Originally Posted by demarpaint
I didn't think coating the braking surface with paint is a good idea. It seems to me a cost cutting compromise to finishing off coated rotors, they save a few pennies not masking off the braking surface prior to painting them.
I think the issue is that rotors are used on different applications/models but the brake caliper pads might be slightly different.That means on some vehicles there will be paint under the pad area while others will be unpainted where the pad doesn't contact (and will develop permanent rust).
