Disclaimer: Some would call this butchery.
Prius #3 was giving me grief, telling me it had issues being in Park if I sat there with the radio on for a few minutes. Classic symptoms of a failing 12v battery. New ones are $150 (potentially $110 at pep boys after $40 rebate) but money's tight and I was bored.
So I got a 35 Ah AGM battery (This guy) and went at it.
First note is the different terminal style, which needs fiddling. Second is its reduced height, which required shimming. Thirdly, there's no port for it to offgas. Since it's an AGM battery, in the hatch area, and behind some trim with a vent to the outside, I'm not worried about hydrogen.
For the positive terminal, one removes the post clamp, bends the tab over, and bolts it up with the through-bolt provided. I added a wider washer on the back-side so it wouldn't dig into the lead of the terminal.
For the negative, I simply spread the existing post clamp slightly then used the battery's hardware to bolt through.
On my first attempt at installation, I shimmed the battery with both wood blocks underneath. This had the positive terminal sticking up so far it could have been bumped by something heavy on the cargo floor, transferring energy through the passenger side floor/trim piece. So I revised it with one block below, one up top giving the clamp adequate tension.
Worsely, the HV battery output vent tube doesn't fit around this mess. I live in the cold and have never heard the HV battery fan even run aside from a fault condition, so am not worried. This fan's output will now bounce around in the no-man's land until it finds its way out the body exit flap.
So, it's a kludge! Works good though.
