Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
32 registered members (2015Corolla, 4WD, Bailes1992, billt460, 5 invisible), 514 guests, and 57 spiders.
Topics286,442
Posts4,908,266
Members67,622
Most Online2,967
Mar 10th, 2019
Gas boiler frustrations #4976821
01/12/19 09:53 AM
01/12/19 09:53 AM
Lyndhurst NJ
Audios Offline OP
Audios  Offline OP
Lyndhurst NJ
Just ranting. Lost heat on Sunday night with our 25 year old Weil-Mclean NG boiler. Woke up to 61 in the house. Pilot ok, spark ok, vent dampner works properly. Turn the valve off, lose pilot, turn it back on, immediate pilot. Pilot is baking the flame sensor. OK NBD, ordered the flame sensor to start, its dated 1991 so why not, 150$ and overnight shipping. Swapped it out, no change. OK time to get the guy here. He takes a look and confirms its the gas valve....which is NLA. I called the supply house that I got the flame sensor from. I gave them the part number and they had only one updated option. Ordered it, got it on thursday and took a look. 3/4" in and out, mine is 1/2". My burner is 110k btu, this valve is rated at 250k lowest, up to 440. So of course that wont work safely, and now Im stuck replacing the whole unit on an emergency call for Saturday, with the highs looking to be 30 all next week, forcing my hand to a unit thats locally in stock. Peerless wouldnt be in until tuesday earliest, so we went with a Williamson to get the ball rolling. Frustrating when a "simple" 500$ fix turns into $5k. There were Honeywell update kits that would have been in mid week, however I dont know if the heating guys have had any experience updating these units, and it would be another week down with space heaters. /endrant.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Gas boiler frustrations [Re: Audios] #4976853
01/12/19 10:30 AM
01/12/19 10:30 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
I've used Patriot supply.. Should have been able to get a valve for that I would think easier than a new install! I have oil burner and they need constant attention.to ensure a proper burn and decent efficiency. The older boilers should be good for 35 years service at least. Just require component replacement now and then.
Good luck!
No fun loosing heat when it gets really cold. I have a wood stove backup that can heat the whole 2 story LOg Cabin with no wall insulation to 90degF in sub zero weather. BTW, It was 8degF this morning here in the northeast U.S. with high winds. Again, good luck getting some heat!
2019 VW Jetta S,6M OCI#0 2103mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Gas boiler frustrations [Re: Audios] #4976899
01/12/19 11:30 AM
01/12/19 11:30 AM
Lyndhurst NJ
Audios Offline OP
Audios  Offline OP
Lyndhurst NJ
Yea the valve is discontinued, and they only offered Honeywell updates that "should" work. The vale I ordered was way too big, and they didnt want to step down the fittings since they have no way of controlling the flow. The old valve was a variable flow knob, this one is just on off toggle switch.
Re: Gas boiler frustrations [Re: ARCOgraphite] #4976903
01/12/19 11:34 AM
01/12/19 11:34 AM
Michigan
Kjmack Offline
Kjmack  Offline
Michigan
Good luck!
I love log cabins, any chance you will post some pictures of it someday ?
Re: Gas boiler frustrations [Re: Audios] #4976921
01/12/19 11:51 AM
01/12/19 11:51 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
The repair guy told me the new gas boilers that hang on the wall are great unit they break and then it's a $1000 part rather than a $100 part on an old style boiler.
2015 Ford F250 w/Powerstroke
Re: Gas boiler frustrations [Re: Audios] #4976938
01/12/19 12:20 PM
01/12/19 12:20 PM
Peace valley, Missouri
Fitter30 Offline
Fitter30  Offline
I would of use the new valve. Gas pressure is set by the regulator in the valve 3.5" and the the amount of gas entering the burners is set by the orfices at each burner. What is the model number of the new valve?
Re: Gas boiler frustrations [Re: Audios] #4976986
01/12/19 01:08 PM
01/12/19 01:08 PM
Lyndhurst NJ
Audios Offline OP
Audios  Offline OP
Lyndhurst NJ
The larger valve was White-rodgers 36C84-923, my original ended in -913 I think, its in the garbage now.... The tech that was there couldnt guarantee the fitment, and I couldnt gamble on it not working and then needing another 3-5 days for boiler to arrive and install. Currently watching the temp rise in here, they just finished the install, about 3.5 hours start to finish. It was a Genesis 110k unit that went in, owned by Williamson?
Re: Gas boiler frustrations [Re: Audios] #4977011
01/12/19 01:25 PM
01/12/19 01:25 PM
massachusetts
wog Offline
wog  Offline
massachusetts
Williamson was owned by weil mclain years back,wm makes good product. I prefer standing pi lots no guess if it conks out,keep it simple. Enjoy the new boiler!
Re: Gas boiler frustrations [Re: Audios] #4977018
01/12/19 01:32 PM
01/12/19 01:32 PM
Fernandina Beach FL
Dan55 Offline
Dan55  Offline
Fernandina Beach FL
I had a similar situation back in the 90’s, pilot sensor NLA, gas valve NLA, on a 10 yr old boiler. The only part available to me locally was used and did not work. A new gas valve and controls would be $500. After numerous phone calls in the Tri state area I was directed to Charles Connelly in Lyndhurst NJ. For $100 I got a Honeywell Flame Rectification kit ,it kept my boiler going til I sold in 2010. http://www.connollydist.com
2016 Lexus NX200T 2017 Mustang Conv Eco Prem
Re: Gas boiler frustrations [Re: Audios] #4977080
01/12/19 03:03 PM
01/12/19 03:03 PM
Lyndhurst NJ
Audios Offline OP
Audios  Offline OP
Lyndhurst NJ
Small world, I own a shop less than a mile from there. I actually went there after my heating guy called to check the part. I live about 5 miles away so I went down there and showed them, nothing listed at all. Supplyhouse.com actually was helpful, although they were only able to source the larger valve and couldnt verify the fit, which I had to return.
Re: Gas boiler frustrations [Re: Donald] #4977101
01/12/19 03:32 PM
01/12/19 03:32 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Same with gas fired tankless water heaters.
They are amazing devices - but almost cheaper to replace than repair.
Re: Gas boiler frustrations [Re: Donald] #4977140
01/12/19 03:58 PM
01/12/19 03:58 PM
NY
Kage860 Offline
Kage860  Offline
NY
That makes me feel better that I signed a contract to convert my boiler to gas rather than get one of the more efficient on the wall instant units. I'm converting a Beckett oil burner to a Carlin gas burner. I like going with stuff the local supply house has parts for in case a part goes out.
2007 Jeep Liberty PP 0w-20 / Carquest Blue, 6k oci
2015 Nissan Rogue PP 0w-20 / Pronto, 5k oci
2019 Audi Q7 - Castrol 5w-40 / OEM Filter
Re: Gas boiler frustrations [Re: Audios] #4977149
01/12/19 04:07 PM
01/12/19 04:07 PM
Raleigh NC
MrMoody Offline
MrMoody  Offline
Raleigh NC
Maybe not directly relevant to this case, but one thing I've discovered over the last couple decades is that when it comes to HVAC, NO ONE wants to repair anything. You need a new unit. We'll gladly quote one for you.
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
Re: Gas boiler frustrations [Re: Audios] #4977204
01/12/19 05:21 PM
01/12/19 05:21 PM
MA
Wolf359 Online content
Wolf359  Online Content
MA
Do you have Burnham in your area? That's pretty much what I see in this area in terms of gas boilers. Weil-Mclean, Peerless and a bunch of other smaller brands make up the rest. But the difference is that if you call up a plumber most of them will know how to fix a Burnham and most supply houses here have them.
Re: Gas boiler frustrations [Re: MrMoody] #4977275
01/12/19 06:56 PM
01/12/19 06:56 PM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
In other words, it's the same as when you have a transmission problem.
