This man is rebuilding his 2.0T EA888 out of his 2014 Audi A4. These engines starting from 2009 have had some severe issues with oil consumptions requiring a Stage 1 (PCV + software) or Stage 2 (replace cylinder rings with updated design) intervention from Audi depending on the rate of burn and circumstance. This rebuilder has traced it down to a problem with the oil ring design where oil is not flowing back out of the cylinder and hence burning off during combustion. This seems to be caused by clogged oil passages in the rings from carbon. As more oil is burned off, this probably just becomes worse and worse.
Curious about two things:
1. Would using an engine flush be strong enough to remove that carbonization?
2. Would a thinner oil have an easier time evacuating the cylinder once the drain has been cleaned?
These engines are generally rated for 5w30 or 5w40.
https://www.audizine.com/forum/show...d?p=13430056&viewfull=1#post13430056
https://www.audizine.com/forum/show...d?p=13484455&viewfull=1#post13484455
