10K Mile Oil Change - 1.8L TSI Jetta
by SandCastle - 09/21/19 08:08 AM
Pennzoil Platinum 10w30 HTHS
by donnyj08 - 09/21/19 07:56 AM
Mortality stats
by CourierDriver - 09/21/19 07:38 AM
Is it time for a brake fluid flush?
by A_A_G - 09/21/19 03:22 AM
Take that!
by Mad_Hatter - 09/21/19 03:18 AM
02 Honda Accord V6 Aluminum Radiator
by David1 - 09/21/19 01:55 AM
Difinitive Answer for SCA, Silicates, and Diesels
by ErikLeifson - 09/20/19 11:11 PM
Quart bottle cap
by maverickfhs - 09/20/19 11:11 PM
Dexron vi
by charmer37 - 09/20/19 10:22 PM
Deposit Shield
by TheLawnRanger - 09/20/19 10:00 PM
Atlanta Airport - Excellent History
by ctechbob - 09/20/19 09:56 PM
Angry at Walmart service center
by Jetsfan421 - 09/20/19 09:52 PM
Fuel System Cleaners
by ZeeOSix - 09/20/19 09:22 PM
Milwaukee 1/2 impact
by wensteph - 09/20/19 09:10 PM
Windows 7 Use After Support Ends
by ZeeOSix - 09/20/19 08:29 PM
Walmart Poulan chainsaws 50% off
by bubbatime - 09/20/19 08:10 PM
Vintage "Ultra Lube" Grease (show & tell)
by GaryPoe - 09/20/19 08:09 PM
Impact driver for auto work?
by Klutch9 - 09/20/19 07:27 PM
2000 Honda CR-V Ex transmission fluid?
by taztheman - 09/20/19 05:36 PM
Pennzoil Launches Four New Motor Oils
by jayjr1105 - 09/20/19 05:25 PM
OilReport99, TungGT, ErikLeifson, Kinnes25, Bamajoe
69348 Registered Users
70 registered members (alarmguy, ArrestMeRedZ, 4WD, 379KITTY, 2004tdigls, 7 invisible), 1,828 guests, and 30 spiders.
Topics294,850
Posts5,067,976
Members69,348
Most Online3,532
Jul 30th, 2019
Page 1 of 3 1 2 3
Is there any advantage to DOT3 over DOT4? #4976553 01/11/19 10:18 PM
L
littlehulkster Offline OP
L
I need a brake flush in my 2015 Mazda3, and while the manual specifies DOT3, I have a large unopened bottle of DOT4 I had bought for a future job on my old car. I understand that DOT4 can be used in any application where DOT3 is specified without harm, but I was also thinking that since this car is a 2015, Mazda could have specced it for DOT4 in the manual but didn't, and DOT4 is not even mentioned. However, it seems that DOT4 is a flatly superior product.
Is there some sort of advantage to DOT3 over DOT4 that I'm not aware of, or was the DOT3 spec just a matter of cost? I guess to rephrase the question, I know I CAN use DOT4, but SHOULD I?
2015 Mazda3 I 2.0
Re: Is there any advantage to DOT3 over DOT4? [Re: littlehulkster] #4976568 01/11/19 10:34 PM
slacktide_bitog Offline
Yes, use the DOT 4 smile
Re: Is there any advantage to DOT3 over DOT4? [Re: littlehulkster] #4976569 01/11/19 10:36 PM
demarpaint Offline
I'd use the DOT 4.
God Bless Our Troops
Re: Is there any advantage to DOT3 over DOT4? [Re: littlehulkster] #4976597 01/11/19 11:16 PM
F
FordBroncoVWJeta Offline
F
DOT4 is superior.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: Is there any advantage to DOT3 over DOT4? [Re: littlehulkster] #4976603 01/11/19 11:26 PM
W
Wolf359 Offline
W
Yes, the only real difference is the cost, Dot 4 can be about double or so the price of Dot 3. Only reason for Dot 3 would be that the car isn't high powered and the brakes won't really be taxed so there's no need for the higher boiling points of Dot 4. But if you already have it, go ahead and use it.
Re: Is there any advantage to DOT3 over DOT4? [Re: Wolf359] #4976605 01/11/19 11:31 PM
L
L
I guess I have to wonder why DOT3 is even sold anymore, then. Sure, 4 costs more, but brake fluid is cheap overall. The cost of using DOT4 over 3 may be 2x, but 2x 5 is only 10.
2015 Mazda3 I 2.0
Re: Is there any advantage to DOT3 over DOT4? [Re: littlehulkster] #4976623 01/12/19 12:05 AM
W
Wolf359 Offline
W
Well the manufacturers watch every penny. Some recalls are caused by penny pincher that shave a few cents off the cost of a part. If you save $5 extra per car and sell 100k, that's a $500k savings. A few dollars here and there can add up to millions without raising the price.
Re: Is there any advantage to DOT3 over DOT4? [Re: littlehulkster] #4976676 01/12/19 03:33 AM
H
HorseThief Offline
H
They taste the same to me....
I saw a brown dog
Re: Is there any advantage to DOT3 over DOT4? [Re: littlehulkster] #4976811 01/12/19 09:42 AM
A
Audios Offline
A
DOT 3 is less likely to absorb water and can usually go longer in the system before changing. However 4 is the better fluid.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Is there any advantage to DOT3 over DOT4? [Re: Audios] #4976828 01/12/19 09:58 AM
spk2000 Offline
Have heard this more than once but never saw anything that proves it is true and not just rumor. Anyone got some studies or evidence?
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: Is there any advantage to DOT3 over DOT4? [Re: littlehulkster] #4976845 01/12/19 10:22 AM
Dufus2 Offline
I used DOT 4 from Napa and it seems to be a little thicker, in very cold weather DOT 4 may be slower to respond. I just use the Walmart SuperTech DOT 3 brake fluid (paid $5 for a quart) and change it out every 2-3 years depending upon the condition. I just bought a brake fluid tester pen and my old fluid tested at 1-2% moisture after at least two years.
ASE Certified in Med/Heavy Truck Service including A9
Heavy Equipment Repair, Fleet Maintenance
Real Cars Rattle and Smoke a Little
Re: Is there any advantage to DOT3 over DOT4? [Re: Dufus2] #4976854 01/12/19 10:30 AM
M
mightymousetech Offline
M
There is DOT 4 low viscosity. It is what BMWs call for.
Mighty Mouse Tech
BMW Diagnostic and Alignment Tech
2013 BMW 135i M Sport Edition Motul 0W40, MTL/MT-LV
2010 BMW 328i X-Drive, Castrol 0W40, MT-LV
Re: Is there any advantage to DOT3 over DOT4? [Re: spk2000] #4977211 01/12/19 05:35 PM
W
Wolf359 Offline
W
I heard that as well, further research seems to show that Dot 4 actually absorbs less water than even Dot 3 so that bit isn't even true. The more frequent flush recommendation may just be a good reason for some dealer to get the car in for maintenance.
Re: Is there any advantage to DOT3 over DOT4? [Re: littlehulkster] #4977266 01/12/19 06:46 PM
N
nobb Offline
N
If you're changing your fluid often, the dry boiling point is more important. If you're not changing your fluid often, then the wet boiling point is more important. There's some DOT 3 fluids (like Ford PM-1-C) that actually outperform the DOT 4 standard for dry boiling point, but falls short in the wet boiling point.
Re: Is there any advantage to DOT3 over DOT4? [Re: Wolf359] #4977279 01/12/19 07:00 PM
G
Garak Offline
G
Something like Castrol LMA DOT 4 certainly markets based upon that aspect. Whether that's true for other DOT 4 varieties, I have no idea.
Plain, simple Garak.
Page 1 of 3 1 2 3
