Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
Some good modern rock songs
by 53' Stude. 01/19/19 03:51 PM
06 Pathfinder O2 sensor voltage sensor 1
by Bluestream. 01/19/19 03:50 PM
Honda Blue Coolants
by redhat. 01/19/19 03:49 PM
Let's talk about some of the other NHL teams
by 53' Stude. 01/19/19 03:45 PM
coolants for 1965 imperial
by ted s. 01/19/19 03:35 PM
Where to get real Dexron III ?
by das_peikko. 01/19/19 02:40 PM
Dexcool + Prestone AMAM Mix
by George7941. 01/19/19 02:31 PM
Questions about Maverik gas
by MRtv. 01/19/19 01:25 PM
Anyone Taking Superfoods ?
by Warstud. 01/19/19 12:55 PM
Permatex High Tack (80062)
by TheLawnRanger. 01/19/19 12:29 PM
A little warm down in Oz.
by Snagglefoot. 01/19/19 12:03 PM
Supertech 6607 - 7300 miles - 2017 Legacy
by MrWideTires. 01/19/19 10:21 AM
ejmiller, _THOR_, Captmorgan2112, TreadMonster, Snachlift500
66978 Registered Users
101 registered members (28oz, 69Torino, 2K2AcuraTL, 71Chevyguy, 12 invisible), 1,994 guests, and 35 spiders.
Topics296,850
Posts4,960,114
Members66,978
Most Online2,688
Jan 19th, 2019
UOA Amsoil MCF 10W-40. BMW K1600 #4976557
01/11/19 09:23 PM
01/11/19 09:23 PM
Manitoba, Canada
atc250r Offline OP
atc250r  Offline OP
Manitoba, Canada
High lead is concerning me. Bike is parked for the winter, but I’ll put on miles in spring and see what happens with the next UOA. Comments?
Re: UOA Amsoil MCF 10W-40. BMW K1600 [Re: atc250r] #4976588
01/11/19 10:08 PM
01/11/19 10:08 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Yes lead is a little high may be try Castrol 10w50. This may make it easier to read.
Re: UOA Amsoil MCF 10W-40. BMW K1600 [Re: atc250r] #4976595
01/11/19 10:14 PM
01/11/19 10:14 PM
Manitoba, Canada
atc250r Offline OP
atc250r  Offline OP
Manitoba, Canada
Thanks for the rotation
Re: UOA Amsoil MCF 10W-40. BMW K1600 [Re: atc250r] #4976941
01/12/19 11:24 AM
01/12/19 11:24 AM
Colorado, USA
Bonz Offline
Bonz  Offline
Colorado, USA
That’s a big dose of calcium and good numbers for zinc and phosphorus too.
Still wanting/trying to learn when/why calcium (3300 ppm) would be in that high of a quantity (with basically no magnesium) vs a combo of calcium and magnesium.
Mobil 1 10w40 4T runs 2000 ppm of calcium with a similar non existence of magnesium, but a decent amount of boron (162 ppm) vs basically no boron in the Amsoil. M1, by my UOA shows 1155 ppm zinc, 1007 ppm phosphorus vs the higher Amsoil numbers in the original post.
Does the presence of boron in the M1 offset the lower calcium as a detergent or does the boron help offset the lower Z/P numbers in M1 for wear protection? Both?
When I read about boron, it seems to be an anti-wear additive but also is said to have cleaning properties, but is always in lower concentrations than the other additives it may or may not be used in place of for detergency and/or anti-wear.
Thoughts?
Re: UOA Amsoil MCF 10W-40. BMW K1600 [Re: atc250r] #4980713
01/16/19 05:44 AM
01/16/19 05:44 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
Nice report, yeah, I guess if it was me seeing the lead might be a little upsetting.
If it was me, I think I would just forget about it until the next change and see what happens at the next report, since this is your first report in almost 50,000 miles you have no idea as it could have been 3 times higher and has come down very much and still coming down over the last 20,000 miles, or it could be going up too.
Either way, I wouldnt lose sleep over it since you have no history with the reports, not only that but you cant do anything to fix the higher then normal lead.
Im not big on any brand of oil, the reasons we pick oils are because of marketing and I respect Amsoil a lot but I hate the fact they put so much calcium in their oil as I do not extend oil changes and no reason for it to be there.
Im also not big on spending a lot of money on oil, to me its all marketing, I pick the right "API" and I am done, heck I still use mostly conventional/semi syn because no one has ever proved to me lower wear numbers (and I have some of the lowest) and again, I change my oil at the recommended intervals and less.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: UOA Amsoil MCF 10W-40. BMW K1600 [Re: alarmguy] #4982921
01/17/19 08:19 PM
01/17/19 08:19 PM
Manitoba, Canada
atc250r Offline OP
atc250r  Offline OP
Manitoba, Canada
Good point. Yes, I will put on some miles in spring and get another UOA done ASAP.
Re: UOA Amsoil MCF 10W-40. BMW K1600 [Re: Bonz] #4983473
01/18/19 11:52 AM
01/18/19 11:52 AM
Colorado, USA
Bonz Offline
Bonz  Offline
Colorado, USA
Thoughts?
From what alarmguy said I take it to mean calcium helps extend drain intervals by keeping good cleaning additives in there (higher TBN).
How about the balance of the additives like boron, magnesium, calcium when used in different quantities like I asked in the quoted post? Can anyone weigh in on it? Why boron vs more calcium, etc.
