Originally Posted by slybunda
72 hours after being driven mine sits at 12.2v. This is the battery that was being undercharged by a dodgey alternator which had intermittent voltage drops. This has possibly been going on for over 8 months. Battery is a year old.
Always found it odd why it would turn over slower when left for a few days.
The same day i fitted a voltmeter in the car the same day i found out about the alternator issue. Voltage goes to 13.9 then drops to 12.5 then after a few seconds goes up to 14.3 then drops back to 12.6 etc.
Replacement alternator and it sits solid at 14.3 and drops down according to engine bay temperature.
Update:
Drove towards home:1hr highway driving, stopped by Pepboys/pickup AGM, and then home
Attached Battery Minder to OE Toyota battery for 2.5hrs(fully charged)
Detached from Battery Minder at 7pm
Readings
1/18 7pm 13.1
8pm 12.87
9pm 12.78
11pm 12.76
1/19 7am 12.7
7;30am Installed Bosch AGM -13.2
removed OE Toyota 8am 12.75
By the way, I have a Zus( amazon) usb/cigarette lighter that monitors Voltage and sends it to my iphone. This is a 24hrs run while driving from 1/17 16:02 to 1/18 15:16. I went to work(1/18 4am), drove to PepBoys and then drove home
After 15:16, I started working on the OE Toyota battery.
@slybunda, I agree with your findings, driving with alternator output @12.6 is bad, a new alternator @14.3 constant V is much better. See my pic.
I think my alternator is OK, since it charges between 13.5-14.4 when the car is running.
