Credit Increase- CC's
by Zee09. 02/21/19 08:24 AM
High iron and silicon
by landyman. 02/21/19 08:21 AM
13 Titan Vibration in 4th gear.
by Anthony. 02/21/19 07:36 AM
DEF Consumption
by wings&wheels. 02/21/19 07:06 AM
Which Natural Gas Water Heater to Get?
by LoneRanger. 02/21/19 06:58 AM
2016 Crosstrek Windshield Washer reservoir
by Donald. 02/21/19 06:43 AM
Whistling wipers!
by mclasser. 02/21/19 06:39 AM
Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
Opinion Of Dodge Nitro
by Warstud. 02/20/19 09:26 PM
Cheap first car
by LeakySeals. 02/20/19 09:08 PM
Grand Caravan break in
by pda1122. 02/20/19 09:07 PM
Million mile Lexus
by Skippy722. 02/20/19 08:57 PM
AtomicNumber53, waynea, txan, pman9003, alienyouth33
67298 Registered Users
95 registered members (Al, alienyouth33, 2004tdigls, 1foxracing, Alfred_B, 13 invisible), 1,521 guests, and 51 spiders.
Topics284,600
Posts4,873,164
Members67,298
Most Online2,548
Feb 16th, 2019
Bag-in-a-box motor oils #4987142
01/22/19 02:10 AM
01/22/19 02:10 AM
British Columbia, Canada
jtr990 Offline OP
jtr990  Offline OP
The tire shop I worked with recently made the switch from the regular bulk 5w20, 5w30, and 15w40 oil containers to the Shell Ecobox oil dispensing system, with positive results. Having said that, I was wondering how practical, energy-efficient, and manageable bag-in-a-box engine oils have become, regardless of brand? Especially when working in a small shop.
Re: Bag-in-a-box motor oils [Re: jtr990] #4987148
01/22/19 02:44 AM
01/22/19 02:44 AM
Europe
ChemLabNL Offline
ChemLabNL  Offline
Europe
What are the positive results?
Re: Bag-in-a-box motor oils [Re: ChemLabNL] #4987151
01/22/19 02:52 AM
01/22/19 02:52 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Profits for the shop.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Bag-in-a-box motor oils [Re: jtr990] #4987176
01/22/19 05:05 AM
01/22/19 05:05 AM
WA
OilUzer Offline
OilUzer  Offline
WA
Since its lighter, hopefully the shops will shake the box or the first 2 fills will be all additives grin2
What is the noack,kv100 & hths of additives? I forgot shocked2
Re: Bag-in-a-box motor oils [Re: jtr990] #4987184
01/22/19 05:55 AM
01/22/19 05:55 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
A) I wonder if their bulk tank was closing in on replacement time? They sprout holes in the bottom, just like home heating oil tanks, no?
B) Having several oil types available is one positive result. Though I'd still be distrusting of any grease monkey grabbing the correct oil for my modern car.
Re: Bag-in-a-box motor oils [Re: jtr990] #4987223
01/22/19 06:54 AM
01/22/19 06:54 AM
Kansas
Kruse Offline
Kruse  Offline
Kansas
The local WM now sells Havoline's 6 quarts of oil in a box. The label says it uses 70% less plastic.
However, if I still shop around, I can get some entry-level oils for a cheaper price per quart.
Re: Bag-in-a-box motor oils [Re: ChemLabNL] #4987414
01/22/19 10:08 AM
01/22/19 10:08 AM
jtr990 Offline OP
jtr990  Offline OP
Better oil variety, uses less space, and no leaky bulk oil pumps to mess with.
Re: Bag-in-a-box motor oils [Re: Kruse] #4987428
01/22/19 10:26 AM
01/22/19 10:26 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
I have yet to see Boxed oil in either of my Walmart's.
2004 Corolla 129142
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74645
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Bag-in-a-box motor oils [Re: JohnnyJohnson] #4987439
01/22/19 10:44 AM
01/22/19 10:44 AM
PimTac Offline
PimTac  Offline
I’ve seen the Havoline. It’s not in all the Walmart stores.
In my opinion, the savings on plastic is negated if you have to buy a plastic jug to recycle the used oil. Also you have to buy a pitcher or something to measure with if your vehicle holds less than the six quarts.
Cannot see signatures any longer so it doesn’t matter.
Re: Bag-in-a-box motor oils [Re: PimTac] #4987477
01/22/19 11:37 AM
01/22/19 11:37 AM
Maricopa, Arizona
dave1251 Online happy
dave1251  Online Happy
Maricopa, Arizona
How is it negated? It's better to buy one bottle rather then buying a bottle each change.
don't use.
Re: Bag-in-a-box motor oils [Re: dave1251] #4987483
01/22/19 11:48 AM
01/22/19 11:48 AM
PimTac Offline
PimTac  Offline
I’m stuck in the idea that my used oil goes back into the 5 qt jug the new oil came in. With the bag in the box setup, the used oil has to go into something. If I had one of those oil pans that holds the oil that would be an option. I don’t though.
I’m not knocking the concept.
Re: Bag-in-a-box motor oils [Re: jtr990] #4987513
01/22/19 12:21 PM
01/22/19 12:21 PM
Vancouver
Jimmy_Russells Offline
Vancouver
My local parts supplier has had this in Eneos oils now for a couple years. They are kind of neat.
Re: Bag-in-a-box motor oils [Re: PimTac] #4987695
01/22/19 02:56 PM
01/22/19 02:56 PM
Maricopa, Arizona
Maricopa, Arizona
RGR I have vehicles with larger sump capacities then 5 quarts I recycle but I have been using a 15 quart jug for a while.
don't use.
Re: Bag-in-a-box motor oils [Re: jtr990] #4987778
01/22/19 04:40 PM
01/22/19 04:40 PM
Texas
johnnyz73 Offline
johnnyz73  Offline
Texas
My local mechanic uses the boxed STP oil in all flavors, both Full Synthetic and Conventional.
2017 Jeep Patriot
STP 5W20 SYN Full Synthetic Engine Oil
STP 15,000 Mile Maximum Life Oil Filter
Re: Bag-in-a-box motor oils [Re: jtr990] #4988607
01/23/19 02:05 PM
01/23/19 02:05 PM
Europe
ChemLabNL Offline
ChemLabNL  Offline
Europe
Got it..,.And I hope that you are more profitable as well.
Moderated by  ekpolk
