Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
Oil weight and FM
by Brian553. 01/22/19 01:07 PM
New Bridgestone Blizzak WS90
by SubLGT. 01/22/19 12:59 PM
Southwest Airlines slides off runway
by JustN89. 01/22/19 12:55 PM
phenolic caliper pistons
by bionictony. 01/22/19 12:31 PM
SS snowblower auger to scraper gap?
by dwcopple. 01/22/19 11:47 AM
PP HM 10W-30 at Walmart for $15
by 28oz. 01/22/19 11:30 AM
2012 Camry ATF change- now or later?
by TmanP. 01/22/19 11:20 AM
Oil sampling tube
by kevmor99. 01/22/19 10:00 AM
Gas trimmers
by weeksjake. 01/22/19 09:11 AM
Supertech Heavy Duty 15W40 ...$9.64
by dblshock. 01/22/19 08:53 AM
Trooper recommends dash cameras
by FordBroncoVWJeta. 01/22/19 07:14 AM
New Harley synthetic 80w-140 gear released
by shanneba. 01/22/19 06:43 AM
Registering a Vacation Car
by ssamaroo01. 01/22/19 06:23 AM
Sam002, Binco, Coolbreez1973, jmcast1127, DF8005
67010 Registered Users
116 registered members (28oz, 4WD, 928, 240_Ed, anndel, 14 invisible), 2,250 guests, and 33 spiders.
Topics296,983
Posts4,962,896
Members67,010
Most Online2,821
Jan 21st, 2019
1998 olds w/V6 3800 motor #4977165
01/12/19 03:27 PM
01/12/19 03:27 PM
Illinois
Mark72 Offline OP
Mark72  Offline OP
Illinois
I recently acquired a 98 Olds with V6 38000. Has 146000 miles on it. Intake gaskets and valve cover gaskets all new. The engine specs for 10w 30 from 0 degrees and above and 5W30 from 60 degrees and below. Do you think there should be any issue running synthetic in it? My guess is that its had conventional oil up until now.
Re: 1998 olds w/V6 3800 motor [Re: Mark72] #4977173
01/12/19 03:37 PM
01/12/19 03:37 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
First off....why do you want to use Synthetic ?
Re: 1998 olds w/V6 3800 motor [Re: Mark72] #4977178
01/12/19 03:44 PM
01/12/19 03:44 PM
Buffalo, NY
Nickdfresh Offline
Nickdfresh  Offline
Buffalo, NY
Why not?
Yes, it would be fine with syn. It runs well on anything, I used MaxLife blend a lot on my old one...
Re: 1998 olds w/V6 3800 motor [Re: Mark72] #4977192
01/12/19 04:03 PM
01/12/19 04:03 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
If no leaks, Mobil 1 HM 5w30.
2015 Hyundai Sonata 2.4L 90k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 232k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: 1998 olds w/V6 3800 motor [Re: Mark72] #4977194
01/12/19 04:05 PM
01/12/19 04:05 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
Pics, please. A thread regarding acquisition of such a forum favorite requires them!
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: 1998 olds w/V6 3800 motor [Re: Mark72] #4977197
01/12/19 04:09 PM
01/12/19 04:09 PM
Maricopa, Arizona
dave1251 Offline
dave1251  Offline
Maricopa, Arizona
Anything you use will be an improvement from anything recommended in 1998.
don't use.
Re: 1998 olds w/V6 3800 motor [Re: Mark72] #4977223
01/12/19 04:47 PM
01/12/19 04:47 PM
Raleigh NC
MrMoody Offline
MrMoody  Offline
Raleigh NC
Best value in a used beater: anything with a 3800 Series II in it. You can buy them for a little of nothing (IMO because they are out of style "grandpa" cars) and they are almost bulletproof. The trans is the weak link. How's yours? Sloppy, slow, inconsistent shifting can usually be cured in the pan with a TransGo kit.
I've been running M1 10W30 in mine for years (but we never get below 0). High Mileage will turn black very quickly if the engine is dirty inside.
Recently the timing cover crank seal has started leaking, which has now destroyed the rubber in the motor mount under it. This is a project for next summer.
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
Re: 1998 olds w/V6 3800 motor [Re: Nickdfresh] #4977225
01/12/19 04:52 PM
01/12/19 04:52 PM
Kansas
ejes Offline
ejes  Offline
Kansas
Originally Posted by Nickdfresh
Why not?
I did the same with the one I had. It was the perfect oil for it. Stopped up the weeping on the seals pretty much.
Re: 1998 olds w/V6 3800 motor [Re: Mark72] #4977249
01/12/19 05:26 PM
01/12/19 05:26 PM
Indy
69Torino Offline
69Torino  Offline
Indy
That engine will thrive on anything with a starburst on the bottle. Enjoy the car til the trans dies.
1969 Ford Torino GT 390 Auto
2003 Mercury Marauder
1992 Mercury Capri Convertible
2005 Ford Freestyle
2008 Hyundai Santa Fe
2015 Kia Optima
1947 Ford 2N
1978 Honda XL75
Plus Other Stuff...
Re: 1998 olds w/V6 3800 motor [Re: Mark72] #4977259
01/12/19 05:40 PM
01/12/19 05:40 PM
Illinois
Mark72 Offline OP
Mark72  Offline OP
Illinois
Yes..the engine runs and sounds like its brand new. The transmission seems like it has no issues. According to the car facts this car has seen highway most of its life which equates to only 50,000 miles worth of wear really. Car is ugly as [censored] but in mint condition . Only rust is the exhaust and a little on the rails underneath. It's more quiet and comfortable than our 2017 Pacifica
Re: 1998 olds w/V6 3800 motor [Re: Mark72] #4977295
01/12/19 06:17 PM
01/12/19 06:17 PM
Suburban Washington DC
atikovi Offline
atikovi  Offline
On a 20 year old 146,000 mile Illinois car? You haven't looked hard enough.
Re: 1998 olds w/V6 3800 motor [Re: Nickdfresh] #4977341
01/12/19 07:17 PM
01/12/19 07:17 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Why not?
The number 1 reason to use Synthetic is longer OCI. Plus an older car like that may leak after using Synthetic.
Re: 1998 olds w/V6 3800 motor [Re: Mark72] #4977367
01/12/19 07:37 PM
01/12/19 07:37 PM
St. Charles County, Missouri
csandste Offline
csandste  Offline
My step son bought a 98 LeSabre for a few hundred a year and a half ago. Had an inoperative blend door which made it pleasant only in spring and fall. That 3800 was a great engine, though. I would think MaxLife 5-30 would be perfect for this car, that weight is a lot better than it was a generation ago.
2017 Kia Soul Plus-- VWB 5-30, 54,000 miles.
Re: 1998 olds w/V6 3800 motor [Re: atikovi] #4977417
01/12/19 08:36 PM
01/12/19 08:36 PM
Indy
69Torino Offline
69Torino  Offline
Indy
Like at the brake and fuel lines. Especially if it has rocker rot. Brake and fuel lines are notoriously troublesome on W-bodies. It’s worth looking at just to be safe.
2005 Ford Freestyle
2015 Kia Optima
1947 Ford 2N
1978 Honda XL75
Plus Other Stuff...
Re: 1998 olds w/V6 3800 motor [Re: Mark72] #4977432
01/12/19 08:44 PM
01/12/19 08:44 PM
Chicago Suburbs
Nitronoise Offline
Nitronoise  Offline
Chicago Suburbs
wI have a 2000 regal with the LS 67 3800
ryn QS full syn
car has a tune , down pipes qand under driive pulleys so far
I have been known to thrash on it and have had no problems running full syn
car gets parked in the winter as it came from Georgia ,,,
and the trans is is fresh as the overdrive shaft has been known to fail
07 Ford Freestyle 135K
06 Honda Acord EX 115K
04 Hyundai Sonata 290K sold
03 Hyundai Santa Fe 165K
02 Ford Tarus 98K
00 Buick Regal SC 135K
95 Goldwing 28K
