Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
Hazet 600LG/8 Wrench set - $160
by drtyler - 02/25/20 01:34 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
40 registered members (Artem, bbhero, BlakeB, blufeb95, Brian553, 2009Caraman, 4 invisible), 1,399 guests, and 14 spiders.
Topics301,931
Posts5,205,720
Members70,801
Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary #4990773 01/25/19 06:38 PM
A
Artem Online Content OP
OP Online Content
A
Slowly racking up the miles on the oil while monitoring wear and oil condition to determine the best interval for this freakin Rotary engine.
Only 4 quarts drain out during an oil change. Total sump capacity is 7 quarts, so 3 quarts of old oil remain and instantly contaminate the new oil... it sucks, but what can you do?
Thinking of just calling it quits @ 1,500 mile OCIs. My cost per 4 quart drain n fill = under $10 and takes 5 minutes. Seems like a no brainer since my goal is to try to keep this thing spinning happily for as long as possible. Thoughts?
Code
OIL             Pennzoil yellow bottle 10w40
MILES IN USE    1,621 miles
MILES on unit   140,970
SAMPLE TAKEN    12/12/2018
Make up Oil     1qt
ALUMINUM        2
CHROMIUM        9
IRON            14
COPPER          1
LEAD            3
TIN             0
MOLYBDENUM      127
NICKEL          0
MANGANESE       0
SILVER          0
TITANIUM        0
POTASSIUM       2
BORON           68
SILICON         3
SODIUM          25
CALCIUM         1677
MAGNESIUM       21
PHOSPHORUS      575
ZINC            683
BARIUM          0
SUS VIS 210�F   63.5
cSt @ 212�F     11.20
FLASHPOINT �F   395
Fuel %          <0.5
Antifreeze       0.0
WATER            0.0
INSOLUBLES       0.1
TBN
TAN
OilReports.aspx-4.jpgfull-38453-22470-fullsizerender_7.jpgfull-38453-22468-img_8945.png
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: Artem] #4990800 01/25/19 07:08 PM
1
1JZ_E46 Offline
1
Maybe try switching oils? Since you’re using a 40-grade conventional (because wankel), what about trying a 15W-40 conventional HDEO? Something like Delo. Still cheap, comes in gallon jugs (handy for your 4 quart drain), and has far more antiwear additives.
2019 Tesla Model 3 SR+
2016 Countryman S: Castrol 0W-40
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: Artem] #4990811 01/25/19 07:20 PM
G
Gasbuggy Offline
G
Man, don't see many of those on the road anymore, fun to drive. I'm guessing it's had a rebuild by now. What did Mazda call for a change interval? What killed alot of these cars were owners not staying on top of the typical rotary oil consumption.
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 Euro L
76 Mercedes 300D Rotella T4
Series III Land Rover VWB
02 Yukon 10w30 PP
01 P71 M1 EP-HM 0W20
95 Accord - 386k. Mobil 2 RIP
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: 1JZ_E46] #4990904 01/25/19 08:58 PM
A
OP Online Content
A
I plan on trying something else during the summer. I'm already stressing with the 10w40 during cold starts when winter shows it's true colors in Florida (30-40F in the morning), I can't imagine starting this thing with a 15w40 during winter. Haha.
Factory spec for the US is 5w20. Coupled with natural fuel dilution from the ever rich running Rotary and I'm not surprised so many of these engines died early lives. There's just not enough lube to keep the apex seals from rubbing away.
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: Gasbuggy] #4990906 01/25/19 09:00 PM
A
OP Online Content
A
I'm not sure what the factory interval is. Never bothered to check but i'm sure it's 5-7,500 miles. No way I'd ever run it that long. This engine just isn't made to be economic. It's designed to give driving thrills unlike any other.
Yea I barely see them as well and always turn heads when I'm driving it.
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: Artem] #4990919 01/25/19 09:12 PM
1
1JZ_E46 Offline
1
Totally understand. I know they say synthetic is “bad bad bad” for rotaries, but is that really the case or just leftover wisdom from the early days of rotaries and synthetics? What about a 5W-40 synthetic blend or full syn?
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: Artem] #4990941 01/25/19 09:36 PM
DoubleWasp Offline
When I had mine, I had one with the Rotary Aviation kit that feeds the oil injectors straight TCW3 oil instead of engine oil. Went a long way toward reducing sump consumption and wear. I premixed TCW3 into the gas before then.
Unless there is a good reason why not, I'd premix if I were you. Since you're doing very short OCIs, there is little fear of mechanical shearing. I'd run something like a 5w-40. Maybe a Euro oil instead of HDEO. I know life is rough for rotary catalysts.
BTW, the worry for synthetic has always been that low quality synthetic leaves more deposits than conventional. This is not true of high grade synthetic, but everyone dodges the issue as much as possible.
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: Artem] #4990980 01/25/19 10:15 PM
Marco620 Offline
You want some consumption as to why I think the 13B only recommended dino oil for seals. Keep doing what you do. Just buy a Fram Ultra or M1 oil filter and change it every 15k. Nice car too.
15' Civic 1.8 i-vtec 311,000 mi M1 0w30 & LG Biotech, BP CVT Fluid,GUMOUT W/ PEA
Doberman Whisperer!
E pluribus unum.
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: 1JZ_E46] #4991428 01/26/19 12:20 PM
A
OP Online Content
A
Those who run a stand-alone oil injection setup happily run synthetic oil, since it obviously protects better and can withstand the abuse better.
The going belief is that since synthetic resists breakdown, and it needs to BURN in the combustion chamber, it will leave behind deposits and carbon will eventually ruin the engine, although the rest of it will be perfect. Lol.
Since conventional is weaker, the idea is that it will burn off cleaner.
I’d gladly run a separate oil injection tank but they are expensive and this isn’t exactly a perfect example of an RX-8 to go all out and modify to perfection. It’s a beater for me... although a nice and unique one at that. Plus I like experimenting with it. I think it should last a long time with such short OCIs. Clean oil is basically always being sprayed on the apex seals.
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: DoubleWasp] #4991431 01/26/19 12:24 PM
A
OP Online Content
A
Well said. I premix the fuel always with Idimitsu Rotary specific Lube. The series 1 RX-8 needs it the most, since it only has 2 oil injectors instead of 3 like it’s suppose too. (Thanks Mazda)
Many Rotary shops recommend splitting it down the middle and run a synth blend. I’d do that once my huge stash of conventional is used up by this beast. I got a ton of it on clearance just for the RX-8.
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: Marco620] #4991433 01/26/19 12:27 PM
A
OP Online Content
A
Currently using the OEM series one RX-8 specific oil filter. I kept the last one going for like 5-6k miles although the oil was changed like 7 times during that interval (600 mile OCIs)
I agree with your idea though since that would make the most sense. No point in dumping a perfectly good oil filter.
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: Artem] #4991512 01/26/19 02:20 PM
1
1JZ_E46 Offline
1
If you want to stick with conventional then I think your current regiment is fine. If anything the OCIs are a little too short. Perhaps run PYB 5W-30 in the winter and 10W-40 in the summer.
Or another consideration is to run a conventional 10W-30 HDEO year round. Those are closer to a 40-weight than PYB 5W-30. HTHS is around 3.5... maybe a tad higher.
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: DoubleWasp] #4992000 01/26/19 11:51 PM
P
Pinoak Offline
P
I thought there reason for not using synthetic is because the rotary engine is supposed to burn oil by design and synthetic dosent burn as well??
Anyway I had An Rx7 back In the day. Long before the 8 and it was just too problematic although it could beat the mustangs and Camaros all day long.
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: 1JZ_E46] #4992007 01/27/19 12:28 AM
A
OP Online Content
A
I agree that the OCIs are ridiculously short and I can probably run 2-3k with a stronger synthetic blend but for now, I’m fine with 1,500 mile spill n fill. Like I’ve stated, 3 quarts remain in the system during an oil change.
Now if an OC was replacing say... 6.5qt of the 7qt capacity, that would be a different story.
Re: Pennzoil 10w40 - 1,621mi - 04 Mazda RX-8 Rotary [Re: Pinoak] #4992010 01/27/19 12:31 AM
A
OP Online Content
A
That is the reason. Synthetic is stronger and resists burning, so it’s not ideal as a 2 stroke oil that needs to burn off CLEANLY.
I’m sure this is 2005 talk and today’s SN spec oil are pretty much the same, regardless if it’s conventional or synthetic. I’d rather not experiment with my engine.
