I had a check engine light a few weeks ago and OBD scanner indicated Code P0024 - B Camshaft Position - Timing Over-Advanced or System Performance. I did some internet research (TacomaWorld forum) and several posts indicated that it could be caused by dirty oil or particles - several had experienced same, dealer changed oil and code went away. So I changed the oil, and lo and behold it cleared after 20 or so miles. Anyone ever experienced something like this?
More info: I sent the oil to Blackstone, and they didn't see any problems, it's consistent with prior changes. I've been using Amsoil Signature Series 0W-20 and Amsoil filters since first change at 2,700 miles. At 27,000 now. I did notice that the Blackstone reports show that the Amsoil has a higher viscosity, both at 100 and 210, than did the TGMO factory fill (not a huge difference but a difference nonetheless). Could this be a factor with the code??? Any thoughts would be appreciated!
