Acceptable amount of time to get up to speed?
by ls1mike - 11/22/19 09:35 AM
Paint question
by supton - 11/22/19 09:31 AM
Yet Another Zinc Oil Question
by Tedd - 11/22/19 09:07 AM
SUV tires vs passenger car tires
by Ded Mazai - 11/22/19 09:00 AM
Crysler Crossfire Pro/Con?
by tc1446 - 11/22/19 08:54 AM
Possible to balance a bent steel wheel?
by johnnyh55 - 11/22/19 06:33 AM
Tablet question.
by 007 - 11/22/19 04:29 AM
dexos 1 vs dexos 2
by avi1777 - 11/22/19 02:33 AM
I had to lay it down...
by 02SE - 11/22/19 01:22 AM
Costco Car Buying
by rrretiree7 - 11/22/19 01:06 AM
Tesla Cybertruck
by E365 - 11/21/19 10:30 PM
Tesla Truck Reveal
by Aero540T - 11/21/19 10:06 PM
DIY Engine Rebuild Costs
by Spetz - 11/21/19 10:01 PM
Killer rod
by P10crew - 11/21/19 09:51 PM
Do you need to shake clear cans of spray paint?
by atikovi - 11/21/19 09:20 PM
Is this an accurate test on motor oil
by Tboss - 11/21/19 08:57 PM
Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi
by SavagePatch - 11/21/19 08:48 PM
Tedd, hunter9296, Corslayth, oildud, Kylefl1
69938 Registered Users
108 registered members (5azzmonkey, 4WD, Alfred_B, 67ZL1, aquariuscsm, 1978elcamino, 13 invisible), 2,109 guests, and 20 spiders.
Topics297,770
Posts5,122,193
Members69,938
Most Online3,589
Nov 2nd, 2019
Rate Thread
'15 6.7 Powerstroke UOA #4983393 01/18/19 10:18 AM
R
roadrunner1 Offline OP
R
FE................................................................77
CHROMIUM................................................<1
NICKEL.......................................................<1
ALUMINUM...................................................6
PB................................................................<1
SILVER.......................................................<.1
COPPER.......................................................2
TIN...............................................................<1
TITANIUM....................................................<1
SILICON........................................................7
BORON.....................................................187
SODIUM.....................................................<1
POTASSIUM................................................2
MOLY........................................................284
PHOS........................................................902
ZINC........................................................1044
CALCIUM................................................1359
BARIUM.....................................................<1
MAGNESIUM...........................................838
ANTIMONY................................................<1
VANADIUM................................................<1
[email protected] 100 C...........................................11.0
SOOT.......................................................<.1
FUEL%....................................................<.5
OIl and filter were changed at the time of sample, IOLM was at 0% (9,975 mi.)
The oil is John Deere Plus 50 II 10w-30 CK-4
The sample is from 10/08/18
The lab is OILSCAN
The truck is an F350 6.7 Powerstroke diesel, which is my work truck. It tows and hauls heavy daily.
The uptick in FE this sample attributing to a recall/TSB that was preformed during this run on the crankcase vent system as there is no other uptick in any other wear metal.
This is by far my highest ever FE# as since break-in they have run near 20 per 10,000 mi. OCI.
'15 F350 6.7
Re: '15 6.7 Powerstroke UOA [Re: roadrunner1] #4983422 01/18/19 10:58 AM
claluja Offline
Use Enerburn?
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
2018 Jeep Rubicon, Pentastar 3.6L
Re: '15 6.7 Powerstroke UOA [Re: roadrunner1] #4983435 01/18/19 11:19 AM
dnewton3 Offline
Global Moderator
Global Moderator
Not bad except the Fe as noted.
Will wait to see how it recovers on the next UOA.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: '15 6.7 Powerstroke UOA [Re: claluja] #4983439 01/18/19 11:23 AM
R
R
Originally Posted by claluja
Use Enerburn?
Yes I have been using Enerburn for the last year or so. At first I did see a major decrease in regen % at 500 mi., but now I'm not sure if it was attributed to the very cold weather we experienced last year at this time or the Enerburn. I am continuing to use it currently, but not so sure into the future once my current stock is exhausted.
'15 F350 6.7
Re: '15 6.7 Powerstroke UOA [Re: roadrunner1] #4983440 01/18/19 11:24 AM
claluja Offline
Use Enerburn?
Enerburn is why you have high iron. Pouring iron into your fuel, which makes it's way into the oil.
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
Re: '15 6.7 Powerstroke UOA [Re: claluja] #4983450 01/18/19 11:34 AM
R
R
Use Enerburn?
Really? I've been using the same fuel across my several different diesel engines and haven't seen an increase in FE, this is the first I've heard of this.
'15 F350 6.7
Re: '15 6.7 Powerstroke UOA [Re: roadrunner1] #4983453 01/18/19 11:35 AM
Danno Offline
I take the wear numbers as a possible oil spec issue.
I couldn't find John Deere oil meeting the FORD WSS-M2C171-F1 oil spec.
https://www.fcsdchemicalsandlubricants.com/main/additionalinfo/dieseloilsWSSM2C171F1.pdf
According to Ford, CK-4 does not give enough wear protection.
https://www.oildepot.ca/solution-ford-concerns-2017-api-ck-4-diesel-motor-oil-specs/
If it was my PS 6.7, I would do the following.
Run a Ford approved oil such as Devlac ESP 0W-40, using a higher weight than was on the UOA.
Change the oil at 20% OLM remaining life, just because I want the safety margin.
Stop using additives.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: '15 6.7 Powerstroke UOA [Re: roadrunner1] #4983485 01/18/19 12:03 PM
R
R
The Enerburn is a FUEL additive, not an oil additive.
I have the complete history of UOA's from when the truck was new, its always had 10w-30, always run to IOLM 0%, and this isn't the first run of the Deere CK-4, but it is the first uptick in FE.
As I had stated there was a warranty repair done involving the crankcase vent system.
I am going to assume the Deere lube isn't on the Ford list since it isn't officially API certified, no worries from my camp.
'15 F350 6.7
Re: '15 6.7 Powerstroke UOA [Re: roadrunner1] #4983509 01/18/19 12:37 PM
claluja Offline
Oil is good oil.
Enerburn is the high iron culprit for stock 6.7s. If you want another example, see beercan UOA thread I just bumped. Seen others.
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
Re: '15 6.7 Powerstroke UOA [Re: roadrunner1] #4983597 01/18/19 02:33 PM
BeerCan Offline
There is a later uoa than the one you bumped that has my first run without enerburn. My fe was still high, I have another uoa coming real soon which should help confirm or deny this theory
2020 Porsche Cayenne
2017 Ford F250 6.7 PS
2016 Ford F150 3.5 EB
2016 Porsche 981 GTS
2015 Ford Mustang 2.3 EB
My car list is getting long smile
1994 Porsche 968 Coupe
1987 Porsche 944 Turbo
Re: '15 6.7 Powerstroke UOA [Re: BeerCan] #4983601 01/18/19 02:35 PM
claluja Offline
Should come down, but slowly since the Enerburn coats engine parts with iron oxide. It's not just a matter of residual iron in the oil.
Edit: just looked up your latest UOA - thanks! Iron dropping nicely, and should drop further on your next one if Enerburn-free.
Good news is that the increased iron wasn't coming from engine wear!
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
Re: '15 6.7 Powerstroke UOA [Re: roadrunner1] #4983636 01/18/19 03:20 PM
L
Langanobob Offline
L
Just a question, how would a recall/TSB on the crankcase vent system cause higher fe content in the oil?
Re: '15 6.7 Powerstroke UOA [Re: roadrunner1] #4983674 01/18/19 03:58 PM
R
R
Mechanical parts being removed/reinstalled (nuts&bolts) within the oil system.
I had no idea pertaining the iron oxide within Enerburn, definitely something I will look at next OC,
'15 F350 6.7
Re: '15 6.7 Powerstroke UOA [Re: roadrunner1] #4985868 01/20/19 08:24 PM
dnewton3 Offline
Global Moderator
Global Moderator
https://www.enerburninc.com/
reduced wear by 40-50%????
I find that hard to believe ...
I know nothing of this product, but if there is correlation, that's worth investigating.
I'd email them and ask them about the Fe oxides; they may be willing to share info.
Here's the real rub ....
Let's say the Enerburn is the cause of the higher Fe. OK - means the engine isn't wearing adversely.
But this is like the topic of the Cu in Dmax engines when you see some lubes with high amines attack the oil cooler; they spike Cu REALLY high.
So if the product you use spikes a wear metal, even if that wear is colloidal and not detrimental, what happens when the element is so freaking high in the UOA count that is masks other issues?
If the Fe is allowed to be this high, then it's really hard (if not impossible) to see real world upticks in true wear, because the magnitude attributed to the additive is so large that you cannot discern smaller shifts in wear!
I'd ditch the additive, but it's not my truck.
Re: '15 6.7 Powerstroke UOA [Re: roadrunner1] #4985939 01/20/19 09:44 PM
claluja Offline
Fyi, Enerburn admits increased iron in the oil can result (but says "don't be alarmed" ???). My view is that it is particularly problematic in engines subject to fuel dilution, such as stock 6.7s which inject fuel on the exhaust stroke during regens. No real way to keep the added iron from the enerburn/ferrocene out of the oil.
https://www.movinout.com/magazine/enerburn-r-user-s-guide
Also, one can read up on enerburn/ferrocene and figure out this will happen.
https://www.researchgate.net/public...on_Four_Stroke_Diesel_Engine_Performance
http://fpc1.com/sci_ferrocene.php
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
