Hey BusyLittleShop
by Shannow - 10/21/19 04:47 AM
TT Equalizer: MORryde CRE3000 VS Lippert Equa-Flex
by SavagePatch - 10/21/19 12:53 AM
Milwaukee 2485-20 M12 1/4” Right Angle Die Grinder
by The Critic - 10/21/19 12:41 AM
Group 78 Battery Connector Issues
by Falcon_LS - 10/21/19 12:37 AM
Factors that can affect warming up time
by SlavaB - 10/20/19 11:59 PM
A nokian lineup review
by UG_Passat - 10/20/19 11:19 PM
Dealer Oil Change
by HowAboutThis - 10/20/19 10:35 PM
small qty of automitive paint
by danez_yoda - 10/20/19 09:36 PM
2017 Chevy Cruze recommended oil filter
by Electromotive - 10/20/19 09:13 PM
4L80E to Allison filter conversion
by P10crew - 10/20/19 09:03 PM
Pickles and gardenia
by 53' Stude - 10/20/19 09:00 PM
Weird Electrical Problems Due To Bad Ground.
by RayCJ - 10/20/19 08:59 PM
ECOGARD X 4610 CUT OPEN
by 53' Stude - 10/20/19 08:23 PM
FRAM ULTRA 7317 CUT OPEN
by 53' Stude - 10/20/19 08:17 PM
Easy to use free video editor
by Rat407 - 10/20/19 08:11 PM
Best budget tire for 2006 Nissan Pathfinder SE
by Dogred08 - 10/20/19 07:51 PM
Latest on SSD, HDD and USB Drives?
by JHZR2 - 10/20/19 07:43 PM
Oxy Clean On Leather Seats...WoW
by Warstud - 10/20/19 07:22 PM
Winter street biking
by CourierDriver - 10/20/19 06:47 PM
whizznbyu, Oildude, JDVW2019, Carlos40A, GeraldT
69624 Registered Users
39 registered members (AEHaas, 2015_PSD, Best F100, Bailes1992, bernau, 5 invisible), 743 guests, and 21 spiders.
Topics296,251
Posts5,094,224
Members69,624
Most Online3,532
Jul 30th, 2019
Full Synthetic High Mileage in 40w range. #4979998 01/15/19 01:41 PM
F
FlyPenFly Offline OP
F
Looking for a 40w range fully synthetic high mileage oil.
Does anyone else make a full synthetic high mileage oil like M1 10w40? I can't seem to find any that are full synthetic. Nothing against it but just wondering if there are other oils I should look at as well. This is for the problematic VW/Audi EA888 engine with about 123k miles on it. They're notorious for oil consumption.
2014 Mercedes GLK350 3.5L DFI
2014 Mercedes E350 Coupe 3.5L DFI
2010 Audi A4 2.0T
Re: Full Synthetic High Mileage in 40w range. [Re: FlyPenFly] #4980031 01/15/19 02:20 PM
A
aquariuscsm Offline
A
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/7AA916452910531580257EFB0071A62D/$File/BPXE-A4X7SV.pdf
Castrol Edge High Mileage 10W40
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Advanced Durability 10W30
Re: Full Synthetic High Mileage in 40w range. [Re: FlyPenFly] #4980042 01/15/19 02:30 PM
9
901Memphis Offline
9
The 10w40 M1 HM is what you want. You could probably get away with a 10w30 too?
2012 Chevy Cruze LT 1.4T - 69k - M1HM 5w30 + Fram Ultra
2002 Buick Century 147k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Full Synthetic High Mileage in 40w range. [Re: FlyPenFly] #4980046 01/15/19 02:31 PM
E
edyvw Offline
E
My EA888 does not consume drop of oil.
How is your PCV or rear main seal? PCV failure will lead to rear main seal failure.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: Full Synthetic High Mileage in 40w range. [Re: FlyPenFly] #4980075 01/15/19 02:52 PM
F
F
After looking at the VOA, I guess M1 10w40 is the way to go with it's lower Ca and higher Mg. This is a turbo DI engine after all. Thankfully it's significantly less expensive than the Castrol 10w40HM.
Car is running fine but it needs the timing chain system replaced (tensioner is at max extension) and I'll probably do the PCV system myself in the near future. Not burning much oil but want to keep it that way. It's a class action and TSB for Audi anyway for oil consumption and timing chain system. Apparently a lot of these engines suffered from poor quality cylinder rings from a vendor and poorly designed timing chain tensioners pre-2014.
2010 Audi A4 2.0T
Re: Full Synthetic High Mileage in 40w range. [Re: FlyPenFly] #4980223 01/15/19 05:15 PM
E
edyvw Offline
E
I would stick with Castrol 0W40. You will not gain anything with HM oil.
I changed tensioner at 68k preventively and installed updated one.
Reengineered piston rings, PCV are mid-2012 as well as chain tensioner (this affects 3.0T engines too).
I would change tensioner ASAP, and stick to Castrol 0W40. PCV might alleviate some of your issues as that is first culprit.
By the way, what oil are you using now?
Re: Full Synthetic High Mileage in 40w range. [Re: FlyPenFly] #4980235 01/15/19 05:24 PM
J
Jimmy_Russells Offline
J
Agree with edy above.
I had a 2011 GTI for 7.5 years and my coworker bought it from me about ten months ago, he still has it. It has about 82k on it now. Still on the original tensioner but I have told him he might want to swap it out. I think the consumption problem is more PCV related but mine never really used much oil, maybe 1/2-3/4 quart every 6-7k mile OCI. I always used 502 oils in it.
Re: Full Synthetic High Mileage in 40w range. [Re: FlyPenFly] #4980294 01/15/19 06:48 PM
R
rubberchicken Offline
R
Amsoil makes a good synthetic 10w-40. Motul also has a 10w40 full synthetic.
Re: Full Synthetic High Mileage in 40w range. [Re: FlyPenFly] #4980300 01/15/19 06:53 PM
dogememe Offline
O'Reilly Full Synthetic HM 10w-40 is cheap and decent.
2010 Ford Escape 2.5 ~100K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~283K Miles: Unknown Oil, Filter.
Re: Full Synthetic High Mileage in 40w range. [Re: FlyPenFly] #4980310 01/15/19 06:58 PM
dubber09 Offline
I second that, M1 HM 10w-40 is a very good oil.
Kia Sportage 2014 GDI 2.4L
Kia Forte 2014 MPI 1.8L
Re: Full Synthetic High Mileage in 40w range. [Re: edyvw] #4980334 01/15/19 07:27 PM
F
F
I think at 123k miles on this somewhat problematic engine design, I think it might make sense as preventative to keep the seals in good condition. There's Castrol 0w40 that was just changed in there now. I'm getting the tensioner and full chain service and maybe a carbon cleaning done in 2 days.
Next oil change, I'll probably switch to M1 10W40HM because of it's lower Ca content as well.
2010 Audi A4 2.0T
