Thought I would give credit where credit is due......I've pulled cabs on 6.0L & 6.4L powered Ford Trucks, But never really thought of doing it on gas powered Fords 'til 14Accent posted a thread on doing Timing Chains on a 3.5L Ecoboost with the cab pulled.
This is a 2003 F-250 5.4L that has a cracked cylinder head.....If it was just Timing Chains, I would have done it with the cab-on. Manual calls for pulling the engine to do cylinder head R&R.
Started at 10am, Had both heads pulled, Cab back on the frame & pushed off the lift by 3pm with an hour lunch in the middle. Ran the heads by the machine shop on my way home.
Without the CAC pipes & driver side battery found on the diesel trucks......The cab is even easier to pull!
