Arlen Ness passes
by 02SE. 03/24/19 03:15 AM
Plants - they learn and remember
by Shannow. 03/24/19 03:02 AM
Rotella Gas Truck
by jpstiles02. 03/24/19 02:53 AM
The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
What's in Maxima oil?
by Truckedup. 03/23/19 06:29 PM
2015 Acura TLX 3.5L V6
by blackdiamond. 03/23/19 06:20 PM
GSXRBullwinkie, Mark1970, FixItDad28, RandomJoe, Sciascia
67599 Registered Users
37 registered members (BobFout, berlyn, billt460, AurionX2, Astro14, 4WD, 6 invisible), 655 guests, and 54 spiders.
Topics286,323
Posts4,906,447
Members67,599
Most Online2,967
Mar 10th, 2019
Dunking new Hydr, lifters in hypoid gear oil? #4976879
01/12/19 11:05 AM
01/12/19 11:05 AM
Balearic Islands , Spain
FordCapriDriver Offline OP
I am planning to change the hydraulic lifters in my Escort's engine as i'm getting tired of the constant Rattling noise they make.
I have a Haynes manual for it, and before fitting the new hydraulic tappets they recommend placing them in Hypoid gear oil for between 24-72h before fitment.
Any idea as to why they would recommend Hypoid gear oil versus engine oil? i do happen to have some left over EP90 Gear oil that i could use.
[Linked Image]CVH by Argentum Enim in Sempiternum, en Flickr
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: Dunking new Hydr, lifters in hypoid gear oil? [Re: FordCapriDriver] #4976915
01/12/19 11:42 AM
01/12/19 11:42 AM
Virginia
Dufus2 Offline
Dufus2  Offline
Virginia
It sounds like the EP additives in gear oil for the start up and break in period. I just use an oil can and pump it in the small hole until oil pushes out the top and install the lifters in the engine, much faster than soaking them or trying to pump the air out. I also just use 30w oil and never had any problem
ASE Certified in Med/Heavy Truck Service including A9
Heavy Equipment Repair, Fleet Maintenance
Real Cars Rattle and Smoke a Little
Re: Dunking new Hydr, lifters in hypoid gear oil? [Re: FordCapriDriver] #4977035
01/12/19 01:53 PM
01/12/19 01:53 PM
Raleigh NC
MrMoody Offline
MrMoody  Offline
Raleigh NC
IMO they should also be cleaned with some sort of solvent first, to remove any manufacturing debris.
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
Re: Dunking new Hydr, lifters in hypoid gear oil? [Re: FordCapriDriver] #4977187
01/12/19 04:57 PM
01/12/19 04:57 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Naw I would not do that. Today we have break in oils and assembly lubes. Use those instead.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Dunking new Hydr, lifters in hypoid gear oil? [Re: Dufus2] #4977349
01/12/19 08:23 PM
01/12/19 08:23 PM
Fort Lauderdale, FL
DoubleWasp Online content
DoubleWasp  Online Content
Fort Lauderdale, FL
Best way to do it.
Re: Dunking new Hydr, lifters in hypoid gear oil? [Re: FordCapriDriver] #4977652
01/13/19 04:30 AM
01/13/19 04:30 AM
I have friend who did the same thing to his engine and simply had them in engine oil for 72h so they would be full of oil already on start up and had no problems.
Re: Dunking new Hydr, lifters in hypoid gear oil? [Re: FordCapriDriver] #4978727
01/14/19 09:51 AM
01/14/19 09:51 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I would use engine oil , also . Are they roller lifters ?
Wyr
God bless
Re: Dunking new Hydr, lifters in hypoid gear oil? [Re: Dufus2] #4978734
01/14/19 09:57 AM
01/14/19 09:57 AM
out there
spasm3 Offline
spasm3  Offline
out there
What I have done. I use oil mixed with Schaeffer's 132 for lifters and installing piston rings.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Dunking new Hydr, lifters in hypoid gear oil? [Re: FordCapriDriver] #4979053
01/14/19 03:22 PM
01/14/19 03:22 PM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
Soak in engine oil.
smear with assembly lube.
But if it's new lifters on old cam, it often doesn't go well.
Because sometimes the simple things in life...
...simply don't know any better
Re: Dunking new Hydr, lifters in hypoid gear oil? [Re: FordCapriDriver] #4979162
01/14/19 05:00 PM
01/14/19 05:00 PM
California
nthach Offline
nthach  Offline
California
I haven't done any internal engine repair, but my brain says gear oil might be a bad idea for the lifters when they pump up on startup. I'd use whatever engine oil you have on hand and follow any FSM procedures, some lifters shouldn't be "pumped up" during install!
Re: Dunking new Hydr, lifters in hypoid gear oil? [Re: Shannow] #4979976
01/15/19 01:21 PM
01/15/19 01:21 PM
Originally Posted by Shannow
Soak in engine oil.
Don't worry, i know exactly what i'm doing, i've asked various people on wether it's worth doing and according to people who have done it ( changing the hydraulic tappets ) it IS worth doing and it does make these engines ( Ford CVH ) much quieter.
Re: Dunking new Hydr, lifters in hypoid gear oil? [Re: FordCapriDriver] #4980814
01/16/19 09:12 AM
01/16/19 09:12 AM
South Carolina
ka9mnx Offline
ka9mnx  Offline
South Carolina
Put new lifters on an old cam in the F150 at 185k miles (flat tappet hydraulics). Still running fine at 255k miles. I heard it was the other way around. Old lifters on new cam will wipe it out pretty quick. Never heard of soaking lifters in hypoid gear oil. Always engine oil.
2005 Ranger 3.0 - M1 HM 5w-30/Motorcraft - (85+K)
2000 4Runner 3.4 - M1 HM 10w-30/Toyota - (250+K)
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar - (175+K)
1993 F150 4.9 - M1 HM 10w-30/Motorcraft - (250+K)
Re: Dunking new Hydr, lifters in hypoid gear oil? [Re: FordCapriDriver] #4981868
01/17/19 12:40 AM
01/17/19 12:40 AM
New Zealand
Silk Offline
Silk  Offline
New Zealand
It's the recommended proceedure, and you've got the oil...um,so do what they say.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - 5W-40 Castrol Magnatec diesel.
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
