Generally wear rates are unaffected by most additives, when the additives are used in moderation.
There are some examples of massive wear trend shifts, but they are attributed to significant doses that greatly alter vis, and are often paired with other aftermarket "solutions" to problems imagined (an example would be a recent Dmax UOA posted here that used both Lucas to thicken a 15w-40 and a FF filter that has no BP relief).
The only way to know for sure would be to do a true controlled study; 30 UOAs not using the additive to establish a base control group, and 30 UOAs using the additive. Then analyze the data for averages and stdev; see if you can discern the trend shift amid the noise of daily use. Hint - no one here has the time/money to do this; that's why these topics are the fodder of bench racing and not science.
