Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
Some good modern rock songs
by 53' Stude. 01/19/19 03:51 PM
06 Pathfinder O2 sensor voltage sensor 1
by Bluestream. 01/19/19 03:50 PM
Honda Blue Coolants
by redhat. 01/19/19 03:49 PM
Let's talk about some of the other NHL teams
by 53' Stude. 01/19/19 03:45 PM
coolants for 1965 imperial
by ted s. 01/19/19 03:35 PM
Where to get real Dexron III ?
by das_peikko. 01/19/19 02:40 PM
Dexcool + Prestone AMAM Mix
by George7941. 01/19/19 02:31 PM
Questions about Maverik gas
by MRtv. 01/19/19 01:25 PM
Anyone Taking Superfoods ?
by Warstud. 01/19/19 12:55 PM
Permatex High Tack (80062)
by TheLawnRanger. 01/19/19 12:29 PM
A little warm down in Oz.
by Snagglefoot. 01/19/19 12:03 PM
Supertech 6607 - 7300 miles - 2017 Legacy
by MrWideTires. 01/19/19 10:21 AM
ejmiller, _THOR_, Captmorgan2112, TreadMonster, Snachlift500
66978 Registered Users
91 registered members (AdditiveOCD, 4WD, 28oz, 69Torino, A310, 11 invisible), 1,959 guests, and 36 spiders.
Topics296,850
Posts4,960,145
Members66,978
Most Online2,688
Jan 19th, 2019
Possibly the ultimate Harley oil? #4975827
01/11/19 08:13 AM
01/11/19 08:13 AM
Montana
Reltor Offline OP
Reltor  Offline OP
Montana
This is made by Lucas in a conventional and Semi-Synthetic from what I have seen. It is pricy but the ZDDP levels are super high. I may try it in the spring. My bike is older...no cats.
https://lucasoil.com/products/marin...xtreme-duty-marine-sae-20w-50-engine-oil
The conventional is around $10/qt and the semi-syn around $17/qt
Re: Possibly the ultimate Harley oil? [Re: Reltor] #4975835
01/11/19 08:30 AM
01/11/19 08:30 AM
Lakeside, CA
Blkstanger Offline
Blkstanger  Offline
Lakeside, CA
Harleys don't need a ton of ZDDP. They have roller bearings everywhere. And roller lifters. And stock Harley engines are far from "high performance". I ran Redline 20w60 for many years in both my Big Twin Harleys. Had 80,000 miles on the Black one when it was totaled.
99 Jeep WJ 4.7 195,000 Maxlife 10w30, Fram Ultra.
Re: Possibly the ultimate Harley oil? [Re: Reltor] #4975857
01/11/19 09:03 AM
01/11/19 09:03 AM
Michigan
Diesel12 Offline
Diesel12  Offline
Michigan
Not a bad looking oil except take a look at the CCS Viscosity at -15C its 9500cp. i bet that oil has a crappy pour point thats why they dont post it.
Compare it to Schaeffer 20w-50 V-twin which the same test at the same temp resulted in 3500cp. Also has a stable pour point of -41F.
Here is the data sheet for Schaeffer V-twin 20w50 https://www.schaefferoil.com/documents/229-707-td.pdf
1998 Dodge Neon-Rebuilt 2.4L-Schaeffer 5w40
2014 Dodge Durango 3.6, 56K- Schaeffer 5w-20
2002 Ram 2500 Cummins 125K- Schaeffer 5w-40
2008 Dodge Avenger 220K Schaeffer 5w-20
Re: Possibly the ultimate Harley oil? [Re: Reltor] #4976225
01/11/19 02:36 PM
01/11/19 02:36 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Mystik 15W-50 is what i get locally (and VERY inexpensively) and the it has been giving OUTSTANDING used oil analyses on here
[Linked Image]
Re: Possibly the ultimate Harley oil? [Re: Diesel12] #4976273
01/11/19 03:32 PM
01/11/19 03:32 PM
Somewhere in time
Imp4 Offline
Imp4  Offline
Somewhere in time
And tell me again why you care about low temperature performance in this application????
I think what you have stated here may be both true and irrelevant.
2001 Mitsubishi Galant 2.4 - 160k+
Grandma's creampuff...
Re: Possibly the ultimate Harley oil? [Re: Reltor] #4976318
01/11/19 04:43 PM
01/11/19 04:43 PM
New England
Jarlaxle Offline
Jarlaxle  Offline
New England
Maybe because some people do actually ride in cooler weather? Especially in Michigan.
1979 Coupe de Ville, 542 stroker, winter storage frown
2011 Crown Vic P71, 5W-20 Super Tech, Super Tech
2011 Sportster 883, winter storage frown
Re: Possibly the ultimate Harley oil? [Re: Reltor] #4976415
01/11/19 06:30 PM
01/11/19 06:30 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Would not anything with more than 1200 ppm ZDDP cause impurities /sludge in the engine?
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Possibly the ultimate Harley oil? [Re: Jarlaxle] #4976505
01/11/19 08:12 PM
01/11/19 08:12 PM
Somewhere in time
Imp4 Offline
Imp4  Offline
Somewhere in time
Call me back when you're riding at below 0°C.
Otherwise...
Re: Possibly the ultimate Harley oil? [Re: Reltor] #4976700
01/12/19 05:46 AM
01/12/19 05:46 AM
New England
Jarlaxle Offline
Jarlaxle  Offline
New England
My coldest was 3 C a couple years ago...bike was fine. (Oil was 10W-40.) I suspect my current bike (with conventional 20W-50) might not be.
Re: Possibly the ultimate Harley oil? [Re: Reltor] #4976985
01/12/19 12:08 PM
01/12/19 12:08 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
That's a high performance Marine oil. It's made more like an SAE 50 for shear resistance. They don't care about cold weather operation, because a high performance boat is not going to be subjected to that.
Pour point depressants are usually left on the shelf.
Re: Possibly the ultimate Harley oil? [Re: Reltor] #4980719
01/16/19 05:52 AM
01/16/19 05:52 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
Hard to comment on the OP as there is no mention of what year and model his Harley is.
Being there are so many, for me, I try to stick to the recommended type of oil.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
