Originally Posted by kenwin30
My wife came across this car, it has 120k on it !! She wants me to buy it ! Where do these cars stand as far as reliability goes ? I usually stick with Toyota or Honda, how well does this BMW stack up against these two. Need some feedback before i pull the trigger. Thanks
All Euro cars require preventive maintenance. That is also how Germans think, it is cultural thing.
On X3 transfer case seems weak point, as any BMW cooling system is an issue (I personally would change all hoses and radiator on such old car, Euro or Asian, does not matter. Pump is electric and pricy). Oil filter housing gasket and valve cover gasket. However, there is no six cyl that is that smooth and that develops power in that fashion.
See if records are available, how it drives, any jerking at parking lot speeds (indication of failed transfer case).
If all that checks out and you get car, here is thing:
1. Change TC fluid, use ONLY BMW TC fluid.
2. Change tranny fluid and filter. As mentioned it is GM sourced, you can use I guess Maxlife etc.
3. Differentials. Change fluid.
4. Get used on buying oils with specific approvals and not generic synthetic oil (they are though not any more expensive and readily available in Wal Mart).
They do require more attention, but no Asian SUV and majority cars will drive like that senior citizen
