Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
Oil weight and FM
by Brian553. 01/22/19 01:07 PM
New Bridgestone Blizzak WS90
by SubLGT. 01/22/19 12:59 PM
Southwest Airlines slides off runway
by JustN89. 01/22/19 12:55 PM
phenolic caliper pistons
by bionictony. 01/22/19 12:31 PM
SS snowblower auger to scraper gap?
by dwcopple. 01/22/19 11:47 AM
PP HM 10W-30 at Walmart for $15
by 28oz. 01/22/19 11:30 AM
2012 Camry ATF change- now or later?
by TmanP. 01/22/19 11:20 AM
Oil sampling tube
by kevmor99. 01/22/19 10:00 AM
Gas trimmers
by weeksjake. 01/22/19 09:11 AM
Supertech Heavy Duty 15W40 ...$9.64
by dblshock. 01/22/19 08:53 AM
Trooper recommends dash cameras
by FordBroncoVWJeta. 01/22/19 07:14 AM
New Harley synthetic 80w-140 gear released
by shanneba. 01/22/19 06:43 AM
Registering a Vacation Car
by ssamaroo01. 01/22/19 06:23 AM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
124 registered members (28oz, 4x4le, ABerns, 53' Stude, 12 invisible), 2,370 guests, and 33 spiders.
Topics296,983
Posts4,962,957
Members67,013
Most Online2,821
Jan 21st, 2019
Toyota red in GM 3800? #4976649
01/12/19 01:00 AM
01/12/19 01:00 AM
Martinsburg West Virginia
71Chevyguy Offline OP
Any harm in using Toyota Red in a 3800? I don't imagine it is anywhere near as harsh as dexcool. Just wasn't sure how it would do with the cast iron engine since most Toyota stuff is aluminum. I'm thinking it would be fine since these vehicles aren't picky but figured I would ask. Anyone aware of some bad reaction I should be aware of? Hard to pass up on clearance at Autozone, but should be able to return it in case it is a bad idea. Would be going into a 97 Regal GS L67 with all new cooling system, since it sprung a leak in the radiator. Thanks for your help guys!
18 Focus 1.0 Valvoline Modern Engine 0w20 / STP XL filter
99 VW Beetle TDI M1TDT / Mann filter
98 Buick LeSabre Kendall HM Ti 5w30 GF4 / Bosch Dist+
85 Skylark 2.5
71 Nova 250
Re: Toyota red in GM 3800? [Re: 71Chevyguy] #4976654
01/12/19 01:16 AM
01/12/19 01:16 AM
WA
SnowDrifter Offline
SnowDrifter  Offline
WA
It'll be fine so long as you do a thorough cleaning of the cooling system.
I'm running honda blue in my chevy right now. Swapped out dex cool for universal, then went from that to the honda stuff in the interest of avoiding the ethylhexanoic acid present in OAT coolants
2005 Tahoe - 135k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
Re: Toyota red in GM 3800? [Re: 71Chevyguy] #4976671
01/12/19 02:07 AM
01/12/19 02:07 AM
Balearic Islands , Spain
FordCapriDriver Offline
I've been doing some research and apparently, Dexcool and its various clones, are the only OAT coolants that contain 2-Eha these days, the P-OAT coolants used by Asian manufacturers or Si-OAT coolants used by the VW Group do not have it.
It also seems like not only is 2-Eha harmful to silicone hoses, you see OAT coolant have been accused of not protecting older types of solder well, it seems like 2-Eha and Octanoic acids are the main culprit of that ( according to the book "Engine Coolant Testing" from 1993 )
Toyota red is a Phosphate buffered OAT coolant so as long as your owners manual doesn't say it requires Phosphate free coolant you're probably fine.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort Mk4 Xr3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Finnish expat in Spain.
Re: Toyota red in GM 3800? [Re: 71Chevyguy] #4977105
01/12/19 02:35 PM
01/12/19 02:35 PM
Fernandina Beach FL
Dan55 Offline
Dan55  Offline
Fernandina Beach FL
Toyota Red has a reduced service life 2 yrs 30k. Not worth it imho, unless you don’t mind changing fluid every 2 yrs,better options out there . Peak Global Lifetime is a favorite on this site.
2016 Lexus NX200T 2017 Mustang Conv Eco Prem
Re: Toyota red in GM 3800? [Re: 71Chevyguy] #4977617
01/13/19 01:42 AM
01/13/19 01:42 AM
If it were mine i'd run Zerex G40 in it smile
Re: Toyota red in GM 3800? [Re: FordCapriDriver] #4977921
01/13/19 11:50 AM
01/13/19 11:50 AM
Yeah, I agree with you. If I were to just go out and choose one for the car it would be the VW equivalent stuff. Very similar to dexcool without the nonsense. I didn't realize the Toyota red was the short interval stuff or I wouldn't have gotten it, I was probably thinking of the Toyota Pink. I guess I could use it in my 85 Buick instead of the standard old school green though. I will probably return this stuff and get something else.
85 Skylark 2.5
71 Nova 250
