 during cold starts when winter shows it's true colors in Florida (30-40F in the morning), I can't imagine starting this thing with a 15w40 during winter. Haha.
Factory spec for the US is 5w20. Coupled with natural fuel dilution from the ever rich running Rotary and I'm not surprised so many of these engines died early lives. There's just not enough lube to keep the apex seals from rubbing away.
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: Gasbuggy] #4990906
01/25/19 10:00 PM
01/25/19 10:00 PM
Florida
Artem Offline OP
Artem  Offline OP
Florida
I'm not sure what the factory interval is. Never bothered to check but i'm sure it's 5-7,500 miles. No way I'd ever run it that long. This engine just isn't made to be economic. It's designed to give driving thrills unlike any other.
Yea I barely see them as well and always turn heads when I'm driving it.
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: Artem] #4990919
01/25/19 10:12 PM
01/25/19 10:12 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Totally understand. I know they say synthetic is “bad bad bad” for rotaries, but is that really the case or just leftover wisdom from the early days of rotaries and synthetics? What about a 5W-40 synthetic blend or full syn?
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: Artem] #4990941
01/25/19 10:36 PM
01/25/19 10:36 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
When I had mine, I had one with the Rotary Aviation kit that feeds the oil injectors straight TCW3 oil instead of engine oil. Went a long way toward reducing sump consumption and wear. I premixed TCW3 into the gas before then.
Unless there is a good reason why not, I'd premix if I were you. Since you're doing very short OCIs, there is little fear of mechanical shearing. I'd run something like a 5w-40. Maybe a Euro oil instead of HDEO. I know life is rough for rotary catalysts.
BTW, the worry for synthetic has always been that low quality synthetic leaves more deposits than conventional. This is not true of high grade synthetic, but everyone dodges the issue as much as possible.
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: Artem] #4990980
01/25/19 11:15 PM
01/25/19 11:15 PM
Yellowbrick Rd(KS)SemiRetired
Marco620 Offline
Marco620  Offline
You want some consumption as to why I think the 13B only recommended dino oil for seals. Keep doing what you do. Just buy a Fram Ultra or M1 oil filter and change it every 15k. Nice car too.
15' Civic 1.8 i-vtec 254,000 mi Redline 5/0w20, BP transmax cvt fluid & Archoil9100
Tornado Chaser Extraordinar!
Son of a Navy Corpsman. Support vets!
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: 1JZ_E46] #4991428
01/26/19 01:20 PM
01/26/19 01:20 PM
Florida
Artem Offline OP
Artem  Offline OP
Florida
Those who run a stand-alone oil injection setup happily run synthetic oil, since it obviously protects better and can withstand the abuse better.
The going belief is that since synthetic resists breakdown, and it needs to BURN in the combustion chamber, it will leave behind deposits and carbon will eventually ruin the engine, although the rest of it will be perfect. Lol.
Since conventional is weaker, the idea is that it will burn off cleaner.
I’d gladly run a separate oil injection tank but they are expensive and this isn’t exactly a perfect example of an RX-8 to go all out and modify to perfection. It’s a beater for me... although a nice and unique one at that. Plus I like experimenting with it. I think it should last a long time with such short OCIs. Clean oil is basically always being sprayed on the apex seals.
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: DoubleWasp] #4991431
01/26/19 01:24 PM
01/26/19 01:24 PM
Florida
Artem Offline OP
Artem  Offline OP
Florida
Well said. I premix the fuel always with Idimitsu Rotary specific Lube. The series 1 RX-8 needs it the most, since it only has 2 oil injectors instead of 3 like it’s suppose too. (Thanks Mazda)
Many Rotary shops recommend splitting it down the middle and run a synth blend. I’d do that once my huge stash of conventional is used up by this beast. I got a ton of it on clearance just for the RX-8.
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: Marco620] #4991433
01/26/19 01:27 PM
01/26/19 01:27 PM
Florida
Artem Offline OP
Artem  Offline OP
Florida
Currently using the OEM series one RX-8 specific oil filter. I kept the last one going for like 5-6k miles although the oil was changed like 7 times during that interval (600 mile OCIs)
I agree with your idea though since that would make the most sense. No point in dumping a perfectly good oil filter.
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: Artem] #4991512
01/26/19 03:20 PM
01/26/19 03:20 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
If you want to stick with conventional then I think your current regiment is fine. If anything the OCIs are a little too short. Perhaps run PYB 5W-30 in the winter and 10W-40 in the summer.
Or another consideration is to run a conventional 10W-30 HDEO year round. Those are closer to a 40-weight than PYB 5W-30. HTHS is around 3.5... maybe a tad higher.
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: DoubleWasp] #4992000
01/27/19 12:51 AM
01/27/19 12:51 AM
Fort Worth
Pinoak Offline
Pinoak  Offline
Fort Worth
I thought there reason for not using synthetic is because the rotary engine is supposed to burn oil by design and synthetic dosent burn as well??
Anyway I had An Rx7 back In the day. Long before the 8 and it was just too problematic although it could beat the mustangs and Camaros all day long.
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: 1JZ_E46] #4992007
01/27/19 01:28 AM
01/27/19 01:28 AM
Florida
Artem Offline OP
Artem  Offline OP
Florida
I agree that the OCIs are ridiculously short and I can probably run 2-3k with a stronger synthetic blend but for now, I’m fine with 1,500 mile spill n fill. Like I’ve stated, 3 quarts remain in the system during an oil change.
Now if an OC was replacing say... 6.5qt of the 7qt capacity, that would be a different story.
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: Pinoak] #4992010
01/27/19 01:31 AM
01/27/19 01:31 AM
Florida
Artem Offline OP
Artem  Offline OP
Florida
That is the reason. Synthetic is stronger and resists burning, so it’s not ideal as a 2 stroke oil that needs to burn off CLEANLY.
I’m sure this is 2005 talk and today’s SN spec oil are pretty much the same, regardless if it’s conventional or synthetic. I’d rather not experiment with my engine.
