Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
72 registered members (2004tdigls, 1foxracing, 2009Edge, 2015_PSD, 2010Civic, Agnosto, 5 invisible), 1,385 guests, and 54 spiders.
Topics286,108
Posts4,902,735
Members67,563
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: Rubber Lubricant? [Re: pbonsalb] #4948248
12/10/18 01:54 PM
12/10/18 01:54 PM
wisconsin
zonarosso Offline
zonarosso  Offline
wisconsin
Old post but came up in a 2018 search. There's a product called red rubber grease that is the stuff I've received in Brembo brake rebuild kits. Used to be made (maybe still is?) by Castrol but I found generic online. For a thinner lube I use silicone based dielectric grease. Silglyde is a little thicker, Parker O-ring lube is thicker yet. I've also used olive oil in certain applications (japanese car trunk/hatch locks where the pawl is rubber coated). The P80 line of lubes from International products is excellent but can be hard to find. They make stuff that lubes the rubber for installation and then the lube dries and promotes adhesion.
Re: Rubber Lubricant? [Re: MolaKule] #4954535
12/17/18 09:51 PM
12/17/18 09:51 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Originally Posted by MolaKule
A silicone-based product like Amsoil Silicon Sray is excellent for light trim.
Westly's Black Majic, a super thick silicone fluid is probably best for tires, hoses, and heavy/thick rubber.
Those tire wet products have petroleum distillates in them.
Look at silicone brake fluid as an option.
Re: Rubber Lubricant? [Re: pbonsalb] #4954703
12/18/18 07:26 AM
12/18/18 07:26 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
For common o rings found on injectors and hoses use WD40 for installation, to remove stuck rubber hoses just lift the edge with a pick and squirt some down the opening, twist and it will remove easily. Nothing works better.
For A/C and brake use a product specifically designed for use with these systems. I got this tip from MOOG years ago with a rubber boot fiasco.
Re: Rubber Lubricant? [Re: pbonsalb] #4955051
12/18/18 01:34 PM
12/18/18 01:34 PM
California
nthach Offline
nthach  Offline
California
For AC O-rings and compressor seals, the specified compressor oil works fine, Nylog works better as an assembly lube for HVAC seals but the benefits aren't worth the $ for it. For general purpose O-rings, depending on the system I like silicone spray, Dow 111 or motor oil/ATF to lube them. For braking O-rings, use Dow 111/silicone dielectric grease or red rubber grease(Castrol or Toyota) ONLY.
Re: Rubber Lubricant? [Re: pbonsalb] #4972283
01/07/19 01:49 PM
01/07/19 01:49 PM
W. WA (too close to Seattle)
Unicorn01 Offline
Unicorn01  Offline
Since this is back to life, it seems that there is still interest and possibly questions.
Silicone is good, unless the o-ring contains silicone as I've seen silicone rings expand when a silicone oil or grease was applied. Nyogel (https://www.nyelubricants.com/nyogel) is a rubber safe grease that has been used to protect o-rings in things like flashlights.
Re: Rubber Lubricant? [Re: pbonsalb] #4973258
01/08/19 01:53 PM
01/08/19 01:53 PM
NY, NY
NYEngineer Offline
NYEngineer  Offline
NY, NY
Murphy's oil soap. Been using it for years.
Re: Rubber Lubricant? [Re: pbonsalb] #4976493
01/11/19 08:58 PM
01/11/19 08:58 PM
California
vavavroom Offline
vavavroom  Offline
California
Are you talking about synthetic rubber-like elastomers or natural rubber? Natural rubber can be lubricated with tallow or powdered tallow. Avoid any mineral-based lubricant on natural rubber. Synthetic rubber may be treated with silicone oil/greasel but I would use it sparingly. I have repeatedly heard that too much silicone oil/grease can damage silicone elastomers over time. Soap makes good lubricant for window molding installation with a string. Soap washed of course off, so it's not a lasting lubricant.
Re: Rubber Lubricant? [Re: FowVay] #4976496
01/11/19 09:04 PM
01/11/19 09:04 PM
California
vavavroom Offline
vavavroom  Offline
California
Originally Posted by FowVay
companies such as Parker sell rubber lubricants specifically for O-rings. If you have rubber exposed to the atmosphere then plain old talcum powder is used by nearly every rubber manufacturer to prolong the life of their product while in storage.
Talcum powder is used for longterm storage of rubber parts because oxidized rubber gets sticky due to devulcanization over time and the talcum powder prevents the rubber parts from sticking, I often feel a greasy type powdered on new rubber parts and that's to the best of my knowledge powdered tallow, which serves likely doube-duty as a lubricant/conditioner and ant-stick agent.
Re: Rubber Lubricant? [Re: pbonsalb] #4976498
01/11/19 09:05 PM
01/11/19 09:05 PM
E. Tennessee
WhizkidTN Offline
WhizkidTN  Offline
E. Tennessee
Can't you just spit on it and slide it in?
Wow, that sounded completely wrong!
His: '12 Kia Optima SX - 2.0L GDI Twin-Scroll Turbo [Tuned] (78K)
>EDGE 0W-40, Fram XG9688
Her's: '14 Nissan Rogue SL AWD - 2.5L NA (80K)
>EDGE 0W-20, Fram XG6607
Re: Rubber Lubricant? [Re: WhizkidTN] #4976501
01/11/19 09:09 PM
01/11/19 09:09 PM
NC
BigD1 Offline
BigD1  Offline
NC
LOL
1992 Toyota Pickup--PYB 10W-30--Fram PH3614
Page 2 of 2 1 2
