Interesting. For whatever reason(s) Wix has avoided using their traditional thread end bypass on the 820S equivalent. One thought was it might have had something to do with patent rights. I think an FCA Mopar application similar. Thread end on Mopar, Wix dome end.
Also notice topic filter uses center tube holes, Wix/Napa Gold have been gradually switching to louvered use, eg., 5/7356. Also notice imprinted date code and white can. Former something new-ish and ime white can used at start of a newer design. Original 57356 started out white with dome bypass, now back to traditional thread end with standard black. Wix online cat shows black for topic.
If this is new standard 51372, if pattern follows no reason to believe the NG 1372 won't be the same.
While this change will be especially desirable for persnickety FoMoCo owners here, not a huge deal 'imo' over dome end. However it will make it one the few if not only aftermarket filter in this tier with separate thread end bypass, same as Motorcraft.
Thanks for pics.
