Originally Posted by BigCahuna
I've never been able to get an accurate temp reading of my bikes motor oil,with my point and shoot temp gun due to port where you put the dipstick. But I will say this. A few weeks ago I went out for our weekly Polar Bear ride and the air temp was 28f. For a second there, I didn't think it was gonna start due to it turning over super slow. After 2 tries it finally lit off and wasn't a issue for the 4 or 5 other starts that day. Based solely on using my hand to gauge the motors temp, I'd say it runs alot cooler when the air temps are below 32f. Harley says in their manual to use 10/40 wt oil if the bikes being ridden in temps under 40f, for ease of starting.
That's interesting - what oil did you have in the bike? 20W-50?
If I had to guess, I'd say the first start was tough because the oil was at ambient temp, and on the subsequent starts the oil was warmed up from the bike being ridden and not given time to cool down too much. The viscosity at, say, 50F will be around half of what it is at freezing, so a little bit warmer goes a long way.
I have a Trailtech oil temp gauge on my bike and I installed the sensor where the main oil gallery plug bolt used to go. The oil passing by has just exited the oil filter after passing through the oil-to-coolant heat exchanger, so it's at the point where oil temps will be lowest. A run on the freeway will have the oil temperature matching coolant temperature - in cold weather this happens fairly quickly.
