Follow up to my Hyundai/Kia Theta II multiple call campaigns, thread.
wemay
Site Donor 2023
Everglades
Member, JustinH commented...
Originally Posted by JustinH
There were some major changes with this ECU update, I would recommend it.
The throttle response has changed totally, especially light throttle. The sonata base is not a sports car, but the tune is dramatically better than the factory tune.
The best way I can explain it is the factory tune would lag when you would hit the gas, then rev high and not go anywhere.
With the re-calibration the car has no lag, actually somewhat fun to drive.
I bet they fattened up the mixture to keep the engine from pinging as well.
I wish I could find an article from a tuner to see what was actually done.
The true test will be next week when it gets a tank of 87 shell.
 I experienced the exact same thing with the Sportage 2.4L. When i went back to the dealer to purchase accessories i shared this info with the tech. he said that's normal, the Tech also told me not to worry if i wanted to still run 5W-20, it is perfectly fine and will cause no issues.I wonder if the oil pump change after the 2015 MY plus this ecu update are the reasons why.
How much can a tune actually change in this situation?
Was at dealership to make appointment for my Elantra and had a good service advisor. He was easy to talk to. Talked about Theta II and GDI. He said they replaced 500 engines and are still trying to figure it out. Hopefully this current campaign will have lasting positive effects.
