Rebuilt transmission - how to treat it?
San Francisco Bay Area
Finally got my wife's 2002 Civic LX (4AT) working again. Cost about $1600, but otherwise the car runs well. But it's got a rebuilt transmission from an engine/transmission rebuilder. I've noticed it smells a little burnt. It smelled a lot more when I just picked it up. After a while I only notice an odor when I'm stopped.
Take it easy? Drive it normally? I figure the odor will go away.
Of course the car could have a host of problems. Had to charge the battery twice because it was sitting in the driveway for months and not driven. Not sure if it's sulfated as a result, but it would be easy enough to buy a new battery.
Well, it will be one of three things: Worse than stock, equivalent to stock, or better than stock. Depending on the skill of the Mechanic, and the quality of parts used.
As for a burnt smell, without smelling it myself, it could just a be little ATF that got onto surfaces during the removal, rebuild, install, refill process, in which case it will likely go away shortly. Assuming he's competent, and used good parts, it should be at least as good as a new OEM trans. In which case I would just drive it normally. I assume he also has some sort of warranty period on the rebuilt trans.
Drive it normally - transmissions don't really have a "break in period"....
Well, modern engines really don't, either....
And make sure you check the fluid level. What happened to the Original Tranny? Lack of maintenence?
You can change the fluid yourself on those very easily. Its just a drain and fill without a filter. I can change mine on a 2012 just as easily as I can change the engine oil. You said the smell is not as bad now as when you first got the car back and that is a good sign. If it kept getting worse it would be a problem. Check the fluid level and if it's ok keep driving it.
When should you change the fluid in a rebuild? I had my 4l60e rebuilt. has dex 6 in it. I do have some amsoil dex 3 in the garage.
It was 17 years old. That is what happened.
Not sure really. The only scheduled maintenance is 4 straight drain and fills at 100k miles. I kind of split the difference and did it twice a few years ago. Figured I'd do it again. I used Honda ATF from a dealer.
Not sure on that either. I thought that brand new transmissions have whatever fluid is in them and then that's what's expected to be there until scheduled maintenance comes up.
I'd drive it normally and change the ATF in a few thousand miles (may next oil change). I see you used Honda ATF in the past. Did you use it in this transmission?
Oh, and I don't know the proper procedure for checking the ATF level in you car but I would do that as well. If you are smelling something burning, I wouldn't want my ATF
to be leaking out and dripping on something hot.
Used Honda DW-1. It was a pain too. I ended up damaging the drain bolt head when it slipped and bought a new one (at an Acura dealer strangely enough because it was cheaper but the correct part). I also didn't have a breaker bar/flex handle and bought one at Sears. I've never had a problem using a 3/8" ratchet on a Honda/Acura manual or auto transmission until this one. I also couldn't get enough leverage to break it open so I raised it about 4 inches on ramps. I basically couldn't insert it in and get enough room to actually move it until it got a little higher.
Checking is really easy. The dipstick plugs into the fill hole and is easily accessed. The transmission is recirculating fluid without a filter.
However, I've never had a rebuilt auto transmission before. The mechanic said that he would expect at least 150k miles out of it, even without a fluid change. He's got a similar generation Civic himself. I hadn't checked the fluid myself in a while, but he looked and there was plenty of fluid. I guess it was just kind of random that it failed.
I still have some transmission fluid, but a change only replaces about 40%. Any other suggestions here about if/when would be a good time to do it?
I would add a bottle of Lubegard Red to it. That's kind of how the product got its start from trans rebuilders using it after a rebuild. One of the Honda mechanics that I know swears by the stuff and is against just about any other additive except for that one. Use the entire bottle during the next drain/fill which I would do sooner rather than later.
Maybe some atf spilled on the hot exhaust causing the fumes. Which would get better in time.
The guys who rebuilt my 4L65E told me 30k mi. I'll probably change it at 2 years although it won't be there in miles.
I am not being a weiner but did you check the ATF the proper way? On my Toy's, I check ATF hot while idling. Eric the car guy video I just watched said to check Honda's hot with engine off. I don't know if he is right. I really don't.
And I from what I know, Honda's are picky about their ATF. My SonInLaw is a Honda Parts Mgr and he verified the DW1 is the correct ATF.
I'd go to next oil change and do the drain and fill of the ATF.
Quote
used Honda DW-1. It was a pain too. I ended up damaging the drain bolt head when it slipped
I do regular drain/fills and now use a pump. Even a cheap one from Harbor Freight works well - pump out 3 to 3.5 qts via the fill tube every 20k miles and replace. Pump some soapy water through the pump afterwards to clean the seals and keep them healthy.
I too would add Lubegard to it (it works), but check whether Red or Platinum is correct for the Honda. Their ATs are finicky, as you now know. One once of the Lubegard bottle should go into the PS system. It protects there, too.
Sure. The proper procedure is warm on a level surface. Maybe a few minutes after shutdown so that it settles. It's pretty easy to check. In any case the fluid level was fine when the mechanic checked it.
I know that Honda ATF-Z1 was the factory fill, but Honda says DW-1 is a direct replacement. There are some generic versions of Z1 still available.
https://www.amazon.com/ACDelco-10-4056-Honda-Automatic-Transmission/dp/B007Q9QNR2/
Well, you got my questions settled....Good Job!
Drive it normally - transmissions don't really have a "break in period".....
I must respectfully disagree, Well....Partially anyway.
Friction disc surfaces are not are not perfectly flat when new, In fact they're kinda "hairy" & coarse. It takes quite a few on-off cycles to break-in the friction surfaces.
With fresh frictions, Especially Flat-Faced ones.....The shifts will be soft & lazy 'til the surface packs down & mates to it's steel.
I recommend waiting 200 miles before putting the wood to a fresh unit, This being a low power/light vehicle....Not that big of a concern.
