Shell Rotella Gas Truck 0W-20, 9349 miles FCA 2.4
by austinlunsford - 11/19/19 06:53 PM
06' V6 Accord 12,462 miles Penzoil Platinum 0W20
by Daschicken - 11/19/19 04:57 PM
Pride Asian Plus Coolant-thoughts?
by N Heat - 11/19/19 04:21 PM
Should it really take this long?
by IronMaidenRules - 11/19/19 02:21 PM
Does Ford use Hall Effect sensor for the APPS?
by LoneRanger - 11/19/19 02:09 PM
Brake Calipers for my 74 Corvette
by Alwyn678 - 11/19/19 01:32 PM
My Neighbor's 320,000 Mile Saturn
by CrackyWainwright - 11/19/19 01:14 PM
2012 GMC Terrain 3.0L V6 P0300
by benjamming - 11/19/19 12:51 PM
Mustang 4r70w atf recommendation
by Hansvoytek - 11/19/19 12:18 PM
PRO TEC PTL 57502 CUT OPEN
by 53' Stude - 11/19/19 12:08 PM
Federal rebates?
by buck91 - 11/19/19 12:07 PM
Bosch fuel pump quality
by drtyler - 11/19/19 11:28 AM
Standard Motor Products
by Whimsey - 11/19/19 11:25 AM
Delo SynBlend 15w40 - $11.45
by Greg L - 11/19/19 11:17 AM
VIRGIN STP 8316 CUT OPEN
by 53' Stude - 11/19/19 11:00 AM
FPPF: Polar Power & Total Power
by BigJohn - 11/19/19 10:40 AM
Cubez007, dshadow, Hansvoytek, DeltaP71, 300Kncounting
69918 Registered Users
119 registered members (928, 4WD, 01rangerxl, Aero540T, 2009Caraman, 1978elcamino, 9 invisible), 1,989 guests, and 21 spiders.
Topics297,647
Posts5,119,959
Members69,918
Most Online3,589
Nov 2nd, 2019
Page 2 of 3 1 2 3
Re: more PSD woes with cold weather [Re: dbias] #4988343 01/23/19 09:52 AM
R
racin4ds Offline
R
Originally Posted by dbias
Could it be Sticktion? In extreme cold sometimes the oil used for the injectors gets sticky. Try archoil it helped my fords with hydraulic injection.
This new PSD does not use HEUI injection, its common rail. Ford dropped HEUI injection after 2007MY mostly.
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: more PSD woes with cold weather [Re: Donald] #4988587 01/23/19 01:42 PM
Donald Offline OP
Its 31 today and truck finally ran properly. But now I am not sure what to do if it gets down to 0F again. Talked to Power Service people and they said I could add another 8 oz of the white container product. They said 911 is alcohol based also.
2015 Ford F250 w/Powerstroke
Re: more PSD woes with cold weather [Re: Donald] #4988602 01/23/19 01:55 PM
M
meep Offline
M
shrinking HPOP o-ring? is yours in the family susceptible to that problem?
2018 F150
2015 crv (wifey!)
Re: more PSD woes with cold weather [Re: Donald] #4988796 01/23/19 05:30 PM
F
fdcg27 Offline
F
Our old fully mechanical Mercedes 240Ds were never a problem in cold weather, if you could get them started.
Neither of these cars had the cold weather kit although both were sold new in Ohio, so you couldn't plug them in.
Down to about 5F, you could get a start if you left the car outside.
Below that, you'd want the car to have spent the night in the garage.
Once you got it running, you'd see no problems of any kind. I can even recall long trips in sub-zero cold with no engine running issues and shirtsleeve heated comfort in the car.
You didn't have these low temperature running problems with your old Dodge Cummins either, did you?
18 Accord Hybrid 20K HGMO 0W-20
17 Forester 30K VME 0W-20
12 Accord LX 115K SSO 0W-20
09 Forester 119K M1HM 5W-30
96 Accord LX 104K T5 10W-30
95 318i
Re: more PSD woes with cold weather [Re: fdcg27] #4988865 01/23/19 06:41 PM
Donald Offline OP
I never had these kind of issues with my Dodge Cummins. But the Ford being newer has much more high tech precision involved in the fuel injection system. I will say that given the Dodge Cummins was useless in the snow I did not drive it that much in the winter.
Re: more PSD woes with cold weather [Re: Donald] #4988913 01/23/19 07:25 PM
R
roadrunner1 Offline
R
You need to find another fuel supply, the additive is useless unless fuel is above the cloud-point when added (between 32f-20 f). If you are adding a fuel additive below the cloud-point you're wasting your money as it can't blend correctly with the fuel.
'15 F350 6.7
Re: more PSD woes with cold weather [Re: Donald] #4988964 01/23/19 08:27 PM
02SE Offline
I second finding another fuel source. My '17 RAM starts and runs fine at -20 F, not plugged in.
Re: more PSD woes with cold weather [Re: Donald] #4989239 01/24/19 07:49 AM
supton Offline
I agree, the only time I had my TDi gel was when I used a fuel station that likely had a poor turnover rate (it was in Concord proper but I doubt trucks filled there that often). Might just have to drive the extra mile for the cold months I'm afraid (and it makes you wonder what else that fuel is lacking in for quality).
2011 Toyota Camry, base, 2.5L/6MT, 194k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 155k, ours
1999 Toyota Camry LE, 2.2L/4AT, 215k, his
Re: more PSD woes with cold weather [Re: Donald] #4989685 01/24/19 02:57 PM
claluja Offline
See last post in this link about some bad gelling fuel in NY
https://www.ford-trucks.com/forums/1563311-does-the-6-7-have-a-fuel-heater-3.html
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
2018 Jeep Rubicon, Pentastar 3.6L
Re: more PSD woes with cold weather [Re: Donald] #4989797 01/24/19 04:55 PM
M
MNgopher Offline
M
Starting to sound not so far fetched there is some bad diesel being distributed in that area...
To the OP, I'd make sure to mention, if you had not already, that you are having trouble to the fuel supplier. They hear it enough, some real investigation might actually happen.
Still surprising that a region that isn't that unusual to get cold sounds like they are getting bum fuel...
Re: more PSD woes with cold weather [Re: Donald] #4990632 01/25/19 03:38 PM
H
Huie83 Offline
H
That's weird. I've been using Opti-Lube XPD in my VW Golf TDI with the CR 2.0 motor. It's been negative digits the past few days and she fires right up. I actually didn't use any in my current tank (forgot to bring it when I fueled up) and it's been fine.
Wonder if you just have some bad diesel.
I know one tank I got from a not so busy station I had some weird missing issues. On the highway it felt like the engine was missing randomly and I'd lose 1-200 RPM for a split second.
Re: more PSD woes with cold weather [Re: Donald] #4990727 01/25/19 05:39 PM
Donald Offline OP
I got the fuel from a new Cumberland Farms station :(Cumbies).
They sell a lot of gas, unsure how much diesel. Not setup for tractor trailers.
Re: more PSD woes with cold weather [Re: Donald] #4990748 01/25/19 06:03 PM
Donald Offline OP
911 is alcohol based. You must use it carefully. Owner's manual for my PSD says no alcohol based winterizer.
Re: more PSD woes with cold weather [Re: Donald] #4990750 01/25/19 06:04 PM
Donald Offline OP
So now what to do for the rest of the winter? Trust ExxonMobil to have properly winterized fuel? Gulf?
Re: more PSD woes with cold weather [Re: OVERKILL] #4991753 01/26/19 06:26 PM
G
Garak Offline
G
Originally Posted by OVERKILL
Interesting. I've been putting nothing in our diesel's fuel at all. Petro-Canada sells "winter diesel" and that's what we've been buying. No issues, even when it was -26C shrug
Yes, it is kind of odd. My dad had everything from more than one iteration of the Powerstroke to GM 6.2 to Caterpillar agricultural equipment, used down to -40 and worse, with just ordinary winter diesel.
Plain, simple Garak.
Page 2 of 3 1 2 3
