I picked up a couple pieces of ceramic in my front right tire. As a result, the high point of tread has a couple 1 inch gashes. It does not appear that the bottom surface of the tire has been damaged badly. Very little penetration if any on the bottom surface. Damage is mostly in the tread. Obviously, nobody can predict the future and I can replace it, but the tire has less than 2000 miles on them. What would you guys suggest? I had the tire leak checked and it does not lose air.
