Originally Posted by supton
I could see the slow 0-60 but 0-100? Wouldn't that be from low hp? I mean, off the line it'd be a dog but once the motor hit full song it should have been fine. Excepting for the fact that it was probably doing 60+ in first and hitting an aero brick wall...
I always wondered if there was a gain from avoiding overdrive and using direct drive when possible. I suspect the gain was negligible, and OD allowed better final drive setups (strength). In the end it's the overall drive ratio.
They didn't have OD transmissions when they designed the Diplomat/Fury. (They were based on the 1976 Volare/Aspen.) They did have low HP...as I recall, after 1979, they topped out (police 4bbl 318) at 170HP, and they were done by 4000RPM. Things improved a bit in 1985, when they got the low-geared (A-999) transmission, but they never got OD. By the time Chrysler started building OD automatic transmissions, the M-bodies were pretty much at the end of the line.
