Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
Some good modern rock songs
by 53' Stude. 01/19/19 03:51 PM
06 Pathfinder O2 sensor voltage sensor 1
by Bluestream. 01/19/19 03:50 PM
Honda Blue Coolants
by redhat. 01/19/19 03:49 PM
Let's talk about some of the other NHL teams
by 53' Stude. 01/19/19 03:45 PM
coolants for 1965 imperial
by ted s. 01/19/19 03:35 PM
Where to get real Dexron III ?
by das_peikko. 01/19/19 02:40 PM
Dexcool + Prestone AMAM Mix
by George7941. 01/19/19 02:31 PM
Questions about Maverik gas
by MRtv. 01/19/19 01:25 PM
Anyone Taking Superfoods ?
by Warstud. 01/19/19 12:55 PM
Permatex High Tack (80062)
by TheLawnRanger. 01/19/19 12:29 PM
A little warm down in Oz.
by Snagglefoot. 01/19/19 12:03 PM
Supertech 6607 - 7300 miles - 2017 Legacy
by MrWideTires. 01/19/19 10:21 AM
One Of The Best F-16 Performances
by billt460. 01/19/19 09:52 AM
ejmiller, _THOR_, Captmorgan2112, TreadMonster, Snachlift500
66978 Registered Users
121 registered members (53' Stude, 2K2AcuraTL, 2004tdigls, 4WD, 02z, 17 invisible), 2,007 guests, and 37 spiders.
Topics296,849
Posts4,960,080
Members66,978
Most Online2,688
Jan 19th, 2019
Page 2 of 2 1 2
Re: Remington Rem Oil w/ Teflon for general use #597460
09/08/05 11:57 PM
09/08/05 11:57 PM
Texas
HondaMan Offline
HondaMan  Offline
Texas
I'm about to try Prolix
http://www.prolixlubricant.com/
I'll let everyone know how it works.
I agree that Rem Oil is not that good of a product. I've used a few cans when I could find nothing else on the shelf.
Break Free has always been standard issue and works great. I notice that they do now have a Citrus based cleaner which is what Prolix has gone towards.
Re: Remington Rem Oil w/ Teflon for general use #597461
09/09/05 05:20 AM
09/09/05 05:20 AM
East of IGO
Steve S Offline
Steve S  Offline
East of IGO
Amsoil metal protector works real good especially when guns are stored.
Re: Remington Rem Oil w/ Teflon for general use #597462
09/09/05 03:39 PM
09/09/05 03:39 PM
NY
frank1 Offline
frank1  Offline
NY
Teflon oil is fine on the exterior surfaces of a firearm. It is not good to oil a barrel with. Teflon, and the combination of the explosion and combustion that goes on inside a firearm doesn't make a good mix.
A top gunsmith warned me against the use. Traces are left in the bore and on shooting teflon will turn to an acid which is used for etching glass, it can damage the bore and might be poisonous or a carcinogen!
His advise was Mobil 1 0W-20, or ATF.
frank1
Re: Remington Rem Oil w/ Teflon for general use #597463
09/22/05 12:28 AM
09/22/05 12:28 AM
Lower Hudson Valley, NY
LIProgun Offline
LIProgun  Offline
The claim that PTFE (Teflon) in gun oils turns in to hydrofluoric acid upon firing has been discussed and debunked in several threads on various gun boards -- at least to my satisfaction. Do searches at The High Road, The Firing Line, etc. The bottom line seems to be that in theory a few molecules of hydrogen fluoride gas could form, but it wouldn't form an acid unless you add water, and even then the quantities would be negligible.
Re: Remington Rem Oil w/ Teflon for general use #597464
12/22/05 05:24 AM
12/22/05 05:24 AM
Houston, TX
Tones Offline
Tones  Offline
Houston, TX
I have used Remoil for years for all sorts of things, including firearms. A little goes a long way. The Teflon stays put long after the oil has gone away and continues to lubricate. Especially good for locks and hinges. I have even used it to lubricate delicate electronics like tape decks with no problems.
Re: Remington Rem Oil w/ Teflon for general use [Re: tblazed] #4973747
01/08/19 10:04 PM
01/08/19 10:04 PM
Littleton, co
GarageMan Offline
GarageMan  Offline
Littleton, co
Specific to Remington gun oil ‘with teflon’…….. Remington must have fairly recently changed the ingredients/additives to this. What I am experiencing is that the ‘earlier’ versions of the oil were extremely light and would “crawl” long the surface. The newer version of the oil is thicker and does not ‘self spread’ like earlier. Also, when you shake the bottle, the earlier version creates a ‘foam’ whereas the newer version does not. Both cans/bottles say it has Teflon additive and that it’s the same oil since (some date). But it's not. In addition to that, the earlier bottles have a lighter green label than the ‘newer’ bottles. And yet, Remington claims it is the same oil they’ve been producing for many years. Has anyone else noted this? Where can I find the ‘good old stuff?’
Re: Remington Rem Oil w/ Teflon for general use [Re: 04.SPT.WRX] #4976556
01/11/19 09:22 PM
01/11/19 09:22 PM
Rapid City, South Dakota
littlehulkster Online content
littlehulkster  Online Content
Originally Posted by 04.SPT.WRX
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by mjo:
<strong> What about the teflon lube spray you can get at a bike shop for bike chains. Has anyone tried that? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">http://www.super-lube.com/product_description.htm
Been using this stuff for years. Locks, hinges, etc.
Can be a little hard to find.
Super Lube is top quality stuff, IMO. I use it for everything. Guns, fishing reels, hinges, anything that can take grease.The really nice thing is not only does it work very well, but it's also food safe, so there are no worries about any sort of toxicity from it. You could literally eat it. You wouldn't want to, I'm sure, but you could.
Re: Remington Rem Oil w/ Teflon for general use [Re: tblazed] #4977162
01/12/19 03:25 PM
01/12/19 03:25 PM
[email protected] CZ firearm factory
Marco620 Offline
Marco620  Offline
RemOil great for a wipe down exterior finish. Only use Archoil LP 4400 or Flitz bore cleaner on internals.
15' Civic 1.8 i-vtec 207,000 mi 0w20 Redline/Redline CVT/Archoil9200/TEIN/Eibach/Tanabe Sustec/Borla Exhaust/Redline Si-1/87 E0 fuel
Son of a Navy Corpsman. Support vets!
Page 2 of 2 1 2
