How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
89 registered members (aircooled, alteredtuning990, aquariuscsm, 64bawagon, 2015_PSD, Alfred_B, 8 invisible), 1,508 guests, and 58 spiders.
Topics286,110
Posts4,902,758
Members67,563
Most Online2,967
Mar 10th, 2019
Page 5 of 5 1 4 5
Re: Platinum or Iridium Plugs for OPE? [Re: Kamele0N] #4971726
01/06/19 09:36 PM
01/06/19 09:36 PM
Texas, United states
Jmoney7269 Offline
Jmoney7269  Offline
Autolite are on the low end of the spectrum..... its hard to go wrong with the good ole trusty NGK copper cores like a BPR5ES, CR7E, BMR6A, etc
Good bbq ain't cheap and cheap bbq ain't good!
Re: Platinum or Iridium Plugs for OPE? [Re: Astro_Guy] #4972715
01/07/19 10:22 PM
01/07/19 10:22 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
This spring I will put in NGK Platinum plugs in my OPE. Also a new set of NGK Iridium plugs in the 2007 Fusion.
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 67K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Platinum or Iridium Plugs for OPE? [Re: tig1] #4976494
01/11/19 09:00 PM
01/11/19 09:00 PM
Pennsylvania
Astro_Guy Offline OP
Pennsylvania
Great! Keep us posted. Personally I am happy with this change; check back with me in 4-5 years when my "never replace the plugs again" strategy either kicks in or falls apart.
Some additional observations...
  • My Honda push mover with GCV160 engine and stock NGK copper plug had the most hours [well into the hundreds] of any in the fleet, and that plug looked good. This has been a trim mower with very few hours for the past four years, yet the plug still looked good. Honda and NGK quality I suppose...
  • My Aries Deluxe 24 snow blower with the AX 254 cc engine and a Torch plug showed great improvement, and the stock plug had less than 5 hours on it. The stock plug seemed to foul to the point of not being able to restart cold after every use. It starts or at least tries to on the first pull now, this after two months of brief exercise runs.
  • For my Champion 3500 watt / 196cc generator, also with a stock Torch plug, I cannot honestly say if it starts any easier. I've taken up a practice of starting it at least once a month, and it started easily before and after the plug change using this protocol. It was difficult to start after sitting idle for 2-3 months, but that would be an apples to oranges comparison. Subjectively I think it is starting a little easier.
  • Not enough hours or cycles on the pressure washer with Honda GCV160, but it starts easily and runs well. I took it out in late October in 50 F weather and it started on the first or second pull. It hasn't been run in nearly three months, so it will be interesting to see if it stars as easily the next time.
  • The John Deere D140 riding mower is electric start only. It started and ran well for the first 100+ hours on the original Champion plugs, which is twice their recommended hours. We shall see how she comes out of storage in a few months, but she started and ran well most of this season on NGK Iridiums. Of any of the macines I own, this is the one that will benefit the most from Iridium plugs because it gathers the most hours.
Hopefully I will remember to update this thread later in the fall of 2019.
Page 5 of 5 1 4 5
