CV Joint Leaking Grease
by 92saturnsl2 - 08/22/19 10:20 PM
Craftsman 6 pc. Screwdriver Set $12.14
by Warstud - 08/22/19 09:32 PM
Got My ATF Replaced.
by Mr_Luke - 08/22/19 09:20 PM
Wht do people with labor intensive jobs lay on their back?
by motor_oil_madman - 08/22/19 09:14 PM
Date code 5 Q Chevron location?
by Onetor - 08/22/19 08:06 PM
Confused, what oil to use?
by BelAir - 08/22/19 08:00 PM
2015 KIA optima turbo Coolant Flush
by Grambo - 08/22/19 07:52 PM
Motul 300V -- oops
by xr650boy - 08/22/19 06:35 PM
Evolution of Garbage Trucks...joke thread
by GumbyJarvis - 08/22/19 05:57 PM
What is this Oil's Application?
by MolaKule - 08/22/19 05:19 PM
Ford 2.5L Engine and 6F35 Transmission
by drh214 - 08/22/19 04:57 PM
Fram XG7317 vs XG3593A
by gamefoo21 - 08/22/19 03:59 PM
Carquest premium 85334
by SlavaB - 08/22/19 03:47 PM
Oil for a Ford 2.8 L Cologne V6
by ford4wd08 - 08/22/19 03:46 PM
Good Question?🤔
by Mad_Hatter - 08/22/19 01:40 PM
Autozone misinformation?
by NavyVet88 - 08/22/19 11:23 AM
Did I mess up getting a civic that sat?
by Kurtatron - 08/22/19 10:48 AM
What are these two things in the bumper?
by atikovi - 08/22/19 09:48 AM
Amsoil Metal Protector
by Snagglefoot - 08/22/19 09:07 AM
AF_VET, oilq, Nesss, Robto, Chaparro_trucker
69028 Registered Users
44 registered members (bbhero, burla, c502cid, BusyLittleShop, aquariuscsm, Black_Thunder, 2 invisible), 1,189 guests, and 26 spiders.
Topics293,664
Posts5,044,624
Members69,028
Most Online3,532
Jul 30th, 2019
Early 00's Caddy Deville #4976558 01/11/19 10:23 PM
F
FL-400S Offline OP
F
Money pit? Talk me out of a low mile 2002ish Cadillac. I cant help but remember the rental Deville I had around 2003, it was awesome. Part of me says forget it, you dont want to be fixing things constantly. Part of me says yayyyyssss!!! Other than maybe reliability, they are nice looking and nice driving cars.
Trying to anticipate issues...headgasket, AC recirc, window regulators? I've fixed GM windows myself multiple times. What else to look out for?
Re: Early 00's Caddy Deville [Re: FL-400S] #4976576 01/11/19 10:52 PM
1
14Accent Offline
1
As things go, if it's low mile and well cared for you're probably alright. It's going to have Cadillac quirks no matter what. You can forget about head gasket issues and the like, those were all taken care of by 2003. Beyond that, you pretty much nailed it. Window regulators are weak in those cars, but not expensive or hard to replace.
At this age, the coolant tanks are known to crack and split. They're about $90. Not that big a deal to replace.
Depending on what trim level, if it has Magneride the struts may be failing and in need of replacement. OEM is bookoo bucks, aftermarket is available. Personally, I would only consider a DTS. It's the one worth getting, and I'd be very picky about what options mine had if I were looking for one. They came with lots of different options and I would want mine loaded.
Also, don't over pay. They aren't worth that much, honestly. I paid $1,200 for my 2003 STS with only 133k on it. It needed a couple hundred in parts to get it running tip top, and it's got every option available in 2003. However, it isn't perfect. It could still use another 2-300 in repairs and eats oil like crazy. It's getting better, but these engines were babied and they shouldn't have been. It's starting to show 20-odd years later.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: Early 00's Caddy Deville [Re: FL-400S] #4976607 01/11/19 11:34 PM
2
2strokeNorthstar Offline
2
Had a 2000 Deville until 185k miles. Overall a great reliable car. List of known issues:
1. Window regulators. All will fail. Look up cotter pin mod. Easy permanent fix.
2. It will leak and burn oil at an alarming rate forever without issue.
3. Expansion tank will need replacing, usually a stuck sensor before failure from cracks.
4. Front motor mount fails constantly. I got good at replacing it. 2005 or so I heard it was fixed by going back to the old design with dog bones.
5. Coolant crossover gasket will most likely fail eventually. Starts off as a slow leak, gets worse over time. I always used dexcool and coolant supplement.
6. Dash curls up in high heat climates.
7. Fuel pump or level sensor needs replacing on most, only 1 time and is easy with access panel.
8. Replace the cam belt tensioner before it seizes the bearing and melts the cam drive pulleys. If it does $$$$.
2001 F150 5.4L 140k miles
2013 Nissan Juke Nismo 80k
2000 Honda S2000 183k
1998 BMW 328i 170k
Re: Early 00's Caddy Deville [Re: FL-400S] #4976609 01/11/19 11:41 PM
2
2
14Accent you could try the dealer fix for oil burning if you are worried. Take out spark plugs and put a couple oz. of Top Engine Cleaner down the plug holes and let sit overnight. Vacuum out or close hood and crank over but it will make a mess. Change oil. Put plugs in and start. Take on freeway, put in 2nd and floor it up to 70-75 and let off gas back to 55, repeat.
Not a permanent fix, probablem usually returns after a year or 2.
1998 BMW 328i 170k
Re: Early 00's Caddy Deville [Re: FL-400S] #4976613 01/11/19 11:47 PM
Chris142 Offline
Cars are junk! Why would you want to make your life miserable?
02 Wrangler traveler sae30
87 F250 Valvoline 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor Chevron sae30
Re: Early 00's Caddy Deville [Re: FL-400S] #4976615 01/11/19 11:51 PM
Chris142 Offline
Double post
Re: Early 00's Caddy Deville [Re: FL-400S] #4976616 01/11/19 11:51 PM
2
2
All cars are?
1998 BMW 328i 170k
Re: Early 00's Caddy Deville [Re: 2strokeNorthstar] #4976617 01/11/19 11:52 PM
Chris142 Offline
Originally Posted by 2strokeNorthstar
All cars are?
That era Cadillacs were.
Re: Early 00's Caddy Deville [Re: FL-400S] #4976621 01/12/19 12:00 AM
2
2
They were before and after as well. Drive great but quality is sub par. You have to balance your wants.
1998 BMW 328i 170k
Re: Early 00's Caddy Deville [Re: FL-400S] #4976738 01/12/19 07:56 AM
marine65 Offline
Money pit? Probably.
But if you can afford to fix the car that you really want,go for it.
You only live once,no regrets.
2018 Hyundai Elantra GT black
2018 Hyundai Elantra GT silver
yup got two of them.
Re: Early 00's Caddy Deville [Re: FL-400S] #4976765 01/12/19 08:44 AM
A
atikovi Offline
A
Unless you can get it under $1,000, avoid any Northstar before 2004 when they went to better head bolts unless you have documentation it was fixed.
Re: Early 00's Caddy Deville [Re: FL-400S] #4976769 01/12/19 08:50 AM
F
FL-400S Offline OP
F
What kind of mileage would you expect head gasket probs? What repair cost?
Re: Early 00's Caddy Deville [Re: FL-400S] #4976778 01/12/19 09:04 AM
A
atikovi Offline
A
Google "northstar head gasket problems"
Re: Early 00's Caddy Deville [Re: FL-400S] #4976789 01/12/19 09:16 AM
Chris142 Offline
My friends 02 dhs had 80k on it when his let go. You can't do the heads in the car so the whole subframe must be dropped . His cost was $8k to do this. Much of the cost was for labor to put inserts in every head bolt hole.
Re: Early 00's Caddy Deville [Re: FL-400S] #4976794 01/12/19 09:25 AM
F
FL-400S Offline OP
F
Is it sudden death or is there some warning? Low coolant for a bit first?
