Arlen Ness passes
by 02SE. 03/24/19 03:15 AM
Plants - they learn and remember
by Shannow. 03/24/19 03:02 AM
Rotella Gas Truck
by jpstiles02. 03/24/19 02:53 AM
The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
What's in Maxima oil?
by Truckedup. 03/23/19 06:29 PM
2015 Acura TLX 3.5L V6
by blackdiamond. 03/23/19 06:20 PM
GSXRBullwinkie, Mark1970, FixItDad28, RandomJoe, Sciascia
67599 Registered Users
37 registered members (BobFout, berlyn, billt460, AurionX2, Astro14, 4WD, 6 invisible), 655 guests, and 54 spiders.
Topics286,323
Posts4,906,447
Members67,599
Most Online2,967
Mar 10th, 2019
Need grease for a bushing in a trans with a wet clutch and atf #4977396
01/12/19 09:19 PM
01/12/19 09:19 PM
California
englertracing Offline OP
California
Hello,
Motorcycle trans
I need a grease I can put on a bushing thats in a low oil flow area, where I had some wear.
It has a wet clutch and uses atf, I cant put something with any ep addatives, or friction reducers in it for fear of causing clutch slippage.
I know theres some trans gel and other automatic safe assembly lubes, but they all say "soluable in oil" meaning they will wash out, and not plug circulating systems.
These atf assembly gels seem to ceartainly be an option, however id prefer the stuff would stay there as long as possible.
Question section
1. What are some examples of "non oil soluable grease"
2. Arent most greases with your average thickeners, clay, lithium, sodium, calcium, aluminum oil soluable? I mean oil is dissolved into them, therefore shouldnt they be souble in oil?
3. Any reccomendations?
Thanks,
Aaron Englert.
Re: Need grease for a bushing in a trans with a wet clutch and atf [Re: englertracing] #4977468
01/12/19 10:15 PM
01/12/19 10:15 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
So you want to lubricate something that is seeing some lubricating oil movement, but not enough?
I dont think its right to say that a grease base is soluble in oil. However, I think it is safe to say that the oil held up in a grease, is soluble in other oil, and therefore the oil that came in the grease is likely to be exchanged out.
Im not sure that is the worst thing.
But if the oil flow causes a slow erosion and dispersion of the grease thickener, what will that do for the same items youre concerned about affecting with additives?
Re: Need grease for a bushing in a trans with a wet clutch and atf [Re: englertracing] #4977519
01/12/19 11:07 PM
01/12/19 11:07 PM
California
California
So basically there clutch pushrod goes through the mainshaft, its operated by a cam/notch, the pushord is also what locates the cam. So theres a bushing in that end of the mainshaft that takes any axial load on the cam/lever, which may be generated by gravity or cable pull angle.
This location is above oil level, has no way of introducing any flow. Short of laying the bike on its side I dont see any reason for oil to exist in this location.
The bushing was basically gone when I took it apart. It was not negatively effecting clutch actuation. I took this engine apart because of conn rod big end bearing failure
So id just like some tenacious grease without any crazy addatives to help the situation a little.
These transgel type greases will ceartainly work, but being designed to wash away to prevent pluging passages, sounds to me like it wont hang around its designed not to.
This trans has no circulating system and is seprate from the engine sump.
So I guess my question is...
Is the transgel [censored] really much more soluable in oil than a standard grease?
Are they just saying that so that people wont be too concerned about plugging things?
After some googling the transgels trick is liquifying at 143f.
I think I need to find something else.
Re: Need grease for a bushing in a trans with a wet clutch and atf [Re: englertracing] #4977534
01/12/19 11:35 PM
01/12/19 11:35 PM
McLean, Va.
vssjim Offline
vssjim  Offline
McLean, Va.
I like to use smooth light buttery type greases for slides like what you are talking about or throw out bearings on snouts like lucas g3 grease
Re: Need grease for a bushing in a trans with a wet clutch and atf [Re: englertracing] #4977542
01/12/19 11:44 PM
01/12/19 11:44 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
The red petroleum jelly used to assemble automatic transmissions (stop by any trans rebuild shop to see it) would work just fine.
Re: Need grease for a bushing in a trans with a wet clutch and atf [Re: Linctex] #4977545
01/12/19 11:51 PM
01/12/19 11:51 PM
California
California
But would it stay?
I think it will melt...
Id like it to be there in 9 more years....
Re: Need grease for a bushing in a trans with a wet clutch and atf [Re: englertracing] #4977717
01/13/19 08:36 AM
01/13/19 08:36 AM
Minnesota
philipp10 Offline
philipp10  Offline
Minnesota
Why not just "lay" the bike on it's side once in a great while to re-lube the bushing? Is the bike big? Heavy? And if the tranny fluid is not getting to this bushing, what makes you think a grease will get washed away?
Re: Need grease for a bushing in a trans with a wet clutch and atf [Re: philipp10] #4977787
01/13/19 09:57 AM
01/13/19 09:57 AM
California
California
No, its a motocross bike, quite easy to lay on its side.
I was thinking that already,
I was also thinking it wont wash standard grease away, but that the trans gel or vasoline will just melt away and drip out right away
Re: Need grease for a bushing in a trans with a wet clutch and atf [Re: englertracing] #4977911
01/13/19 12:41 PM
01/13/19 12:41 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I am thinking Molykote 3451 would be just what the job calls for.
Edit: Link to info pdf 3451
https://www.amazon.com/Dow-Corning-Molykote-Chemical-Resistant/dp/B00CB6A22M
Re: Need grease for a bushing in a trans with a wet clutch and atf [Re: englertracing] #4978033
01/13/19 03:02 PM
01/13/19 03:02 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
what if you replaced the bushing with a sintered bronze one that has oil in it?
Thick oil is better grin2
Re: Need grease for a bushing in a trans with a wet clutch and atf [Re: andyd] #4978132
01/13/19 05:38 PM
01/13/19 05:38 PM
California
California
Well im a but tired of waiting on the back ordered mainshaft, the bushing comes pressed in and is not avaliable seperately.
I have some bushing bronze, and a lathe.
Dont have any "oilite" or stintered bronze
Re: Need grease for a bushing in a trans with a wet clutch and atf [Re: englertracing] #4979383
01/14/19 09:05 PM
01/14/19 09:05 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
One afternoon about 1964, I watched my brother cut a pilot bushing from a piece of brass pipe on a lathe grin2
Re: Need grease for a bushing in a trans with a wet clutch and atf [Re: englertracing] #5036035
03/08/19 01:23 PM
03/08/19 01:23 PM
Lakeside CA
another Todd Offline
Lakeside CA
Why not use stock parts and a better oil? If it must be ATF, try a synthetic ATF. Personally I would try a different lube than ATF.
2015 Ford F250 Diesel Crew Cab FX4
2017 Ford Escape 2.0
2002 GMC Yukon
2015 Hyundai Accent
2008 Yamaha Rhino 700 FI
