Originally Posted by t1snwrbrdr12
No because professional grade impact guns are capable of 700-1000 or more foot pounds of torque and even more in reverse. No matter what little blip anyone does, no matter how used to their tools they are, he or she is not going to be consistent impacting wheels on. If a torque stick is used as opposed to just a socket, I've found them to be very very consistent. I'm anal about my maintenance and I trust my torque sticks with air tools. With battery tools I don't though.
Appreciate the education; that's something that I never knew.
Originally Posted by HangFire
Tire shops use "torque sticks" which are supposed to limit impact guns to a selected RANGE of torque. But at best they are not as precise as a torque wrench, and at worst they can be abused and overtorqued, as a certain Goodyear Tire & Auto location so well demonstrated to me.
Thanks for your input. Do you have a preference/brand of torque sticks?
Originally Posted by cronk
Generally speaking, you would be best to stay with the oe type of friction.
Most passenger cars made in the past 15 years were designed using ceramic pads, and that is what will give the best over all performance and longevity.
Many heavy duty trucks still come oe with semi metallic due to the severe demand placed on the brakes due to heavy weight and towing.
Ceramic and semi metallic work in very different ways, metallic work using friction, ceramic work off adhesion.
The metallic particles dig into the rotor ( on a microscopic level).
Ceramic pads leave a thin coating of material on the rotor that the pads grab onto, think like contact adhesive that you apply to 2 surfaces and they grab ahold of each other. This is why ceramic pads are generally more friendly to the rotors. A proper bed in process ìs important to assure the rotor is evenly coated with ceramic material.
I would install a mid to upper level ceramic pad with new or freshly machined rotors.
Where the pad rides on the caliper bracket must be cleaned of rust to assure the pad can move freely.
As far as brand goes, the Bosch stuff has worked well for me, as has Centric, Reybestos and EBC.
Your post was very instructive; thanks for writing.
Originally Posted by The Critic
Originally Posted by NDL
So...pardon my ignorance, but if a shop is given to performing quality repairs, wouldn't a seasoned, conscientious, auto technician, using an air wrench, following a star pattern, suffice in torquing all of the lugs equally?
Sort of. With enough practice, most techs can tighten all lug nuts (or bolts) fairly evenly. Using either my air or cordless impact, I can consistently tighten all lug nuts to a point where they all require 1/8-1/16th of a turn before they reach 80 ft-lbs on the torque wrench. Is that good enough to prevent lug nuts from falling off? Yes. Is it good enough to minimize the likelihood of developing excessive rotor runout? I don't know....and that is why I still check with my torque wrench.
Appreciate the feedback...thanks
My decades of experience of following up on tire shops is, most get it right, but enough do not, and those few can ruin your day if you have a flat. Not to mention, uneven or over-torquing is hard on your brakes.
I have had multiple instances of having to stand on my 30" Snap-On 1/2" drive breaker bar to get lug nuts off, right after new tires. In one case, a Goodyear shop cross-threaded about half of my lug nuts. On the phone the service writer tried to say they use torque sticks so that couldn't happen. I brought in some cross-threaded lugs I had removed from the truck and slapped them down on the desk and asked "explain to me how this didn't happen". They paid for new hardware that I got at the dealer, but I installed it myself.
When checking on lug nuts, keep in mind that a static pull is usually 25-30% higher than a dynamic one... meaning if they put it on at 100 ft-lbs and you take it off later, it may require 125-130 ft-lbs to remove. More if left on for 6 months.
That's incredible. One reason why I am not a fan of most tire chains.
